z1 zonly wrote:Yeah T45, I was pondering the best way to go about that. I'd like to weld a bung in for the dipstick tube, if at all possible. That way the oil could be checked easily on flat surfaces.
The next big question is, how do I figure out the capacity?
To check capacity, when doing a leak test on the pan- use an old oil quart container, and see how many times you have to fill it, to get the oil level an inch or so below the flange. Looks like it wont hold alot, but am curious.
Can you give me some insight into some dimensions please? depth of sump front to back, and height from flange mounting to clear rack, and also to clear xmember. Thanx alot, n great work
