 Removing/Installing RB head
240slidekat
240sx, b15 specv
oxnard, so kali 805 ca
12-20-2004
can someone give me a quick run through on removing and installing an RB25 head. i was going through the manual and its kinda confusing and i also heard that theirs different angles when you torque or something???
RB25DET Rebuilding process...Turbonetics T72 turbo, CP pistons, Eagle Rods, N1 Pumps, Aem EMS, etc etc...
Shocker
Youngstown Ohio
8-1-2004
 « Re: Removing/Installing RB head (240slidekat)
remove the timing belt, take off the cam gears, you can pull the cams if you'd like to keep the valves in the head so you dont bend them on accident...
Then remove the 3 holder bolts, theres 1 up front by the intake, and 2 in the far back they have 10mm heads.
Start at the front side or back of the head doesn't matter, do the last row, then the first, then second to last, then the second to first set... and so forth, go back and forth. Then remove the head...
Install is the reverse procedure of this, you need to make sure you re face the head, and if your using a metal HG I suggest the block to. Look at some of the head gasket threads for more info.
thats just a brief summary and how I do it. If your leaving the cams in make sure your TDC so you can access the head bolts.
RETIRED NRRB Since 3-17-08
RETURNED to the NRRB 8-9-08
Darius
'97 240SX SE
Ames Iowa
3-2-2003
 « Re: Removing/Installing RB head (Shocker)
DO NOT reinstall the cams with the motor at TDC! Rotate the crank ccw from TDC until all the pistons are about equally recessed in their bores. That way the valves won't get bent when the cam shafts are reinstalled (I don't know of anyone who has personally done this<cough> , but um, I have heard of it happening to someone ). The reason being the cams can only be installed in a certain position or they won't lie straight. Once the cams are in, you can rotate them to the TDC position and then SLOWLY AND CAREFULLY rotate the crank cw to TDC to line up the marks for the timing belt installation. If you feel any resistance, stop and evaluate.
Former Vice President of the NRRBA - Non-Running RB Association
Join today! Temporary and Lifetime memberships available.
Coolwhip
NICO Sponsor
Orlando Florida
2-6-2004
 « Re: Removing/Installing RB head (Darius)
Rub it in time?
As well. If you have ARP head studs currently installed, I suggest removing them before trying to slide that heavy head off of them straight. It's a royal PITA with them installed.
Treasurer of the NRRBA - Non-Running RB Association
Join today! Temporary and Lifetime memberships available. Send your dues to me.
"Parts for a complete and balanced engine"
Shocker
Youngstown Ohio
8-1-2004
 « Re: Removing/Installing RB head (Coolwhip)
lol Matt, well if you keep the cam dowels 15 degrees above horizontal like the picture shows it works perfect, you just need to really watch the #6 cylinder and what that lobe is doing... the cams want to twist their own way while being tightened. So I slowly cap them and rotate them with my wrench to the proper position. When its time to put the gears on they are pretty much dead nuts.
FSM tells you to do it that way for a reason....
I do agree. do double triple 1000xxxx times check that ****ing belt. I counted all the teeth like 5 times on each side before I even considered rotating it. Then I turn it over about 20 times ever so slow, just listening and feeling for any resistance. Do make sure your spark plugs arnt in while doing this, and you have tape over the holes of them......(been there done that)...
gawdzilla
none
9-18-2004
Quote, originally posted by 240slidekat »
the angles when you torque that you're referring to is an alternate way of getting proper torque using a different style tq wrench. most people use the bending tq wrench or the clicking ones now
you shouldn't have a problem putting the cams in when the motor is TDC. just clock the cams like the FSM says
Just your average dreamer looking for a 240
http://forums.racebread.com
Darius
'97 240SX SE
Ames Iowa
3-2-2003
Oh I read the FSM and followed the install procedure except I must have been off on my cam alignment. However, I couldn't have been off by more than 10-15 degrees and I ended up torquing my head down with my valve resting on my #6 piston. This is why I modified my install procedure to take any potential of f__king up the valves out of the equation.
Shocker
Youngstown Ohio
8-1-2004
Yeah your cam angle had to have been off... I install my cams once in my head son my block. You had to have to since your running HKS cams...
When at TDC as you know #1 and #6 are all the way up. So I visually watch my lobes as long as they are on their main circle and not lobe, theres going to be ZERO contact.
If it works for you awesome! I just like using my FSM as a reference for personal relief lol.
240slidekat
240sx, b15 specv
12-20-2004
most of the things you guys said make sense. ok now how bout torqueing the head. i believe the arp are suppose to be torque at 80 ft/lbs. so do i torque it 40 ft/lbs in the sequence mentioned above then 80 ft/lbs?
Coolwhip
NICO Sponsor
Orlando Florida
2-6-2004
70ft/lbs if you're using the ARP moly paste
240slidekat
240sx, b15 specv
12-20-2004
i pulled the head out today and its confirmed my #4 valves are stuck open. the block looks fine though.
Coolwhip
NICO Sponsor
Orlando Florida
2-6-2004
did you end up picking up that head you were looking at?
240slidekat
240sx, b15 specv
12-20-2004
yea not just need time to put it in.
tgxlayzie
89 nissan 240 sx
kearny nj
6-25-2008
realy late but just joined the forum but shocker seems like u missed steps on the removal. 2 take off da head where are these 3 10 mm bolts and bolts that you start from the outside n work your way in. are they under the valve covers. and also i see 3 alan key bolts between the spark plugs do you take those out as well are its not nessesary. and from what i understand if the 1st cylinder is at tdc you dont have 2 take out the cams or is it nessesary to take them out 2 get 2 the head bolts?
haters be killin themselves they wanna come n get the glory
tgxlayzie
89 nissan 240 sx
kearny nj
6-25-2008
 « Re: Removing/Installing RB head (tgxlayzie)
o yia n where can i get a fsm
Coolwhip
NICO Sponsor
Orlando Florida
2-6-2004
two around the outside of the cylinder head toward the back of cylinder 6.
1 is also on the exterior toward the front by cylinder 1.
The hex plugs in the head are for the coolant system, no need to remove them.
TDC will leave the notches in the cam shafts exposing the head bolts. No need to remove cams for this effort.
rbs14kouki
rb27dett s14 / golf mk4
montreal quebec
6-18-2007
got my FSM here : http://phase2motorsports.store....html
i did not took the cams out of the head for the instalation !!! i have a rb26dett !!! i think it's the same for the rb25
Coolwhip
NICO Sponsor
Orlando Florida
2-6-2004
a picture of a RB30 but it has the same bolt locations as the RB25.
Marked in red...
StricNyne
10-30-2003
i like how u ninja 'ed that rb30 pic in there
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
