I inspected the parking brake cable at the rear tires and the driver's side is tighter than the passenger side. with the ebrake off, the passenger side has slack while the drivers side does not. i replaced both rear calipers.h.240 wrote:The parking brake setting could cause this, but it is set a
t the handle not at the individual wheels. If the tension was set too tight it should be too tight for both sides, unless the passenger side cable was stretched. When you replaced the brake calipers and rotors, did you just do the drivers side rear or all both sides? If you only did the drivers side rear it could be a problem with the other calipers sticking since this would cause decreased wear in those pads. Also, do you notice any sideways pull from the car under braking (especially towards the passenger side)? This also indicates stcking calpiers on that side of the vehicle.
No, I never found the problem. I took it to a brake place and they wanted to replace the calipers again. i never found any kinks in the metal lines and could not see the rubber hoses collapsing anywhere. not sure what it is.Atomic-S14 wrote:so did you ever find the source of the problem? My 96 240sx has the same problem and I've went to many different places, but am still not able to find the problem. About to do another quick pad replacement job now.
