Desmoquattro wrote:"To add speed, add lightness." - Colin Chapman
So begins my personal hotrod idea that has been brewing in my mind for a while. Take a decent handling, big engine car and strip it to the bare bones to remove the most weight possible and get the best possible performance and economy, without spending a dime and without having any external mods to give away the work done.
My background in motorcycles has given me an immense appreciation of how much a weight loss program can do. 40 lbs off a stock motorcycle is a night and day difference in performance across the board. I've played with my machines before, cutting and stripping excess weight wherever possible with a minimum of expense. Perhaps my own diminutive weight gives me an even greater understanding of the value of weight savings - I weigh 130 lbs on a bad day, and the difference between a 130 lb rider and a 200 lb rider is incredible.
Originally I had thought about using a 5.0L fox-body Mustang, but could never find one that was cheap enough for the project. Typically they get at least 5000$ for a ratty, automatic LX up here, 10 000$ easy if you want a GT with a Cobra body.
Enter the most unlikely of candidates, the Q45.
I drive alone, I'm single and my girlfriend lives 450 miles away. All of my friends have their own vehicles so I never end up giving more than one person a ride. So why do I need space for four other people?
Stage one has been to strip the easy stuff - the trunk is gutted down to the bare shell, the extra plastic and insulation has been removed from the engine bay. I'm replacing the spare with a patch kit and some tire slime to lose a few more pounds. So far this isn't worth much, maybe 40 lbs of junk has been removed, hardly worth mentioning on a two ton car.
Stage two will start in the next month. I need the car intact for a few weeks, then I will go crazy. First will be the removal of the rear seat (new couch, woohoo), the rear door trim, the carpeting and headliner, the rear power window motors, the rear parts of the stereo system, and any excess bits I can get my hands on.
Stage three will be doing the same to the front, leaving only the seats and the front windows functional (I need ventilation, after all). The stereo headunit and front speakers will go, the front door trims out, any useless electronics will get ditched, and anything I need to leave will get replaced with aircraft toggle switches.
Stage four will be removing the front seats and installing fixed Recaro units.
Sacrilege? Of course. Fun? You bet. Riding around in a car surrounded by mechanicals and bare metal with no sound insulation is fun, if you are a masochistic petrol head like I am.
The ultimate goal is to have a vehicle that has only the necessities in place. On a typical rice-mobile it would almost make sense, on a luxo barge like the Q it's a wonderfully nutty proposition, and a fun way to increase performance.
Of course I'm keeping all the bits so that if I ever plan on selling the car intact, I can reassemble back to the original state.
Wow. Interesting. If I make it out to Montreal this summer, I'd love to see it.
A friend of mine told me about a 90-93 Q for sale up around his way a while ago. It used as an undercover Narcotics car. The police had purchased a Q, kept it stock on the exterior (with the exception of limo tint), and completely gutted the interior. He says that the rear seat was removed and replaced with a plastic bench type seat (similar to a bus or subway train seat), the carpet and headliner removed, dash, door panels, everything. I heard that if the detectives needed to clean the interior, a garden hose would suffice. Just hose it out and let it dry.
My friend told me that the cops replaced the OEM suspension setup with a modified interceptor setup.
I told my friend to buy it (it was $6500) but he didn't. I haven't heard about it since. If it was still for sale, I'd try to talk it down and buy it myself for possible use as a track car. (I refuse to do it to my Q. However, if I happen to get my hands on a second "throwaway" then I'd consider it.)
