Discussion: ECU Tuning, Water/methanol injection, and VCT tuning on a VH45DET | First 1 2 > Last |
| Author |
Post |
qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
| Discussion: ECU Tuning, Water/methanol injection, and VCT tuning on a VH45DET | 10:26 PM 4/14/2008 |
Ok, I've been doing a bunch of tuning of my OEM ECU and would like to pick the brains of those of you that have experience or useful input regarding the subject. Overall, I feel I've done pretty well with my tuning so far. I have been able to get my AFR's where I want them and have been able to get the boost increased to the 7-8 PSI range with only a slight detonation issue.One area I'm still having issues is a slight detonation around 4K and 5K. I kept retarding the timing in several areas on my first tune and eventually I could tell I had lost a lot of power from taking out too much timing in too much of the timing map. I took what I learned and started fresh with my original tune and just added fuel and retarded timing where I knew I needed it. This tune is pretty good and restored a lot of power but I still have the slight detonation at 4k and about 4.8k rpm. AFR's are good in the 11.5-12.5 range depending on RPM/load. Best pump gas here is 91 octane. At WOT and max RPM (around 7K) I'm at about 82% duty cycle on the injectors at ~7 PSI boost. QUESTION: Do I just keep pulling timing in the last couple columns of the map in those RPM ranges until detonation is gone? I'm up to -7* and -8* under my starting map in the areas in question. Is it normal to have a small spot around 4k or wherever, that requires timing to be that much below the surrounding blocks? or do I... Leave it and install the water/methanol injection system I already plan to install? I originally was hoping to get a good tune without the water injection so I didn't have to rely on it but am I wasting my time? I'm pretty confident the water injection will eliminate the detonation and probably allow me to increase boost to a solid 8 psi, which is about as high as I want to go without modifying injectors, MAF, etc. or... Will modifying the VCT rpm on/off points do anything for me? Stock is 4600 rpm for on/off. The aggressive tunes Robert Bowen made for the "NICO ECU's" use 4200 rpm for on/off points. Does anyone know details of this system and benefits/drawbacks of adjusting the switch points high or lower? Anyone tried tuning it with success/failure that can share experience? If not, I might try lowering it to around 4k to see what it does. I wouldn't think it would harm anything, thoughts? Maybe it would help my detonation issue at 4k? Unfortunately I haven't found any information to tell me if it can help my tune or not. I'm sure there are beneficial adjustments that can me made to it, I just don't have any idea how.
1994 Q45 Turbo Current Upgrades/mods:Tuned ECU, Front strut stabilizer bar, 2004 350Z 17" wheels, 7.5" front +30mm offset 225/50, 8" rear +33mm offset 235/50, Stillen cross drilled rotors, Tokico Blues, California Customs Springs, Unitrax 4.08 Rear Diff, Master Power T70 Turbo Tial 50mm BOV, Tial Wastegate, methanol injection, Bose auxiliary input adapter, Much more on the way!
elwesso
Infiniti Super Mod
Online
94 Q45t, 1984 BMW 533i
Anderson and Angola IN
2-23-2003
| « Re: Discussion: ECU Tuning, Water/methanol injection, and VCT tu ... (qsiguy) | 7:18 AM 4/15/2008 |
shane there are some posts back in the day when the guy from florida (I cant remember his name, one of the first guys to put a VH in S13) and he did a bunch of tuning, playing with the VTC and such..I think its probably a fuel issue because I didnt think Siju was having these problems.. It still may not be a bad idea to install a rising rate FPR... I wonder whats actually happening.. That is around the peak torque and HP of the motor so of all places that would seem to make sense for detonation to occur.. Are you running lean in those areas? Id really like to see it run without methanol because I think it can be done, seems like going right to the methanol is sorta like taking the easy way out, just my opinion. I suppose just for grins you could move the VTC point, however when VTC is on it advances the duration of the valves and also increases overlap. Also take in mind that it only does the intake cam, so as I understand it all your doing is making the intake valve close later.. Overlap works great in N/A but not so well in turbo motors.. Take that as you will, im not sure if you'd want to make the VTC on sooner or later, or if it would make much difference at all.
The Infiniti Q45 Resource, Q45.org | Nissan VH series website NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Joe, say Wes sent you.Need a Nissan/Infiniti Mechanic around Indy OR Northern Indiana?? EMAIL ME!!!
Carl H
RB Moderator
1995 240SX SE
charlotte nc
8-4-2003
target 11.5-11.8:1 afrs not 12.5:1 if the best octane you have is 91. install the water injection system but use only a little methanol to aid in cooling, because you're running around in az heat on a non intercooled setup im sure your AIT's are thru the roof.
SHift_BOOM. Damnit. Doing an RB2X swap and scared of the wiring? Check out my thread in the RB section. Now offering VH and SR/KA/CA conversions!
sijoko
Black 1994 Infiniti Q45 Turbo, Silver 1995 Infiniti Q45t
USA
7-26-2002
My suggestion is to aim for 11.5 under full throttle and then spray water as the boost gets higher. I've got my car tuned for ~ 11.5 (between 11.2-11.8) under full throttle. My water injection kicks on at 4 psi. The base timing is set at 15 degrees. The car moves like you wouldn't believe for a 2 ton beast.
TURBO Q45
qsiguy
Phoenix AZ
3-20-2005
Above 3500-4k my AFR's are 12 or lower so I don't think it's a lean condition. Siju is using the OEM ECU with the FPR but he also is using water injection which is most likely preventing any detonation. Last I heard he was only running 6 PSI of boost. Mine is set for 7-8 currently. I'd like to get a MAP sensor so I can wire it to my wideband program and see the exact pressure and the AFR/RPM at the same time.Next question.... Should I just start with water or go right to the methanol injection? I don't believe I have a lean problem so really I think I just need to cool the intake charge. If I do have a lean problem that's easy to fix in the fuel map. BTW, already planning the IC, just need to find some money in the budget. There is also still a section of the charge pipe that needs to be wrapped to keep heat from one of the cats off it. Hey Siju, What octane fuel were you using? 91 or is 93 available in Oregon?
Modified by qsiguy at 1:33 PM 4/15/2008
sijoko
USA
7-26-2002
| « Re: (qsiguy) | 12:45 PM 4/15/2008 |
| Quote, originally posted by qsiguy » | | Above 3500-4k my AFR's are 12 or lower so I don't think it's a lean condition. Siju is using the OEM ECU with the FPR but he also is using water injection which is most likely preventing any detonation. Last I heard he was only running 6 PSI of boost. Mine is set for 7-8 currently. I'd like to get a MAP sensor so I can wire it to my wideband program and see the exact pressure and the AFR/RPM at the same time. Next question.... Should I just start with water or go right to the methanol injection? I don't believe I have a lean problem so really I think I just need to cool the intake charge. If I do have a lean problem that's easy to fix in the fuel map. BTW, already planning the IC, just need to find some money in the budget. There is also still a section of the charge pipe that needs to be wrapped to keep heat from one of the cats off it. Hey Siju, What octane fuel were you using? 91 or is 93 available in Oregon? Modified by qsiguy at 1:33 PM 4/15/2008
I tuned the car without water injection just to be on the safe side. The water injection is just there for insurance but the car didn't detonate without it. In Oregon, they have 93 octane which, up to last month, didn't have any ethanol but now the good times are over with ethanol in the fuel now. When I was in California, the car ran good under boost with the 91 octane but I was spraying water so that has a tremendous effect.
TURBO Q45
qsiguy
Phoenix AZ
3-20-2005
| « Re: (sijoko) | 12:50 PM 4/15/2008 |
| Quote, originally posted by sijoko » | | ......The car moves like you wouldn't believe for a 2 ton beast. |
I agree, it's a blast to drive and quite a rush. I need new rear tires, even with my OEM rear diff still (4.08 install pending) the rear tires will often break loose even up around 20-40 mph if I'm already moving. Took my wife out to dinner on our anniversary and she got a little nervous when I did a little demo for her. She hasn't really ridden in the car since it got the turbo. I think it was the "fish tailing" it was doing for about 30 yards that she didn't like. She was reaching for something to hang on to
I ran a 1/2 tank mix of 100 octane and 91 octane and it didn't detonate at 6 psi with everything stock, ECU, fuel pressure, etc. I'm sure at 91 octane the water injection is making all the difference.
rhinoone
Rocky Mtns
10-22-2007
| « Re: (qsiguy) | 6:09 PM 4/15/2008 |
Try to keep it simple!Water injection is a proven method that has been used for decades. Since you live in AZ I doubt you ever worry about freezing, but just the same tune your water injection for windshield wiper fluid. Its a good mix of alky & water, easy to find, and if you ever drive to a climate where freezing is a threat, you won't freeze the water and break things. Just keep a close eye on the fluid level
Modified by rhinoone at 10:42 AM 4/16/2008
qsiguy
Phoenix AZ
3-20-2005
Wiper fluid, the cheap basic stuff, is what I was planning to use. As long as you don't use the fancy fluid with cleaners in it, it works great. What I'd like to do is plumb the injector pump into the OEM wiper reservoir. An added feature is the low fluid level dash light  I was just looking at the other options at the hardware store tonight and to me it's a no brainer. The wiper fluid is premixed, cheap, and safer than some of the other chemicals, with the exception of water. Some of the other options were over $6 for a little can. You can get wiper fluid for < $2 gallon.
darinz
Online
Nissan Patrol
Whangarei
9-16-2006
| « Re: (qsiguy) | 10:55 PM 4/15/2008 |
I'm not switching the cams at all and the power curve is a straight line untill rev limit. I think my dyno graph is on here somewhere? Mine will break loss at about 80 ks (50mph) when over taking and doesn't get straight again untill about 130k (80ish). It is really funny watching the reaction of people when they see this off road truck go past them sideways!! Make me laugh but my wife doesn't appreciate it as much.
Nissan Patrol, VH45, Garrett T04z, PWR water to air intercooler, Extreme manual shift auto, etc
qsiguy
Phoenix AZ
3-20-2005
I think I've decided not to mess with the VCT, at least not yet. Your truck sounds like a lot of fun. I have your dyno chart hosted in my photobucket account. Here it is...375 whp
craigztoyz
90 300ZX VH45 95 J30 90 rx7 95 2500 4X4 suburban
Austin TX
1-18-2008
| « Re: (qsiguy) | 9:22 AM 4/16/2008 |
| Quote, originally posted by qsiguy » | | I think I've decided not to mess with the VCT, at least not yet. Your truck sounds like a lot of fun. I have your dyno chart hosted in my photobucket account. Here it is...375 whp
that is one nice climbing dyno there. Can you imagine that powerband w/ 5spd in Z32? tt right? Are you the guy on Propane?
qsiguy
Phoenix AZ
3-20-2005
He's running a single turbo and he normally runs avgas, I haven't heard of him using any propane.I pulled my pass. headlight out last night to work out a way to plumb my meth injection from that reservoir. I think I will just drill a hole in the filler neck and feed a 1/4" tube down into the washer reservoir. Thought about putting some sort of fitting on the bottom but I have a feeling I'd just be asking for leaks. It's so old it may just crack anyway. I think through the top is the way to go. Just need to set the pressure on my pressure switch, test the pump with the injector and the length of tube I'll need and if it all works get it installed. Should be pretty straight forward. I have a dual stage boost switch inside the car so I will be wiring it so that when it's on stage 2 and boost hits 4 psi the meth injection starts. Stage 1 boost is just the wastegate spriing which is 3.6 psi where I don't need the injection. I did also decide to richen up the AFR in the trouble area instead of pulling more timing to see if Wes was right. I haven't tested it yet. I'd like to see if I can get the AFR down to about 11.5 across the RPM scale at WOT especially when I hit 4-5 PSI which is around 2.7-3K rpm from a standing start. Already rolling it's lower, around 2.2-2.7K rpm. Started the meth injection install so testing this new tune will have to wait.
darinz
Online
Nissan Patrol
Whangarei
9-16-2006
| « Re: (craigztoyz) | 7:05 PM 4/16/2008 |
No propane but I do run avgas basically all the time. I've only run lower ie 95 plus octane booster, once and that was just to get home as the airport was closed.
Stinky
2-7-2006
| « Re: (qsiguy) | 8:12 AM 4/17/2008 |
Here's the VTC post that was mentioned earlier. http://forums.nicoclub.com/zerothread?id=194978 It would be interesting to see if the ideal switch over point changes with boost. If you can afford some time on a dyno that would be your best bet for getting a safe tune. Without a dyno it's really hard to tell if you have ideal timing or if you could possible back it off a bit to gain a bit of safety margin without sacrificing any measurable power. The same goes for the AFRs. If you can run it at 11:1 instead of 12:1 and still get about the same power then it's worth running the extra fuel just to keep things safe. Are you using Nistune?
qsiguy
Phoenix AZ
3-20-2005
I would have to assume the switch point would change under boost but who knows. Maybe we'll find out if I get some dyno tuning time. Not likely in the near future with my current budget.I'm currently using the wideband software that came with my Zeitronix WB sensor. For the consult stuff I use Nissan Data Scan and ECUTalk. I prefer ECUTalk for the logging but NDS provides some options ECUTalk doesn't. I should have the meth system installed in the next few days and then I can test my most recent tune. I backed off a bit more timing around 4k but mostly I lowered the AFR's in the last couple columns and more so in the 4-5K area. Hopefully that will do the trick w/o meth. Regardless I think I'll start tuning with the meth once it's installed and I test this current tune. EDIT: Interesting reading on the VCT but if I read it correctly those tests were done NA and not boosted. Is this correct? I saw he posted the stock timing map on another linked thread from the one above, any chance he posted his tuned maps anywhere? If anyone knows I'd love to see them.
Modified by qsiguy at 2:06 PM 4/17/2008
Stinky
2-7-2006
| « Re: (qsiguy) | 7:12 AM 4/19/2008 |
Yes, they were done NA. I dont think I ever posted the finished timing maps. If I remember correctly we added quite a bit of timing in the higher rpm areas. to help bring up a dip in power. I'll see if I can dig up the map but its been a while.
qsiguy
Phoenix AZ
3-20-2005
| « Re: (Stinky) | 2:11 PM 4/19/2008 |
Did you ever add boost or was it always NA?I got the methol injection done. I posted the details in the Q45 forum at this link http://forums.nicoclub.com/zerothread/331064 . It's made a huge difference. It got rid of the detonation I was having and I've even advanced the timing a bit where I had pulled it, still with no detonation. I've also increased boost to 8 PSI. I love it! Here are some images that shows the difference from my current tune vs. stock. The timing is just pulled from 3.6K to 4.8K rpm in the last 3 columns. No detonation noticed so far up to 80-90* ambient temps. The fuel map you can see I've just added fuel in the last two columns just about over the whole RPM scale. There is no picture but I also had to tweak the high gear fuel map a bit in the cruise rpm/load area to keep it in closed loop while cruising. Timing map difference from stock. You guys think I should advance more now that I have the meth injection?
 Fuel map difference from stock
qsiguy
Phoenix AZ
3-20-2005
I started another thread for the TP calculations specifically but it's highly relevant to this thread so I'm copying it over.I've been trying to calculate the TP #'s so I can plot the maps and here are the results of my number crunching. IF the formulas and numbers are correct this chart shows the potential detonation area (mostly the center of the orange). I had been pulling timing in the far right columns assuming thats where it was at. Seems to me the load would be higher at WOT and full boost. Anyone have any knowledge of this? I guess it wouldn't hurt to pull some timing in that area and check the results. According to these numbers you'd have to be on a pretty steep grade WOT and pulling hard to get to the right of the map...but I guess that makes sense now that I think about it. Flat ground acceleration wouldn't be that huge of a load compared to what the car can pull on a hill or something. Hmm.. This data is from a log of a 40-65mph pull in 2nd gear and I DID get detonation/knock ~4K rpm even with methanol. Also, if this load reference is correct I may need to retune my fuel as I was also changing those numbers in the last two columns as you can see above. I may just start from scratch again with a tune. Each time I do one I get a little better and learn a little more. [EDIT: These are NOT the right calculations!]
 Modified by qsiguy at 11:46 AM 4/22/2008
Modified by qsiguy at 4:20 PM 4/22/2008
qsiguy
Phoenix AZ
3-20-2005
| « Re: (qsiguy) | 3:19 PM 4/22/2008 |
Tried going back to stock timing and fuel, then adjusting in that calculated detonation area and tested during lunch.... Definitely NOT the right calculations! I lost my nice AFR. The TP is for sure on the right side of the maps if not all the way to the right side columns. Went back to previous bin and made more timing tweaks. I'll have to check out the next tune after work. I want my own dyno to tune on I'd be happy if I could figure out how to program Nissan Data Scan's map trace to work with my ECU. Need to find some technical support for it. Then I could tell where I was on the map.
Stinky
2-7-2006
| « Re: (qsiguy) | 8:26 PM 4/22/2008 |
Do yourself a huge favor and buy the Nistune software. It's indespensable when you're trying to tune especially to do live tuning on a dyno. The software pretty much pulls the tp directly from teh ecu and does a live map trace and logs.
qsiguy
Phoenix AZ
3-20-2005
Nissan Data Scan is supposed to be able to do map trace, I just need to figure out how to set it up.Nistune looks awesome but I don't see support for the VH45DE. Do you know if they support it or not?
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: (qsiguy) | 2:41 AM 4/23/2008 |
I remember looking at Nistune a while back and it didn't mention anything about the VH45. I just checked again and it does in fact mention it will work.
Stinky
2-7-2006
| « Re: (qsiguy) | 8:13 PM 4/23/2008 |
The Nistune software will work on the VH. In fact, I helped Matt get the address file setup so I could use it to tune the 450sx. The only issue is that you have to use an emulator because the stock rom is too small to hold the extra code that the Nistune hardware requires. It sounds like you already have an emulator and a consult adapter so all you need is the software. The nissan datascan maptrace works but completely sucks *** as far as usability. Nistune allows live tuning, live map trace, cell highliting, and plays back the trace when you play back the logs. The cell highlighting keeps all the cells that the ecu has used highlighted until you clear them. So you can do a pull and see exactly which cells the ecu used and know exactly which cells to change. Or if you're holding a load on teh dyno you can sit there and change your timing and watch the power output change in real time. It'll also make swapping injectors and mafs a lot easier if you decide to do that. Well worth the money.
qsiguy
Phoenix AZ
3-20-2005
Oh man, that sounds like an incredible tool. I have to figure out how to get that. Unfortunately I don't have an emulator. I've just been burning chips with my Moates Burn1 and swapping. Getting really old swapping chips. What emulator do you like? The Moates one has been out of stock for a while. I can probably find the original Moates Ostrich 1 on ebay or somewhere but is there one you like? I do have the consult USB cable that works great. I have several programs I've used with it but nothing like Nistune. [EDIT] Ok so I keep going back and reading information on the Nistune site. I'm trying to fully understand how it will work for my ECU. Since I have to use an emulator, I cannot use the Consult connector to tune, correct? If this is correct, does the Nistune software have realtime support if used with an emulator through the USB or Serial connection?
Modified by qsiguy at 3:57 AM 4/24/2008
Carl H
RB Moderator
1995 240SX SE
charlotte nc
8-4-2003
with nistune and the q45 ecu you'll have to plug in both the emulator and consult to the computer at once, it will maptrace thru consult and upload/update thru the emulator.
Stinky
2-7-2006
| « Re: (Carl H) | 10:29 AM 4/24/2008 |
Correct. The emulator takes care of changing the contents of the chip and consult takes care getting the live information from the ecu. Normally they would be independant of each other but Nistune brings them together in one piece of software. I use the Romulator with a Serial-> USB adapter with no problems. USB or serial consult should be fine. All you will need to do is tell Nistune the com port number for the device.
qsiguy
Phoenix AZ
3-20-2005
I confirmed with Nistune that for the VH45DE you would just need an emulator, like the Moates Ostrich 2, the Nistune software, and a consult cable. With these items you should have all the functionality of the software for real time tuning.With the help of deviousKA on the hybridka.com board I now have the correct addresses for map tracing with NDS! I still need to drive it to verify the numbers look good but in park revving it looks good. This is for the VH45DE pre '94 8-bit ECU's. The '94 and up ECU's are 16-bit and I don't know if these will be the same for that one. Primary Timing (No Knock) RPM MSB 140B, Map Address F800 RPM LSB 140C, TP Scale Address FB10 TP MSB 148C, RPM Scale Address FB20 Primary Fuel (No Knock) RPM MSB 140B, Map Address FD00 RPM LSB 140C, TP Scale Address FAF0 TP MSB 148C, RPM Scale Address FB00 These numbers are are actually the same as the VG30DETT except for the RPM MSB and LSB.
Carl H
RB Moderator
1995 240SX SE
charlotte nc
8-4-2003
i was about to say...it looked a helluvalot like the rb20 addresses...
qsiguy
Phoenix AZ
3-20-2005
Map trace is freakin awesome! Did my first test drive with map trace on and now I know more than ever what needs to be done. My troublesome detonation has always been at 4-5K rpm. Turns out I'm maxing my TP scale right at 4k every time I go WOT. Current TP scale goes up to 72 and my TP hits in the 90's and even 100 +/- momentarily.So next thing to do is extend my TP scales and then I can get this baby tuned properly! You can't imagine how relieved I am getting map trace working. Awesome! I made a little video of the map trace working, I'll post it in a bit.
qsiguy
Phoenix AZ
3-20-2005
I found some info in the consult data register so I labeled the Consult register data table for the VH45DE. Thought this might prove useful for some.
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
| « Re: (qsiguy) | 11:20 PM 4/28/2008 |
Nice!!!!
qsiguy
Phoenix AZ
3-20-2005
Here is a short demo video of my Map trace. As you can see my TP goes up to ~100 and the TP Scales only go up to 72. The ECU keeps the same values for every load area above 72. I am going to expand the TP Scales to 128 and the RPM scales to 7200 RPM. That should allow me to perform some precise tuning with a little head room for a tad more boost.
qsiguy
Phoenix AZ
3-20-2005
Here is a screenshot. Now that I see this I know that nearly all of the changes I did to the fuel and timing maps were pointless. The TP isn't even hitting most of those spots on the map at WOT.
qsiguy
Phoenix AZ
3-20-2005
| « Re: (qsiguy) | 1:44 AM 4/29/2008 |
I got the RPM and TP scales expanded. Too late to go for a ride now but I'll give her a road test tomorrow. I did burn the new chip and idled it in the garage for a bit and it still started, which is a good sign! I have a screenshot of the new expanded map trace map but you'll have to wait to see it, Photobucket is down for maintenance at the moment. Tomorrow I'll have a new expanded video for you to check out.I'm so excited to be making this progress now, it's like Christmas!
John Dixon
300ZX-TT Z32
Birmingham UK
11-16-2004
Good s |
