 280z transmission
bigred240sx
91 240sx fb w/ super hicas... 1976 280z
brandon ms
2-24-2007
  280z transmission
well i recently got my 280 as some of you may know. i heard somewhere that a 240sx transmission will work on the l28 in the 280. im just trying to figure out if its true and if it is what year transmission.
evildky
Classic Z Moderator
71 240ZT, 87 300ZXT, 91 300ZXTT, 93 SE-R
Louisville KY
1-31-2004
yup, all 240sx trannies can be used, you gotta modify and reuse the front case and countershaft bearing from the L trans, you might want to search I've done it and it's been discussed, if you can't find it I'll dig around
"if I had all the money I ever spent on cars........I'd spend it all on cars"
12.378 in a rusty datsun with a sliping clutch
"The Rusty Mistress" 299.3 whp and 305 lbft TQ, 2105 lbs
I'm cleaning out my garage, lots fo Z parts, S30, Z31 and Z32 here is my ebay listing
http://motors.search.ebay.com/_W0QQsassZevildky
if you're looking for something shoot me an e-mail, evildky@bellsouth.net
bigred240sx
brandon ms
2-24-2007
 « Re: (evildky)
i looked but couldnt seem to find it
and one guy who talked about doing it posted it up on another website, but i cant veiw it because im not a member
evildky
Classic Z Moderator
Louisville KY
1-31-2004
I did the writeup, and poste din on Hybridz.org years ago, not a sticky just in a regualr post as I had a hard time finding the info back when I did it, so here si the rundown:
you need, a 5 speed trans from any 240sx, any year, even the 84-86 300ZX N/a trans as well as I believe several other less popular applications fo the same transmission, you'll also need a datsun, L series transmission, any 71.5-83 is find with the exception of the 82-83 280ZX Turbo T5, anyhow...
you take the front case off both transmissions, it's pretty simple, you'll see the bolts holding the 2 halves together in the middle of the transmission, there are also some bolts in the bellhousing area that hold the cover over the mainshaft bearing and selector shafts, there si also a large snap ring here you'll have to pull, you'll need to take the front case, and countershaft bearing from each trans and swap them.......
to put the front case from the L series trans on you'll have to overbore the 5th/reverse selector shaft hole, you'll know which one as it's smaller and won't allow the selector shaft of the new trans to go in, some peoplehave had to do some clearancing on the inside of the case, mine fit without issue but if you do a dry fit and try rotating it if you feel drag pull it apart and grind that area......
seal up the 2 halves with RTV, as well as the endcap in the bellhousing area, your exhisting clutch and flywheel To bearing etc all remain unchanged but any 70-83 flywheel and clutch combo will work........
bolt the transmission back in, the trans wil lean to the passanger side a few degrees nto a big deal, you'll need to cut your trans crossmsmber into sections, reposition the sections weld them back together and brace up the seams, you'll need to have a new driveshft made using the slip yoke form the 240sx and the rest fo your old driveshaft to the length needed depending on your diff setup
it's not a bad as it sounds if you have some basic fab skills, if you can find an 82-83 280ZX Turbo 5 sped it's easier and a stronger trans, the Z31 guys are wrong about which trans is stronger
bigred240sx
brandon ms
2-24-2007
 « Re: (evildky)
thanks a million i have all things needed for it even the 240sx transmission just gotta build it or at least change the synchros
redhat-z
Louisville KY
7-5-2005
 « Re: (evildky)
Dave, you should sticky this thread. Yea, I know.
98 GMC Yukon - Daily Beater
90 240sx - Getting motor from Q
93 Sentra SE-R - 207,000 - Had to go.
93 Q45 - Motor going in 240sx
95 Pathfinder - Wife's daily beater
77 280z - Standing vertically in storage
Pharaohabq
92' Nissan 300ZX NA
ABQ NM
4-14-2008
 « Re: (evildky)
So Why would you want to Swap out the tranny? Is the original 280Z tranny very weak when it comes to increasing engine power (adding a turbo et al)????
Phar
evildky
Classic Z Moderator
Louisville KY
1-31-2004
nice avitar steve
the vast majority of S30's came with 4 speeds, so a 5 speed makes the car a lot less annoying at interstate speeds as it adds overdrive, the 77-78 had the option of a 5 speed but they are rare and if you put the power to them they break, they just kinda added an overdrive to the stock trans and they did a poor job of it
Pharaohabq
92' Nissan 300ZX NA
ABQ NM
4-14-2008
 « Re: (evildky)
Ahh, okay, That explains it, Both the S30's I've had had the 5speed tranny already. I'd kinda assumed it was standard equip. My old one was a 2+2 n my "new" project has one and it feels pretty good, though I haven't actually driven it yet. Probably I'll keep it tille I experience an "Upgrade Opportunity."
Phar
sdzxdriver
1982 280zx
So Cal Ca
7-30-2005
 « Re: (Pharaohabq)
It's also nice that in case something with the transmission goes south, you won't have to worry about there not being a parts car at the junkyard. It's getting hard to find Zs in the yard now.
reggiegsd
'94 Q, '73 240Z
Tampa, FL / Flemington, NJ
7-23-2002
 « Re: (sdzxdriver)
Quote, originally posted by sdzxdriver »
Look for a rusted '82 or '83 ZX with a good drive train. The entire drive train and a few other bits will swap into a your 280Z. Unless you are building a turbo motor or an outrageous NA motor the Z tranny will hold up. This is the best L-series motor and tranny and they will directly swap into you 280 with virtually no modification. A nice "Bull Frog" cam (Do they still exist?) and a clean 2.5 inch exhaust and you will have an honest 210 HP.
Reggiegsd
"If you ain't cheetin', you ain't tryin' hard enough."
» Return to Classic Z Forum
Powered by ZeroForum 2.1.1c. ©2008 RelyNet, Inc.
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
