I haven't looked in the engine section in a long time...
If you are an accomplished mechanic, you might consider rebuilding the VTCs if you are up to it.
There are 3 timing chains and two VTCs (front and rear). You would also need to replace the chain tensioners.
The parts, if you can find them (most dealers won't get them anymore) cost like $400.
here is the TSB -- a "how-to" if you will -- for rebuilding the VTCs.
http://maxima.theowensfamily.com/tsb/NTB95-022.pdf
If you go through some stickies and do searches on maxima.org, you can get a lot more info.
