Anyone using regular gas instead of the Premium thats recommended
MrMax03
Car: 2003 Gle Maxima
Is it worth the extra $$ 03 GLE
AcMav
Car: 99' Infiniti I30t
Ive used regular in my I30t for years, i just recently switched to premium because my knock sensor went bad so its worth it for me to use premium instead. I've had no problems on regular fuel.
Mr.Twister
Car: 96 Infiniti I30
89+ seems to work best for me. Anything lower just makes my car sluggish and is bad for the knock sensor. I want to try 93, but I can only get 91 here in Cali.
maxvq
Car: 1997 Nissan Maxima GXE
I've been using regular 87 octane fuel since I've bought my 1997 Maxima and I haven't had any lack of power or problems of any kind.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Premium will make a bit more power, but regular is perfectly fine in your '03 (and really any Max without a VG under the hood).
blackmax23
Car: 1999 Nissan Maxima SE-L
When I first bought my 99 max in 2003, I used 87, then had 2 o2 sensors go bad on me and the mechanic told me not to use 87 anymore. I've been using 93 ever since with no problems. But now that the gas prices are about $4/gallon for 93, I'm gonna be putting in 89 every once in a while to save some dough!!!
ZGadson
Premium gas is roughly 20 cents more per gallon than regular unleaded. Even if we had 20 gallon tanks, putting in premium over regular unleaded would only be $4 more. Because we don't have 20 gallon tanks, it would be less than $4.
Lately though, I've decided against premium. it burns so much faster than regular, which means you get less mpg.
Gman8990
Car: Pearl 1999 Nissan Maxima GXE
Weve owned an 87 Maxima, a 95 Maxima, and the 99 we have now. All 3 with regular gas. 87 got 270,xxx miles and then dad wrecked it. 95 got 180,xxx miles and dad wrecked it. The 99 has 111,xxx and still is going strong
rxm6
Car: '93 240sx
There is a pump at the gas station by my house with 100 octane. Lord knows I've been tempted....
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
MinisterofDOOM wrote:Premium will make a bit more power, but regular is perfectly fine in your '03 (and really any Max without a VG under the hood).
I ran 87 for about a year, then ran 93 for about 6 months, noticed no difference, and went back to 87.
Why do you exclude the VG?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
VG just isn't as advanced so it can't make up for crappy gas as well as other Nissan V6s. You may well still be fine running lower octanes in your VG. But in hot or humid climates during the summer it might cause knocking. That's why I don't run it here: in the summers it gets really hot and when you combine that with crappy gas you can end up with a car that feels below par.
PBfrEAk
Makes sense.
I just wish I could figure out why my VG idles weird. It didn't change no matter WHAT gas I used
telcoman
AcMav wrote:Ive used regular in my I30t for years, i just recently switched to premium because my knock sensor went bad so its worth it for me to use premium instead. I've had no problems on regular fuel.
In 2 1/2 years and 61k miles on my 2006 G35 Sedan, all I use is regular with no problems
http://www.nytimes.com/2008/06....html
Telcoman
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
rxm6 wrote:There is a pump at the gas station by my house with 100 octane. Lord knows I've been tempted....
making me jealous...can you ship some up to MT?
allensteiner
MrMax03 wrote:Is it worth the extra $$ 03 GLE
20cents extra/gallon is worth it. we're paying so much at the pumps anymore that your wallet won't even notice a $3 diference, but your car will.
maxhopper
Car: 02 Maxima SE 6spd
I guess I'll just copy my post on the same subject from 2 weeks ago.
maxhopper97 wrote:The fuel maps are designed to run most efficiently on premium. Using lower grade fuel will result in the knock sensor retarding timing and therefore decreasing performance. By decreasing performance, you get worse mileage per gallon.
For example: Say your standard fill is 15 gallons. Using regular grade fuel saves you $3 (saving $.20/gallon). Using permium you get 28mpg. Using regular grade you get 26mpg. Computing that out to miles per fill equates to 420 miles per tank with premium .vs 390 miles per tank with regular. That is a 30 mile difference which is over 1 gallon's worth of fuel, which at $4/gallon: you just lost over $4 to save $3.
This is just an example, since I only run premium, I have no idea what kind of mileage my Max would get on regular. This is just to point out that saving money on the front end could wind up costing you more in the long run.
allensteiner
to all you thinking regular is just as fine as premium...YOU'RE WRONG!!! look what i found: http://www.dynospotracing.com/octane.htm
and the dyno test is mid vs premium so what do you think it would look like with reg 85 oct? it's not about the power alone but also about your knock sensor.
kzoosho
Car: Turboed 1997 Nissan Maxima SE
I running 116 daily lol. No problems here.
allensteiner
kzoosho wrote:I running 116 daily lol. No problems here.
i bet how much is a gallon though? bout $20?
kzoosho
5.99 a gallon here. Not that much more than premium imho
allensteiner
not too bad. i thought about getting a barrel of toluene and mixing it in with gas. you should look into that - a lot cheaper and can give you more octane than your car can handle
danielekfuj
Car: miata, rocket ship
Do you live in teh USSR?
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
What about E85 I have heard that ethanol is like 110 octane is this true? I know all the indy cars use it so it must produce some decent power. In places like Brasil they use pure ethanol and its half the price of regular gas...only if it worked in the cold
lowblocks
Car: 1995 maxima
my friend put 89 in his 01 Cali spec max and the car ran like **** the car kept shutting off. so now we put 93 with a octane booster
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
johnnyd6404 wrote:What about E85 I have heard that ethanol is like 110 octane is this true? I know all the indy cars use it so it must produce some decent power. In places like Brasil they use pure ethanol and its half the price of regular gas...only if it worked in the cold
E85 only works correctly in cars that are designed to run on it. It's octane rating is higher than normal pump gasoline, but it's closer to 100 than 110. Ethanol CAN produce good power, but motors must be designed specifically for it. Flex fuel (dual-fuel gas and/or E85) engines found in commercial consumer automobiles run less efficiently on E85 than on gasoline.
And the reason Ethanol is so cheap in Brazil is because their economy and infrastructure support it. That is not the case in North America.
D-Maxima
Car: HSV VQ Statesman 5000i
It would cost so much to put in place the infrastructure to do that...
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
the 00 Max pings on 87, so we run middle grade or prem only
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Unless you're running with some boost, don't do it. You'll blow a ton of money for absolutely no gain.
There is a lot of talk about blowing the knock sensor using low octane fuel... your knock sensor isn't going to blow because you use low octane fuel. The heat cycling of the engine is far worse on the knock sensor than the sensor hearing extra noises. Your engine is constantly making different noises that the knock sensor constantly "hears", what it does is listens for a certain frequency that the engine makes when pinging and retards timing to prevent it from pinging anymore. The knock sensor can even pick up "pings" from something hitting the exhaust or engine and trigger the ignition retard in the ecu. If you knock sensor happens to die when you put in low octane fuel it was either its time or was already dead.
xobeachcrazyxo
Car: 1996 Infiniti i30t
My step mom had an Infiniti i30t for years and she never ran her on anything but premium... Right before I bought the car from her, my dad was driving the car and running it on like 83 (reg. gas) & told me that nothing would happen to her. "its no big deal". Once I buy the car I cant quite afford premium, so I still with the special/mid-grade gas... Next thing you know she's running rough, starting up ****ty, and just not handling to her fullest. That day i switched to premium & havent had any problems since
Oh... DOES ANYONE KNOW HOW TO MAKE THE LINING RIGHT ABOVE THE BACK SEAT STOP RATTLING FROM MY SYSTEM??? its not bad but it could sound better
