 GETTING A 350Z differences between years 03, 04 or 05. which would it be better?
maku_gx
240sx
rockville md
9-5-2006
hey there
I'm not new here, but you wouldn't be able to tell :P
I had a 06 z before, and I had to give it up cuz I got into a **** company that wouldn't pay me, called USQFS and it worked with MARLO between many! them ****ers.
anyway.
then I got 240sx 91, n Its got so much problems I dont know about I'm getting tired of it.
Even though I have not given up, n still learning I got an awesome job now and I can buy a new z.
THE POINT IS
I'm trying to figure out what would be better to buy.
if you had to chose between 03, 04, and 05, what would you get?
motor wise, are there any differences that should I get concerned about?
I'm going to be drifting the car, and heavily modify it to get 500hp at least. (with time)
I'm also planning to buy an rb26 or a good engine that wouldn't take away the car's harmony, weight balance and so on.
well thanks for whatever input you got!
maku gX
R350Zz33
Window Licker
2008 350z
Manorville new york
3-25-2008
 « Re: GETTING A 350Z differences between years 03, 04 or 05. which w ... (maku_gx)
the 03-04 287 hp 05-06 300hp and 07-08 306hp i would keep the vq its a great starting block just build and turbo or supercharge it tt could bring it up near the 800hp
"I drift not because it is a quicker way around a corner, but it is the most exciting way" - Keiichi Tsuchiya
rmezz13
350Z Moderator
2004.5 Nissan 350z Performance
Columbus OH
11-27-2007
 « Re: GETTING A 350Z differences between years 03, 04 ... (R350Zz33)
As far as the cars, the 03-04 is fine especially if your plan is to upgrade for power. The 03 - 04 will cost you less to buy because its older, thus putting you $$$$$ closer to your goal. The 03-04 has 287 hp and 274 ft/lbs, the 05-06 has 300hp and 260ft/lbs, some that have driven both say the earlier models seem to be more aggressive through all the gears and all around more fun to drive compared to the 05-06. The 03's and early 04's had some issues that were solved via recall, so you would be pretty unlikely to find one with these issues. Also i do believe a carfax report would list any recalls. 2004.5's were free of the issues the earlier models had. Be sure to get a performance model or up, for the fact they have the LSD. Well you probably plan on adding an LSD since you are building a drift car so i guess a base model would do. As far as adding HP's with TT's, you will not see 800hp on the stock internals. I believe R350Zz33 is refering to the APS twin turbo kit that makes 800hp but it is required to have a built motor to handle that kit. You could build over 400whp with a single turbo kit or twins, easily on stock internals. Might even be able to see 500whp on stock internals (never heard anything but i am willing to try if i can do it without too much risk and some built heads). Hopefully i helped shed some light.
350z Forum
350zClub.org
NICO Home
Quote, originally posted by R350Zz33 »
so how do u guys dress what kinda shoes ect. jw if all z owners wear the same typs of things
R350Zz33
Window Licker
2008 350z
Manorville new york
3-25-2008
 « Re: GETTING A 350Z differences between years 03, 04 ... (rmezz13)
I stated that he should build the motor iwould not goover 400 with stock internals just keep it low and slowly build up or just save up and do it all at once u could even keep the 240 and make that a drift car
jdubs
1994 KH6 300zx TT / 1993 KH6 300zx NA
Philadelphia / Erie PA
11-20-2007
Both the 350Z and G35 have oil consumption problems. Nissan has issued a TSB and you can get the engine replaced under warranty. Unfortunately the replacement engines had the same problems.
The 03-04 350Z had the least engine problems, but more stuff like uneven tread wear, etc.
The 05-06 350zs used the VQ35DEHR engine, which seems prone to burning excessive oil.
Engine modifications would void the warranty.
I wasn't impressed with the 350z or G35.
NSRsheets
1993 Nissan 240sx SR20DETcoupe, 2003 modded tiburon, 92 dodge colt, 2003 350z
Sheffield Ohio
8-7-2006
 « Re: GETTING A 350Z differences between years 03, 04 ... (jdubs)
Rmezz pretty much somed it up. It comes down to how much do you want to pay and how many miles. With the 03's you can put in test pipes with out buying a similater program. Any year 350Z is a good one.
03 350z with aero package
jabber87
2003 Touring 350Z 6MT
College Station TX
7-1-2007
 « Re: GETTING A 350Z differences between years 03, 04 ... (NSRsheets)
In addition to what rmezz said, the 03 and 04 models had slightly smaller brakes, and the 05+ were upped in diameter size... cant recall how much.
maku_gx
240sx
rockville md
9-5-2006
 « Re: GETTING A 350Z differences between years 03, 04 ... (jabber87)
wow these details sure help make ones mind up.
I appreciate this.
I'm gonna be modding the car, but before I'm going to check what problems are the worse, and whats gonna be convenient.
up to now I think I'm going for 2004 model.
Because I'm aware of there being a few problems, but I'd prefer that these problems are easily gone by upgrading parts, which is the ending goal either way. ^^
you see what I mean?
R350Zz33
Window Licker
2008 350z
Manorville new york
3-25-2008
u need to check ur facts im 16 and i know more about the z then u bro come on the is no such thing as a vq35dehr and engine mods do not void the warranty we are protected by a law that states the only way they can void ur warranty is to prove that the mod is the direct cause of the malfunction. the only thing ur right abot is the oil that the 05-06 drank. u may not be impressed jdubs because u dont have the right info do some research and then open ur mouth
maku_gx
240sx
rockville md
9-5-2006
ok
i dunno who that was directed to but
ALRIGHT!
you may have ur facts right
but you oughta learn not to be so cocky and full of urself.
either way its all good.
i like u sharing good info.
I respect you for your research values.
Mine are not as good.
rmezz13
350Z Moderator
Columbus OH
11-27-2007
 « Re: GETTING A 350Z differences between years 03, 04 ... (maku_gx)
maku_gx - r350zz33 was replying to the post by "JDUBS"
R350Zz33 - keep down the hostility, thats how things get locked down around here.... Find a way to reply without being so hostile.....
Just try to ignore posts like that man.....
nterrigno
2005 Nissan 350Z (Enthusiast)
bridgeton nj
3-7-2007
I have an 05 Z. I thought only the 35th aniversary Z had 300HP in 05 and that engine had twin intakes? Correct me if Im wrong. It thought my car has 287HP
2005 Nissan 350Z (Enthusiast) 6-spd
xjmxstac
2003 nissan 350z track edition
chula vista california
2-27-2008
+1
maybe the vq35de and the vq35hr made a baby and shipped it back in time to 2005... jdub is a dumbass i bet he dont even have a z... some people take the time to register for a forum just to bag on other people's ride! Get a life jackass...
Nismo CAI, JIC y-pipe, RS*R ex-mag gt II
Vida, Roxy, and Tammy
xjmxstac
2-27-2008
 « Re: GETTING A 350Z differences between years 03, 0 ... (nterrigno)
Quote, originally posted by nterrigno »
the 05 and 06 had the vq35de revup engine that has a higher rpm range but lower torque...300 bhp/ 260 lb/ft. And the vq35hr from the 07 and 08 has twin intakes and 306 bhp!
R350Zz33
Window Licker
2008 350z
Manorville new york
3-25-2008
 « Re: GETTING A 350Z differences between years 03, 04 ... (xjmxstac)
C
Quote, originally posted by xjmxstac »
+1
thx man i just wanted to let people know i wasent being cock the guy was bagging on z's and g's so i had to put up the facts becuse u dont want someone to see wrongful info on the cars and make a desision on what they are are reading from some scum bag that has time to bag on the cars with the wrong info and try and tell us they suck
dspiel
2006 Nissan 350z Silver Alloy
Santa Monica CA
4-20-2008
I have an 06.....I would get the new 07 or 08, that engine is amazing.
Watermelonwarrior
2004 350z
Arlington Tx
8-21-2006
Quote, originally posted by rmezz13 »
ya no need to get so angry...
2004 Redline 350z - Hawk HPS Brake Pads
Dasoupdude
05' Z ,03' Xterra,
west palm beach FL
3-17-2008
i have an 05 base and the only thing wrong with it, is the left tail light's condensation. Other than that its been perfect in every way.
You didn't eat your broccoli. and you didn't get in line with all the other kids. you never really cared about where you sat at the lunch table or which clique you were in then or what club you are in now you knew that the best way to live was by doing what you wanted not just what you were told. soon everyone else began to notice. you wanted to go your own way. and you did.
» Return to 350Z / 370Z Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
