 cam position sensor, stalling 96 240sx 2.4dohc
davidjmoser
1996 240sx
Massillon OH
5-7-2008
1996 240sx, 2.4 dohc...been running great from day one, bought new off showroom...heard a small pop sound-stalled suddenly in traffic w/no warning or prior indication of trouble.
would not restart, would crank but not start- could not push start-fuel delivery excellent, plenty of pressure - NO SPARK.
hear a clicking sound, sounds like electrical arc-very fast seems to be coming from connection point in wires going to injectors, can even physically feel the clicking at connection-mechanic checked distributor, coil, ignition- all good- narrowed down to cam position sensor, also found 10amp fuse blown- replaced sensor and buss fuse- car ran great for 2 days and did the exact same thing again-when this happens car behaves weird electronically, and looses battery power very quickly - any thoughts???
ufakefe
oooouuuulala HI
1-18-2007
 « Re: cam position sensor, stalling 96 240sx 2.4dohc (davidjmoser)
I had to re read your post a few times. stressed? heres what I understand. you pinched the fuel line for checking fuel pressure? the injectors clicking is normal they do that. how did the mechanic find that the cps was bad? how do you know you have no spark?? what 10 amp fuse is blown? that would help us to see what area to look at. what do you mean " car behaves weird electronically"?? and loss of battery power?? do you mean the when the car acts up, and stalls you try to crank it over it seems the battery is dead???? the only thoughts that I have is you need to explain yourself in more detail. cause diagnosing a car that we cant see in person is a very hard thing to do.
davidjmoser
1996 240sx
Massillon OH
5-7-2008
 « Re: cam position sensor, stalling 96 240sx 2.4dohc (ufakefe)
the first time the car broke down the mechanic came out to look at it before we towed it to his garage, he pulled the gas line and had me start it to make sure it was getting gas it was (he said he later checked the actually pressure using a gauge at the shop and it was @spec)...he then checked for spark, he did this by pulling a plug and using a screw driver somehow propped against the engine block & inserted into the plug wire and once again having me turn the ignition (I'm assuming he was looking for arc and there was absolutely nothing...again, he tested this again once the car was at the shop...@the shop he told me he checked and ruled out the distributor, ignition coil, power transistor & resistor...as for the 10amp fuse, I'm not sure, I'm not at the shop and can't reach him, there is only two 10amp fuses, they are for the egrc solenoid valve.fuel injection system (both lean & rich side), the front heated oxygen sensor & rear heated oxygen sensor- idol air control valve, auxiliary air control valve, & closed throttle position switch - they may run other things but thats all i've been able to determine -i am not a mechanic though! when the car stalled 1st time i was accelerating, the second time i was @ a stop light and taking off from a stopped position - when it stalled, all the dash indicators started flashing and with in minutes, the battery goes dead...the battery was tested the first time and determined to be fine - I've not spoken to the mechanic yet, just tried to call, not sure how he determined cam position sensor was the problem
EstoMax
95 240SX KA-t
Seattle WA
6-25-2004
most likely your distributor took a crap. happened to me with similar symptoms. used ones can be found for about $50, new are $$$.
Marko
1995 240SX with speed(Hail) dings
180sx+silvia=sileighty
240sx
haystack ca
5-28-2006
so what did your mechanics say was wrong with it. its probably the distributor. like EstoMax said
davidjmoser
1996 240sx
Massillon OH
5-7-2008
he said he narrowed it down to a wiring short in the harness coming out of the ecm, he said he was checking connectons on the harness and when he pulled on a certain set it would blow the ten amp fuse and cause the problem again, he said he was able to duplicate the problem three times, and that he narroowed it down to a six inch area of these wires...BUT>>he then called me back 2 hours later and said he couldn't find the short and now couldn't duplicate the problem any more...i told him to drive the car for a few days and see what happens..he assures me the distributor is fine????
240sx
haystack ca
5-28-2006
alright let us know how it turns out.
davidjmoser
1996 240sx
Massillon OH
5-7-2008
 « Re: cam position sensor, stalling 96 240sx 2.4dohc (180sx+silvia=sileighty)
still not solved, i need to find someone who knows what they're doing
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
