S13xCrazy
1993 240sx Vert/1986 Nissan D21 4x4
Dousman WI
10-8-2006
| « Re: New member and new vert =] (Nategreat923) | 7:28 PM 4/14/2008 |
Looks great! Have fun with her and be safe! I can see you are new to driving, so don't let your lead foot get the best of you!
 Check out our Nissan diagnostic cables! Get your ECU Tune chip! Tuned to your modifications!**NOTE: Some vehicles need daughterboards. 93 240 vert project - GT28 turbo, FMIC, SSQV bov, 370cc injectors, meth injection, much much more.
white90esex
2 SRed S13s
Ft C CO
12-25-2005
| « Re: New member and new vert =] (S13xCrazy) | 7:33 PM 4/14/2008 |
nice. Im jelous
 04' Titan | 90' 240sx DD | 90' 240sx project car | 06' Xb Lil pimpin
Nategreat923
1992 240sx "Sil-Vert"
Snohomish Washington
4-1-2008
| « Re: New member and new vert =] (S13xCrazy) | 7:38 PM 4/14/2008 |
thanks a lot. I definetly wont let the lead foot get the best of me with this car, because verts are so rare and this is too special to demolish or beat on. I do have a question though. I have an auto as you can see, and after driving for a while when I stop (at a light or stop sign) it starts to idle really rough and it even died once. I was told that the strainer in the transmission needs to be cleaned, is this true? thanks in advance
red_vert
1994 240sx vert
winter park florida
2-24-2008
sweet car! pics and everything nice.!
 -89 hatch red *track/show* s13.5 autech -89 hatch flat black *sold* -92 coupe totaled. red light runner. -94 vert *under construction*
jspec603
Online
manchester nh
10-24-2006
Nice ride! Good to see yet another vert around here.
 myspace.com/SlidewayzS13 myspace.com/ballisticmotorsportsllc Check out Project Jspec603 Vert build, but only if your cool enough... MEET JULY 26TH BE THERE
S13xCrazy
Dousman WI
10-8-2006
| « Re: New member and new vert =] (Nategreat923) | 9:05 PM 4/14/2008 |
| Quote, originally posted by Nategreat923 » | | thanks a lot. I definetly wont let the lead foot get the best of me with this car, because verts are so rare and this is too special to demolish or beat on. I do have a question though. I have an auto as you can see, and after driving for a while when I stop (at a light or stop sign) it starts to idle really rough and it even died once. I was told that the strainer in the transmission needs to be cleaned, is this true? thanks in advance |
I find this very hard to believe. I would look at other things first. I had a similar issue with my Coupe. Do the RPM's drop at all (anywhere below 800 or so?) and then want to bog down and off? Or is this happening at a higher RPM? What happened in my coupe was that I would come to a stop and my rpm's would drop low enough to where the car would want to turn off. As a quick fix, I adjusted the idle just a little bit higher and I never had the problem again. Hope this helps
Nategreat923
4-1-2008
| « Re: New member and new vert =] (S13xCrazy) | 9:15 PM 4/14/2008 |
| Quote, originally posted by S13xCrazy » | I find this very hard to believe. I would look at other things first. I had a similar issue with my Coupe. Do the RPM's drop at all (anywhere below 800 or so?) and then want to bog down and off? Or is this happening at a higher RPM? What happened in my coupe was that I would come to a stop and my rpm's would drop low enough to where the car would want to turn off. As a quick fix, I adjusted the idle just a little bit higher and I never had the problem again. Hope this helps |
it happens at a stop and it drops below 800 far enough for it to actually die. Im taking it into a transmission shop for a free diagnosis
Loki
Lucky to be Alive
1994 Nissan 240SX Convertible --- 1993 240SX Vert RIP
Scranton PA
10-15-2006
| « Re: New member and new vert =] (Nategreat923) | 9:17 PM 4/14/2008 |
Good to see another Silvert in the NICO family. Welcome and enjoy your stay
NICOCLUB - Ranked highest in user satisfaction by DJButton and Associates.
-RJ-
S13 Convertible
VA Beach VA
8-9-2006
lucky lucky kid it has the silvia front already lolwelcome
 AIM: daruebenwhocould http://www.myspace.com/c0mpr3ssi0n http://www.rjmarket.com MODS: Engine rebuild, 5 Speed swap, 5 Lug conversion, J30 brakes, Megan Coilovers Next on the list: Godspeed Sway Bars and Megan End Links
Nategreat923
4-1-2008
| « Re: (-RJ-) | 10:53 PM 4/14/2008 |
thanks a ton for all the comments!
Bryant0086
1989 Nissan pickup 2004 Nissan Quest SE 1992 240SX vert
Opelika Al
2-11-2008
| « Re: (Nategreat923) | 6:13 AM 4/15/2008 |
Super clean vert !! Good luck getting the idle problem repaired. It doesn't sound like anything serious though. Bryant
Topless_92
92 Nissan 240sx Convertible
Hagerstown Maryland
5-3-2007
| « Re: (Nategreat923) | 6:14 AM 4/15/2008 |
Nice vert. Welcome to NICO
DeXteR
Picture Police
93 sil40 vert- RIP 93 240sx vert- 94 pathfinder se v-6 4x4
Hemlock MI
9-26-2005
| « Re: (Topless_92) | 7:48 AM 4/15/2008 |
I'm going to go out on a limb here and say that your idle problem is not at all related to the transmission whatsoever.You've got some vacuum or fuel related issue going on. You should check to make sure all your vacuum lines are hooked up. Does the car run rich when this happens? Anyways, welcome aboard. That's a nice looking vert you've got there. Thanks for not making me bust your balls for pictures.
 TCEvolution.com - Has your car evolved yet?
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: New member and new vert =] (Nategreat923) | 8:41 AM 4/15/2008 |
| Quote, originally posted by Nategreat923 » | it happens at a stop and it drops below 800 far enough for it to actually die. Im taking it into a transmission shop for a free diagnosis |
When you're looking at the engine on the left side right next to the fan, you will see a little hose from intake pipe going under the intake manifold. Disconnect it, spray half can of carb cleaner in there and start the car. It should clean up IACV and see what happens. Also search IACV(Idle Air Control Valve) on nico and read some threads. And, like dexter said transmission has nothing to do with this.
jamesblonde82
1992 Nissan 240sx convertible RIP 5/10/07 1993 Nissan 240sx convertible
jacksonville FL
3-20-2006
actually guys, on the auto, the torque converter can go bad in many ways and could cause it to pull on the engine hard after it warms up. so saying it's def not the transmission could make him overlook something. nategreat... do you notice that the torque converter locks after it shifts into 4th on the highway? does it lock really rough, or not lock at all? these could also be signs that tell you theres something wrong with that. but check the simpler things first like dex and 94 said. if its your TC (torque converter) then you gotta lower the trans and replace it. perfect time to go with a 5sp swap
onosqv
Q to the V
'92 240sx Vert & '91 300zx TT
bewbews.com
8-7-2002
| « Re: New member and new vert =] (Nategreat923) | 2:04 PM 4/15/2008 |
| Quote, originally posted by Nategreat923 » | And soon to come! (yes I have the rears too haha)
Those ARE the rears buddy . Clean lookin vert, me likes!
bew bews
Nategreat923
4-1-2008
| « Re: New member and new vert =] (brokeAs240sx) | 10:38 PM 4/15/2008 |
thanks for all the suggestions, im gunna check them out pretty soon when the rain stops.and about the wrong suspention pic, sorry Photobucket confused me, i took the wrong link and thought it was the rears
Kristine
I want a 240sx!
Virginia Beach VA
10-19-2007
| « Re: New member and new vert =] (Nategreat923) | 8:41 AM 4/18/2008 |
wow... I'm so jealous! you have the silvia front.
 myspace.com/kristine_may
Nategreat923
4-1-2008
| « Re: New member and new vert =] (Nategreat923) | 9:27 PM 4/18/2008 |
thought Id share this with you. Last friday weather was 80 degrees and sun shine. Today...
Influenced
Plano TX
4-18-2008
| « Re: New member and new vert =] (Nategreat923) | 10:25 PM 4/18/2008 |
s13 front end looks great!
Kristine
I want a 240sx!
Virginia Beach VA
10-19-2007
| « Re: New member and new vert =] (Nategreat923) | 6:02 AM 4/19/2008 |
mmm you should consider a 5 speed swap and a 5 lug conversion
Nategreat923
4-1-2008
| « Re: New member and new vert =] (Kristine) | 2:21 PM 4/19/2008 |
well Im debating a) keeping this stock while getting a beater hatch to drift b) silvia front clip and swapping the SR in with the RHD swap or c) 5 speed swap with a KA24DE-T
YOUNG240SX
93 vert
brooklyn...im moving to somewhere i just idk NY
3-15-2006
| « Re: (-RJ-) | 6:27 PM 4/19/2008 |
| Quote, originally posted by -RJ- » | | lucky lucky kid it has the silvia front already lol welcome |  very nice silvia front looks great
1-90 (s13) hatch base model=de swaped 5speed 2-93 (s13) vert=5speed,rsr spring and gab shocks
B-Boy DuB-L
1993 Nissan 240sx fastback se
Old Bridge New Jersey
3-1-2007
| « Re: (YOUNG240SX) | 9:54 PM 4/19/2008 |
It could be a fuel injector. HAHA i actually just replaced one of mine because the same thing was happening. wen i would stop it would idle rough sometimes stall or felt like it was about to stall. You could check it wit a multimeter, check ohms on injector so be between 9 and 14 i believe, and then use a noid light to check if it is getting any electrical current to the injector. It may be one bad cylinder,sumtin wit compression, U may have a vacuum leak, or may just need to adjust the idle. Good luck finding wuts wrong and fixing it. BTW if your wondering i changed the injector today and WOW wut a ****ing difference!!!!
Kristine
I want a 240sx!
Virginia Beach VA
10-19-2007
| « Re: New member and new vert =] (Nategreat923) | 10:39 AM 4/20/2008 |
| Quote, originally posted by Nategreat923 » | | well Im debating a) keeping this stock while getting a beater hatch to drift b) silvia front clip and swapping the SR in with the RHD swap or c) 5 speed swap with a KA24DE-T |
C) 5 speed swap with the KA-T! ... and a roll cage hehe, that's just my opinion.
Nategreat923
4-1-2008
| « Re: New member and new vert =] (Kristine) | 6:44 PM 5/12/2008 |
| Quote, originally posted by Kristine » | C) 5 speed swap with the KA-T! ... and a roll cage hehe, that's just my opinion. |
alright so i decided to go KA-T, so here are the parts waiting to be put on the vert
ishkabibble
1993 NX Coupe
DC
11-5-2006
| « Re: New member and new vert =] (Nategreat923) | 8:14 PM 5/12/2008 |
Did you fix your rough idle?
The only way to be liked by everybody is to say nothing of consequence.
Nategreat923
4-1-2008
| « Re: New member and new vert =] (ishkabibble) | 8:31 PM 5/12/2008 |
haha no, i wish, but we think its the injectors, so when we turbo it im gunna buy stock SR20 370cc injectors and hope/ pray that it fixes it. And I just picked that TD04 up today for 50$
ishkabibble
1993 NX Coupe
DC
11-5-2006
Did you check/clean the IACV?
sprintman
1992 240sx coupe 5 speed
Cape Girardeau Mo
10-21-2006
| « Re: (ishkabibble) | 12:44 PM 5/13/2008 |
What about ur coolant temp. sensor?
BigMACKenzie
1993 240sx convertible
Rockville MD
5-5-2008
| « Re: (sprintman) | 2:37 PM 5/13/2008 |
Nice car, very clean (twins lol) But i got to ask, wtf are you planning to do with that turbo and springs/dampers etc if you cant get a rough idle to go away? As someone who has tried modding an effed up car I highly recommend against it. How are you going to know if the part you just put in is not working or if previous problems are jacking it up? there are so many ppl here in the forums that can help you with mechanical problems (most of them very much smarter ad more knowledgable than me) just rememeber SEARCH FIRST THEN NEW THREAD! and do like me and get a car cover and get that lady out of teh snow! she is far to classy to be left out on the street corner liek some trollop on 42nd street! enjoy the hot ride and welcome ^^
 http://www.gtplanet.net/forum/...60584 Next mod(s): Suspension Bits! "I hear some people are suing Nissan for facilitating me handing them their @$$ at the stoplight." -TMS If nissans racing division is Nismo, what does that make Honda s...Homo? [IMG][/IMG]
jrm_29720
92 240 Convertible
charlotte NC
12-22-2007
| « Re: (red_vert) | 9:54 PM 5/13/2008 |
While sitting at the light, if just before it dies you push it up into neutral what happens? My limited experience would say if it catches back and does not die as in smooths out I would look more drivetrain but if it stutters on I would think vacuum/intake gasket. Does this happens only in gear and is smooth when you go to park or neutral? Just my two cents worth, nice vert.
Nategreat923
4-1-2008
| « Re: (BigMACKenzie) | 4:17 PM 5/17/2008 |
| Quote, originally posted by BigMACKenzie » | | Nice car, very clean (twins lol) But i got to ask, wtf are you planning to do with that turbo and springs/dampers etc if you cant get a rough idle to go away? As someone who has tried modding an effed up car I highly recommend against it. How are you going to know if the part you just put in is not working or if previous problems are jacking it up? there are so many ppl here in the forums that can help you with mechanical problems (most of them very much smarter ad more knowledgable than me) just rememeber SEARCH FIRST THEN NEW THREAD! and do like me and get a car cover and get that lady out of teh snow! she is far to classy to be left out on the street corner liek some trollop on 42nd street! enjoy the hot ride and welcome ^^ |
Because all together on all the parts ive spent 75$ (brake pads were needed because mine were worn ouy). the parts were from my bestfriends who moved up to bigger parts. so i know how good the parts are. and im in the process of moving to a house with a huge garage so it will be outta the weather | Quote, originally posted by jrm_29720 » | | While sitting at the light, if just before it dies you push it up into neutral what happens? My limited experience would say if it catches back and does not die as in smooths out I would look more drivetrain but if it stutters on I would think vacuum/intake gasket. Does this happens only in gear and is smooth when you go to park or neutral? Just my two cents worth, nice vert. |
you are right, and im not sure if i mentioned before, when it almost dies i stick it in neutral and it runs fine, thats why i was thinking it was drivetrain, it also does the same thing in reverse (the rough idle).
BigMACKenzie
Rockville MD
5-5-2008
| « Re: New member and new vert =] (Nategreat923) | 7:02 PM 5/17/2008 |
Free parts? I'm jealous
