sgetmanenko »
https://forums.nicoclub.com/sgetmanenko-u95284.html
Tue Apr 22, 2008 3:26 pm
01 sentra 2.0 se. One day hesitating while driving, gave an evap code. Later, won't cold start. AAA comes over, has me turn the engine over, he gets down bangs on the gas tank, the car starts. So, I think it's the fuel pump.
Replaced the pump. $130. Aferwards, same problem. It can stall randomly on a highway, it can stall while idling. Some times it won't cold start. Took to the dealership. They inspected for 2 hours. $170. They say oil in in the distributor cutting the spark. Replaced distributor $220. Replaced the Spark Plugs. $10. Same story... hesitates while running randomly, sometimes stalls. Pretty dangerous when on highway, embarrassing at a stop light.
Here's the most interesting part. Once it stalls, if you keep the ignition key turned on and do nothing but sit there and wait, you eventually hear the fuel pump hum, like it's rebuilding fuel pressure. Then you turn the key, starts every time. When I cold start I always turn the ignition all the way on without cranking, if I hear the fuel pump, it will start, if I don't it won't.
Any thoughts? By the way, since dealership has cleared all the codes, no new codes have come up and it has stalled out a number of times. HELP!!!
