Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Thu May 08, 2008 10:06 am
To start with So Cal is only warm try Vegas at 110 or places in AZ that reach 115 or more
You do need to run a thermostat in hot or cold weather. In cold it keeps the engine at a good operating temp.
In hot weather the restriction of the thermostat slows down the flow of water through the radidator giving it time to be cooled. If you run the water through to fast it will not cool and eventualy it will overheat.
If you insist on running without the thermostat (not recomended) then what you need to do is punch out the center so that the outer body will still restrict water flow.
Just remember that if you didn't need a thermostat the factory would not have spent the time and money to design a houseing to put one in.
