Felipe
abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
San Gabriel S.Cal
7-3-2005
| « Re: Video: Nasty head noise (andromeda) | 5:20 PM 4/8/2008 |
kinda has that sound like it needs oil.
Foremerly: drifters2it_sideways
andromeda
91 240sx SR20
crossville tn
1-3-2008
| « Re: Video: Nasty head noise (Felipe) | 5:33 PM 4/8/2008 |
that could be possible. I think it may have leaked a little. I havent been driving it really except around the block maybe a few times. But one of the turbo oil lines leaks a little. so that could be the problem. Im gonna change the oil before i drive it again and see if that helps. i gotta get some new oil lines as well!
a work in progress
  other car for sale six four impala http://www.mautofied.com/listing-100083509.htm
S13xCrazy
1993 240sx Vert/1986 Nissan D21 4x4
Dousman WI
10-8-2006
| « Re: Video: Nasty head noise (andromeda) | 5:42 PM 4/8/2008 |
| Quote, originally posted by andromeda » | | that could be possible. I think it may have leaked a little. I havent been driving it really except around the block maybe a few times. But one of the turbo oil lines leaks a little. so that could be the problem. Im gonna change the oil before i drive it again and see if that helps. i gotta get some new oil lines as well! |
 Check out our Nissan diagnostic cables! Get your ECU Tune chip! Tuned to your modifications!**NOTE: Some vehicles need daughterboards. 93 240 vert project - GT28 turbo, FMIC, SSQV bov, 370cc injectors, meth injection, much much more.
2lua
1-19-2005
| « Re: Video: Nasty head noise (S13xCrazy) | 5:50 PM 4/8/2008 |
Did you bleeded the Hydraulic lash adjuster????
andromeda
91 240sx SR20
crossville tn
1-3-2008
| « Re: Video: Nasty head noise (S13xCrazy) | 5:51 PM 4/8/2008 |
when i say leak i mean like maybe 1/5 of a quart haha. TOPS. Dont worry ive maybe driven it a mile. and the dipstick still reads in the normal range. I just know it leaks a little.
a work in progress
andromeda
91 240sx SR20
crossville tn
1-3-2008
| « Re: Video: Nasty head noise (2lua) | 5:52 PM 4/8/2008 |
i didnt put the motor together myself. but i bet the guy who did, did not do that
a work in progress
2lua
1-19-2005
| « Re: Video: Nasty head noise (andromeda) | 6:00 PM 4/8/2008 |
If he did not bleeded all the air out of the Hydraulic lash adjusters, then it will make noises like that. you might have to get back in there and rebleed them adjuster... GL
urcaptnspeaking
1990 240sx
Washington WV
12-9-2007
| « Re: Video: Nasty head noise (andromeda) | 6:32 PM 4/8/2008 |
yeah i second what was said above. Whats you oil pressure on start up and after 15 mins of running. A lot of motors in time... "knock" on start up and for a minute then its settles.....its moe than likely something with it not getting oil. Check the whole "oil flow related" systems
Project Milk MoneyKAE Motor and Tranny FOR SALE http://forums.nicoclub.com/zer...52947 http://www.myspace.com/loganakazeus Build Thread: http://forums.nicoclub.com/zerothread?id=327738 DIY Hatch Repair: http://forums.nicoclub.com/zer...id=44
andromeda
91 240sx SR20
crossville tn
1-3-2008
| « Re: Video: Nasty head noise (urcaptnspeaking) | 6:25 AM 4/9/2008 |
ok thanks guys ill bleed them and fix the oil lines and go from there, also been emailing idahotuner, hes a really nice dude and said to double check the position of the cams. I think his were a couple teeth off and it made a huge difference. So ive got my checklist of things to do.
a work in progress
HurryupandrunS13
1992 240 fastback
Asheville NC
2-19-2007
| « Re: Video: Nasty head noise (andromeda) | 9:07 AM 5/10/2008 |
Sit em in a jar of oil for a day or two, they'll bleed themselves. That also sounds like it could be a bad timing chain tensioner. Can't tell from the vid, it seems valvetrain related and those lifters will be loud if they aren't bled.
OutToWinPAHC
1991 240sx Hatch with LS6 V8, TH350 Trans
Philadelphia PA
5-31-2007
| « Re: Video: Nasty head noise (andromeda) | 10:20 AM 5/10/2008 |
Yeah shes sounds low on the lubrication. But from experience I had a motor rebuild and the crank was out of round by a few thousandths and it did the same thing. I ended up needing to rebuild the bottom again, with a new crank. At first it almost sounds like a wrist pin. But check the oiling first before you get worried. New oil pump? The most important thing is not to run it until its better,
 Http://www.myspace.com/kevoshardcore Me Http://www.myspace.com/LS6240SX The Car Http://www.cardomain.com/ride/2643446 Car Domain 2002 F-Body LS6, Port / Polished 243 heads with Patriot Racing dual gold springs, Magic Stick V.3 Cam 237/242 .603/.609 112LSA, 1.7:1 Rockers, TR 7.40 Hardened pushrods, LS7 lifters, Ported LS6 oil pump, Comp Cams timing gear / chain, 42# injectors, Fast 90mm TB, Fast TB coming soon.More power then a C6 Z06 , in a S13.5
andromeda
91 240sx SR20
crossville tn
1-3-2008
| « Re: Video: Nasty head noise (OutToWinPAHC) | 2:45 PM 5/10/2008 |
ya ive been so busy lately i havent had time to work on it. but it does have a new bottom end including crank so hopefully thats not the case. i should have some time to work on it shortly so i will post back if the lifters were the problem. thanks for the suggestions though guys
a work in progress
i4jdm
1995 240sx (s14)
mt shasta ca
6-4-2008
| « Re: Video: Nasty head noise (andromeda) | 8:52 AM 6/12/2008 |
hey my ka is making the same noise i think yours is making. it sounds like a ticking sound or something along those lines right? anyways if i is the lifters it would be a minor problem right?
