How Can I Hookup An Aftermarket Amp To The Stock Setup?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Alegre323
i have no idea how to do this. is there an install instuction link I can get?
Alegre323
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Not a clue, sorry for the delayed response. I doubt it would work well anyway. Sorry I don't have more info for you.
opilla36
Car: 05' Infiniti Qx
You get a high low converter and plug into the negative and positive from the stock amp. The high low converter has RCA connection coming out the opposite end. Connect RCA's to aftermarket amp and to the high low converter. Easy as that. Then just connect amp to battery and ground and you have an amp with subs. Thats the way i have my set-up done. 1000\1 JL Amp w/ 2 10" W6 enclosed. Sets off car alarms!
Alegre323
opilla36 wrote:You get a high low converter and plug into the negative and positive from the stock amp. The high low converter has RCA connection coming out the opposite end. Connect RCA's to aftermarket amp and to the high low converter. Easy as that. Then just connect amp to battery and ground and you have an amp with subs. Thats the way i have my set-up done. 1000\1 JL Amp w/ 2 10" W6 enclosed. Sets off car alarms!
sweet where is the stock amp located?
opilla36
Alegre323 wrote:.
Its Under the driver seat. Easy to access from the back seat.
Alegre323
opilla36, i did what you said and when i turn it up the amp turns off and comes right back on!
i have the JL 1000/1 monoblock with 2 W6 V2's
enclosed box..
did you add any thing else? im going to add a yellowtop optima bettery tomorrow with a power canister
LMK!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
