My Turbo Versa
General Discussion forum for Versa Owners
tyler_ofspain
Car: 2008 Nissan Versa S
reyes1212
Car: '07 Nissan Versa Super Black
How are things now?It a lot faster now?Who did it for you? Professionally done?
datsun2401972
Car: 90 Nissan 240SX XE coupe
no total annihilation of the front tires pics? Or are you still running stock clutch lol?
Mr. LS
your intercooler is crooked! Looks tight, gone to the dealer for any service yet!??? I'd love to see the looks on their face when they pop that hood to see that turbo under there!
Great White Versa
Car: 2007 Nissan Versa S HB 6sp
what's this?
Click for full size - Uploaded with plasq's Skitch
blindsnyper
Car: 2007 versa
bov i beleive
Johniboi
Car: Versa
blind_snyper wrote:bov i beleive
as jusbout to say that..lol..but forget about pictures, i wanna see some videos!!!!
rafa2210
Car: 2004 nissan 350z roadster
what turbo is it? I havent found any turbo for versa
Neo Xian Wu
Car: 08 Nissan Versa S Hatchback 6spd
rafa2210 wrote:what turbo is it? I havent found any turbo for versa
It's from the Fox Marketing turbo Versa. He recently parted out the car and tyler was the lucky sob to get the turbo. Glad he got it together, though. Looks clean and well done.
ZuZ
Car: Nissan Tiida S 1.6 2008
wats a bov?
Knightro2
Car: 2008 Nissan Versa SL
BOV=Blow Off Valve. Also known as a "dumper valve". It releases the pressure in the intake system for a turbo charged engine. It's what makes the noticable "pssssshhhhkk" sound in a turbo car.
bigboo_VHB
nice
ZuZ
Knightro2 wrote:BOV=Blow Off Valve. Also known as a "dumper valve". It releases the pressure in the intake system for a turbo charged engine. It's what makes the noticable "pssssshhhhkk" sound in a turbo car.
thanx for the info
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
Beautiful!How's the ride? Any improvements? What about mileage? Nice sound?
Hey, we need more details! Everybody's waiting for news here!!!
CodeRed
Car: 2008 Nissan Versa S MT
take the velocity stack off and put a filter on.
Also, did it come with injectors, new ecu, anything to keep you from detonation?
tyler_ofspain
Hey so when i was removing the the O2 sensor from the stock exhaust i realized that it came cross threaded!!! That combined with the stock clutch means no fun videos or tire roasting... YET!
and that blue piece circled is indeed a Tial BOV
and no there were no injectors, ecu, or anything else to keep me from screwing everything up... oh well
Mr. LS
tyler_ofspain wrote:and no there were no injectors, ecu, or anything else to keep me from screwing everything up... oh well
So then it isn't tuned . . . lolz, this is EXACTLY what I was talking about.
tyler_ofspain
Nope and nobody has software for this car so i can't get it tuned...
CodeRed
your going to hit boost, go real lean, and kablamo. Make sure you use the best fuel. You might also want to purchase a SAFC and get it dyno tuned also get an air/fuel map that'll tell you if your going lean during boost (and i can only assume you are). good luck?
edit: Also, battery doesn't fit with the turbo? Get pix of the manifold. Thx.
Mr. LS
hit up road race engineering, see if they will make a piggy back for you.
Mr. LS
CodeRed wrote:your going to hit boost, go real lean, and kablamo. Make sure you use the best fuel. You might also want to purchase a SAFC and get it dyno tuned also get an air/fuel map that'll tell you if your going lean during boost (and i can only assume you are). good luck?
pointless unless he is running a wideband o2
tyler_ofspain
ZuZ wrote:wats a bov?
weems84
Car: Versa SL
i thought the fox marketing versa had upgraded injectors and a one off clutch made for it as well???
Engine: 1.8L MR18DE - 6 Speed ZPI Racing Turbo Kit -Garrett GT2871 Turbo -ZPI Velocity Stack -ZPI 440 high flow injectors *****************-ZPI 2.5 inch stainless steel intercooler piping -ZPI 26x12x3 Intercooler -ZPI 4 ply couplers -ZPI T Bolt clamps -ZPI Mass conversion -ZPI High Flow Oil Pump -ZPI Water & Oil lines -ZPI 2.5 inch T304 Stainless Uppipe -ZPI 2.5 inch T304 Stainless Downpipe -ZPI ECU & Brake reservoir heat shields -ZPI Mini Battery and relocation kit -ZPI Aluminum Valve Cover -Tial Blow off Valve -Synapse Engineering Wastegate ZPI Crank Pulley ZPI Stage 3 Clutch *********** ZPI 9lb Flywheel ZPI Mid pipe and Tanabe Axle Back Exhaust AEM Tru Boost Gauge AEM Wideband Air/Fuel Gauge
Cardomian page http://www.cardomain.com/ride/2454369
feloniousmonk
Google.
biggie
Stock ecu + stock injectors + boost = big problems (Unless its like 3-4lbs). But even with really low boost a SAFC would be needed.
Neo Xian Wu
I think tyler needs to provide more information...
tyler_ofspain
Engine: 1.8L MR18DE - 6 Speed ZPI Racing Turbo Kit -Garrett GT2871 Turbo -- yes-ZPI Velocity Stack -- yes-ZPI 440 high flow injectors -- Unfortunately no-ZPI 2.5 inch stainless steel intercooler piping -- yes-ZPI 26x12x3 Intercooler -- yes-ZPI 4 ply couplers -- yes -ZPI T Bolt clamps -- yes-ZPI Mass conversion -- don't really know what he meant by that? -ZPI High Flow Oil Pump -- yes-ZPI Water & Oil lines -- yes-ZPI 2.5 inch T304 Stainless Uppipe -- yes-ZPI 2.5 inch T304 Stainless Downpipe -- yes-ZPI ECU & Brake reservoir heat shields -- yes-ZPI Mini Battery and relocation kit -- i did my own battery relocation-ZPI Aluminum Valve Cover -- NOPE-Tial Blow off Valve -- yes-Synapse Engineering Wastegate -- yes------------------------------------------------------------------------------------------------I was told that ZPI went out of business before these items were madeZPI Crank Pulley ZPI Stage 3 Clutch *********** ZPI 9lb Flywheel ------------------------------------------------------------------------------------------------ZPI Mid pipe and Tanabe Axle Back Exhaust -- midpipe included and i already had a cat-back
Apparently Brian Fox could not get these gauges out of his car--AEM Tru Boost Gauge -- AEM Wideband Air/Fuel Gauge
And for all of you who want more info.... i'll let you know once i get my O2 sensor put back in.... Nissan charges upwards of $170!! so it might take a little bit
biggie
tyler_ofspain wrote:Engine: -ZPI Mass conversion -- don't really know what he meant by that?
Mostly likely referring to the what most Nissan owners call a MAF. Which brings in the question of when will the OEM MAF max out or did you get one in the kit? If you got one and its modified without a SAFC or something to adjust it that is also an issue.
tyler_ofspain
biggie wrote:Mostly likely referring to the what most Nissan owners call a MAF. Which brings in the question of when will the OEM MAF max out or did you get one in the kit? If you got one and its modified without a SAFC or something to adjust it that is also an issue.
Oh well i suppose that would make sense... and no the kit did not come with a new MAF... but that probably would've been a good idea
Neo Xian Wu
What are you using as far as fuel management?
Return to “Versa General Chat”
