My 1993 J-30 has smoke coming from between steering column and steering wheel,smells like transistors burning and seems to be related to the turn signal, when the signal is off I can still hear the clicking sound but the signal is in the off position and the indicator lights are off. and it happens more often in the warmer weather, if anyone can tell me for sure what the problem is I will be eternally greatful
'99 Q45 134K Black&Tan / '96 Silverado 5.0 235K / '89 23' Irvette CC F351
virginia beach virginia
12-3-2007
« Re: J-30, smoke from between steering column (el2)
8:15 AM 4/16/2008
How long has it been doing that? The reason I ask is electrical shorts usually isolate themselves pretty quick and / or fail all together. Especially if things are hot enough to create odor and smoke. Possible, but hard to imagine a persistent electrical issue with smoke and fumes which has no other symptoms. Of course, this in the innernets and I can only guess from this azimuth and range.
Any possibility that your valve covers are slowly leaking and the smoke and odor are related to that? The turn signal issue may be something else entirely.
Just a SWAG.
Since purchase Dec 07: Front struts-mounts-springs & rubber, Tension Rods, Stbd Tie Rod End, Front Brakes & Shims, All Belts, Mondo 245 tires, Spark Plugs, RR Diff with M1, RR Brake Fluid with my three dollar gizmo, RR PS fluid, RR coolant, RR Blinker Fluid M1, B/G TrannyFlush w/M1 and super jizz, Tranny Cooler, Misc wrenching and what not, 118
« Re: J-30, smoke from between steering column (oldmako)
8:30 AM 4/16/2008
It has been happening off and on for about a year. The smoke is definitely coming from were the steering wheel joins the column, when it happens it can be seen, it looks like native American smoke signals, and as I said it only happens in conjunction with the sound of the signal indicator being heard for some time prior. It seems like the signal device is malfunctioning and after it builds up heat from constantly running it begins to smoke, that's my best guess based on the prevailing conditions. I've tried moving the lever slightly by hand to see if it would stop but that does nothing for it.
Time to take the covers off around the steering wheel and see what's smoking. I have never heard of this problem before, so it's certainly not typical.
Heath
1990 Infiniti Q45 - AKA "Q2" 2005 Infiniti G35 - Sedan A/T FOR SALE 1997 Nissan Truck - XE - 5 Speed M/T
4:12 PM 8/15/2008
Quote, originally posted by el2 »
This car should be in the shop immediately.
What are YOU going to do, wait until there are FLAMES?
