 LED Lights for the interior lights and licences plates?
DarkNiteM35
2006 M35
El Paso TX
5-1-2008
DOes anybody kno what type of led lights i can install instead of these ugly yellow lights? and where can i get them?
akliquid
Diamond Bar Ca
1-20-2007
 « Re: LED Lights for the interior lights and licences plates? (DarkNiteM35)
I got some LED's from AUTOLUMINATION. The interior lights are Ba9s. I actually put a 25 SMT LED plate. Here's a link:
http://akliquid.myphotoalbum.c...domes
They have white also. I also put super white LED in the license. Looks nice. I'll tell you the easy install if you want to get the plates, but they are super bright. I got blue cuz my car is blue, but they have all different ones to suit individual's preference. But again. just look for the ones that are Ba9s.
Modified by akliquid at 2:06 AM 5/3/2008
DaleHeller
07 M35, Obsidian Black
Nashville TN
1-1-2008
 « Re: LED Lights for the interior lights and licences plates? (akliquid)
How difficult was it to replace all the existing interior bulbs with the LED bulbs? Did you do the dash bulbs also ?
Any issues when you went back to have it worked on (e.g. warranty voided, etc?)
akliquid
Diamond Bar Ca
1-20-2007
 « Re: LED Lights for the interior lights and licences plates? (DaleHeller)
Just need a flat screwdriver to pop open the plastic covers and you have access to the bulb. Found that the SMT type LED (square) is far superior to the regular clear drop type.
Thought about putting red LED in dash, but don't know how to do it.
Have had no issues at the dealership or with warranty work.
Modified by akliquid at 2:08 AM 5/3/2008
xxNite
2004 M45 & '98 Toyota Supra Turbo
Philadelphia PA
12-17-2007
I installed license plate LED bulbs and WOW they look darn good! This is a link to where I got them from:
http://cgi.ebay.com/2pcs-501-W...wItem
I was a little worried about fit at first, but had to try them cause they have 5 LEDS pointing in all directions. They fit and they look like this:
http://rides.webshots.com/phot...lwhiE
http://rides.webshots.com/phot...pxcPr
http://rides.webshots.com/phot...QLGDh
definitely worth the $10
Hey AKLIQUID. In your photo album, what did you use to replace the factory H3 fog lights? they look b-e-a-u-t-i-f-u-l! I am assuming you went with an aftermarket H3 HID retrofit kit, right? which one & how much? I neeeeeedz that!
T. I. A.
xxNite
LaCapitalRue
Acura NSX
Indianapolis in
3-16-2008
 « Re: LED Lights for the interior lights and licences plates? (xxNite)
Looks good! You just sold me on the license plate bulb upgrade.
Hoshtaylor
2008 Infiniti M35 Sport
San Diego CA
12-5-2007
Quote, originally posted by akliquid »
akliquid...could you please send me the link of where you got those...? I've spent close to $50 on trial and error buying the Ba9s bulbs...only one set has worked. I was told there was/is a polarity issue and that's why all of the LEDs I've gotten do not work. Do you have an 08...?
2008 M35 l Sport l Tech l Eibach Springs l Greddy Exhaust l Fujita Intake l Xetronic 8000K HID l Halo 7500K Fogs l Bat Overlays l Raybrig Clear Turn Signals l LED Exterior l LED Interior l Teflon Coated l Clear Bra l Tint l
akliquid
Diamond Bar Ca
1-20-2007
 « Re: LED Lights for the interior lights and licences plates? (Hoshtaylor)
I got mine from AUTOLUMINATION. All the LED's I received from this site have worked without any issues. I have an 04 M45.
Here's a link for the Ba9s page:
http://autolumination.com/otherleds.htm
Hoshtaylor
San Diego CA
12-5-2007
I'm pretty sure I ordered those before...but I'll give it a shot !
Thanks for the info...I just ordered them. I'll let you know what happens after I install.
xxNite
Philadelphia PA
12-17-2007
are the LED's screw type, bayonet type, single socket bayonet, offset bayonet type?
Which ones for the '04 M45?
I want to change ALL of the interior lights in the ceiling liner, footwells, and even the trunk with brighter LED's(except the dash gauge cluster)
akliquid
Diamond Bar Ca
1-20-2007
The 2 lights in the ceiling, above the gearshift are Ba9s. The ones for the rear ceiling are different. Don't remember exactly, but better to just take the cover off and remove bulb to check. I believe it was wriitten on the bulb. Step/ courtesy lights in the doors are 158, and license plates are 168. Most bulbs can be used for both 168 and 194. In my experience, the regular, clear drop LED's are worthless, and burn out in a matter of months. The square, usually called SMT or SMD LED's are much better. It's a good idea to remove all covers and examine which way the bulbs face so you don't get a bulb that shoots the light in the wrong direction.
xxNite
Philadelphia PA
12-17-2007
I follow you on the fact that they are the BA9s variety, but do you remember if they are screw-ins or did they have two pointy posts?
I agree the SMT variety are GREAT. anything else is usesless and directional is a must.
what is the light in between the two front two map lights that illuminates down towards the gearshift? it is the one that adds subtle light so you can see near the cupholders, a little?
akliquid
Diamond Bar Ca
1-20-2007
Ba9s single contact bayonet type. Here's a pic.
http://akliquid.myphotoalbum.c...=ba9s
I couldn't get access to the light in between the maplights. Let me know if you figure it out.
Hoshtaylor
San Diego CA
12-5-2007
Quote, originally posted by xxNite »
They are BA9s bulbs...NOT the screw in bulbs. In other words, they are the ones with the "two pointy posts"
Hoshtaylor
San Diego CA
12-5-2007
yeah so I just received the bulbs and they don't work. I've only found 1 kind of LED bulb that works in this spot and they are hardly bright at all. I don't understand why none of these BA9s bulbs aren't working.
Has anyone changed out their map bulbs to LED's on an 08...???
topstar79
2006 Infiniti M35
Melbourne FL
5-14-2008
Quote, originally posted by Hoshtaylor »
The reason why probably none of the other bulbs you've tried works is because the polarity of the leds are reversed. I've changed out my map lights with these:
http://cgi.ebay.com/ebaymotors...photo
and I just reversed the little white connector between the actual led board and bulb adapter and it worked fine and they are extremely bright.
Hope that helps.
Hoshtaylor
San Diego CA
12-5-2007
 « Re: LED Lights for the interior lights and licences plates? (topstar79)
Quote, originally posted by topstar79 »
Any chance you could describe this a little better or maybe have a pic of what it is I need to do...?
Hope that helps.
Pashdut
06' M35
12-7-2005
T. I. A.
xxNite
That is too bright.
06' M35
xxNite
Philadelphia PA
12-17-2007
 « Re: LED Lights for the interior lights and licences plates? (ttsupra26)
Perhaps a little bright, but you know how PALM cameraphone pictures are, especially at night. over-emphatic and unrealistic. in real-life they don't appear as washed-out and overly bright; It looks good and clear IMHO, but don't try to outrun cops with these... They get your plate number very easily.
» Return to M35 Forum / M45 Forum / Fuga Forum
Car Finance Advice Nissan Infiniti News Archive
240sx technical information Nissan technical information
Infiniti technical information Nissan Infiniti Car Owners Homepage
Advertisers Marketplace
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
