rear subframe stud broke
silviaS13lover
Car: yellow llama onevia
ok so my coupe has some rust. i was lowering the subframe to install spacers, and the nut snapped the stud. so now i only have 3 main studs holding my subframe. any idea on how to replace or get. thanks
KiMbRoZz
Car: 1997 Q45 Silver on Black
I would first say:
1) Grind the stud off2) Drill out the stud all the way through the subframe3) go to a savage yard and saw off the savage stud4) weld (tight bead) a 1/4" plate with the stud in the center making a "T"5) insert the welded plate from the back side of the subframe6) weld into place7) Better than new
silviaS13lover
so i was maybe thinking of just having my buddy weld the lower bracket on the remaning stud.
KiMbRoZz
Now I sound dumb.....I figured you wanted a strong, unbreakable setup
94_240sx
Car: 94_240SX
You can hammer it out. It's pressed to the floor. IIRC, one of the members, babowc had same problem.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
similar sitiuation, the 02-05 altimas have the subframe recalls. I have seen those studs snap and then they get sent to the bodyshop to have a 2000 dollar frame welded in.
silviaS13lover
ok. ill mess with it at school tomorro. f***** rust. FTL
KiMbRoZz
what kind of KA-T stuff do you have for sale?
silviaS13lover
i have just the injectors left for sale.
KiMbRoZz
size and how much? please
KiMbRoZz
oops, I see it in your sig. nevermind
n1smodr1ft
Car: 1998 bmw 540i 1992 sr coupe
wow f those i used to work at nissan and i hated bish.
nissans13240sx wrote:similar sitiuation, the 02-05 altimas have the subframe recalls. I have seen those studs snap and then they get sent to the bodyshop to have a 2000 dollar frame welded in.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
n1smodr1ft wrote:wow f those i used to work at nissan and i hated bish.
+1 but its easy money once you do a few of them....i remember my first day at nissan when i went in the shop and was like.....wtf? There was a huge pile of probably 20+ subframes in the corner.
KiMbRoZz
20+??? Dang
silviaS13lover
was their a post on his problem 2, or if i hammer it out, then where does it come out at?
94_240sx
Car: 94_240SX
silviaS13lover wrote:was their a post on his problem 2, or if i hammer it out, then where does it come out at?
We were talking about sub frame spacers and bushings and stuff in suspension forum and he brought that up. If you remove rear seat or carpet, you should see the studs. Spray some PB Blaster and hammer it from the underneath. You should be able to remove it that way. I think there's a write up on it over at z*****.net.
