what if.....
dormicum
Car: 2002 Q45
when the car is running and i shift to the +/- sidethen the display still shows as 'D'
when i stop the car, off the engine, and turn the key to 'ON' after 5 mins or somethingthe display of "AT check" keep on blinking, and when the engine started, it goes off
any bros had such experience before???????
dormicum
Car: 2002 Q45
anyone knows the cue?????????
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
didn't you also have a post about the trans locking up in 4th gear or something (i'll have to dig thru some other posts).
the AT light indicates that the failsafe mode has triggered. failsafe would also explain trans locked in 4th gear.disconnect the battery overnight and then reconnect.while disco'd put it on a low rate charger and make sure that your system voltage is proper.
dormicum
Car: 2002 Q45
3Q Jay wrote:didn't you also have a post about the trans locking up in 4th gear or something (i'll have to dig thru some other posts).
i seethe FSM said it should be disconnect over 24hours, right??????
