C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Apr 19, 2008 10:39 pm
More gears generally does equate to better mileage if driven correctly. Less gears means each gear must have a much bigger range of operation for a given load. This tends to mean a motor will operate within a wider range of RPMs. Having more gears can narrow this range so that the engine's operation occurs more closely to the most optimal RPM (for fuel efficiency), which will likely reduce fuel consumption. It also allows a motor to have to rev less in each gear. As we have discussed in other threads, higher RPM tends to be one of the biggest contributors to fuel efficiency.
To put it another way, think of Continuously Variable Transmissions. They are in theory, the most fuel efficient transmissions. The more gears you have, the closer it gets to a CVT. If you have taken Calculus or worked with limits, think of x as the number of gears and what would happen if a limit was taken as x approaches infinity.
This same principle applies to acceleration as well. Only its operation will be more centric around the peak HP area of the motor. Shifting is quite fast in a modern automatics. So I doubt a couple of additional gears will make that much of a difference. Chances are, in a 1/4 mile, you might only experience one extra shift anyways.
