 SR20DE in a Pulsar GTI-R!? Urgent!!
Swede_gtir
Stockholm Sweden
3-25-2008
Hi guys,
I really need your help!!
The thing is:
I have a Pulsar GTI-R (SR20DET engine with the 54C block).
Unfortunately the original engine decided to die, and I bought a rebuilt "stronger" motor from a well known company in the US....
BUT......when we checked the engine we noticed that it wasn't a 54C block
It was a SR20DE 53J block...!
The thing that made me wonder what was wrong, was that the intake manifold from the GTI-R didn't fit on the head. The flange was different.
I asked if this was a redtop as the original GTI-R motor and got the answer writter below.
The motor builder said that: "This is the same motor I have sold before for GTi-R's and have not heard of any issues. The "red top" is for rear wheel drive cars, like the US spec 240 SX... so that motor would not work for you."
Is this correct or just bs?
Please help me
Is the tranny going to bolt up? Is everything else going to bolt up? Can it work if I modify/change the flange on the GTI-R intake manifold? The exhaust manifold fits...
Regards
SG
Modified by Swede_gtir at 6:06 AM 3/26/2008
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
There are "red top" FWD engines, but generally when people say red top they mean the RWD S13 engine.
That said, everything else will bolt up. However, the GTi-R has a different flywheel than other SRs. Run a search, I know someone explained the difference recently.
The DD - '01 Sentra SE (RR SR20DE) w/pp (VLSD, FSTB), a few mods
Get your Nissan/Infiniti's FSM FREE here.
Need parts? Look here!
Swede_gtir
Stockholm Sweden
3-25-2008
 « Re: (nametakennow)
Quote, originally posted by nametakennow »
But the intake manifold is not the same, and will not bolt up!? The oil pan is not the same either...
Could you please give me the link to the explanation of the differences between the flywheels?
Or even better!!!! Could you explain it here? Can I use the GTI-R flywheel, or do I have to buy another one?
Regards
SG
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
Right, the intake mani and oil pan are not the same. Some explanation on the oil pan can be found here.
As for the gearbox, the GTi-R uses a larger clutch and flywheel, as explained here. In your case you'll need to use a clutch/flywheel designed for any other SR (if you want to be specific, use the one that matches the 53J type SR, but it won't matter so long as it's a non-GTi-R transverse SR clutch and flywheel).
In the future the search function is the best way to get a quick answer since there may or may not be someone checking this forum who knows where to find this info.
Swede_gtir
Stockholm Sweden
3-25-2008
Thank you VERY much
So....the only way it will work is if I use both clutch and flywheel from another SR-engine than the GTI-R? or can I mix parts? Is it a "bad" thing to use clutch/flywheel from another SR-engine? What does "transverse" mean?
Sorry for the stupid questions...
//SG
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
The GTi-R clutch and flywheel won't mate up to the SR you're receiving, so you have to use one designed for it. You will have no ill effects from doing so.
Transverse engines are mounted horizontally when looking at the car head on.
Swede_gtir
Stockholm Sweden
3-25-2008
Thanks again!!
Just to check if I've understod it...
I can use a flywheel and a clutch designed for any transverse SR20 engine, and this will bolt up with the "SR20+GTI-R-gearbox-mix" without any problems? What about the GTI-R starter? Would that bolt up with the SR20 flywheel?
//SG
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
It shouldn't matter so far as I know. The bolt patterns and such are the same, only the diameters are different.
Swede_gtir
Stockholm Sweden
3-25-2008
Sure? http://www.nissangtir.co.uk/fo...96778
//SG
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
Depending on which direction the bolts go, it may or may not matter.
I assume that since GTi-R clutch/flywheels work on non-GTi-R transmissions, it should go the other direction too.
510_freak
72 Datsun 510 & 93 Z32 n/a
Santa Maria Ca
4-1-2008
hey im new to the forum but maybe one of you guys can help me out. Im planning on putting a sr20 gtir engine into my 72 510 but was wondering if i can bolt up a rwd tranny to it
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
No, RWD transmissions will not bolt up to the FWD/AWD engines. You're stuck using a Silvia engine.
Welcome to NICO!
510_freak
Santa Maria Ca
4-1-2008
so is the bell housing bolt pattern the only thing that keeps them from bolting up
nametakennow
Sentra Moderator
'01 Sentra SE w/pp
Atlanta GA
8-24-2002
The exteriors of the blocks are different, so mounts and such don't match up either.
Swede_gtir
Stockholm Sweden
3-25-2008
I had to modify the block and the oil pan to have the motor and gearbox bolt up... The 53J oil pan is much bigger than the GTI-R oil pan, and the oil pan from the 54C does not bolt up on the 53J block
Does anyone have pictures of a SR20DE FWD (long block) with all of the parts (oil filter adapter, power steering pump etc..) still attached to it? That would help me ALOT!
//SG
Nismo77
SE-R
La Mirada CA
5-31-2006
 « Re: (Swede_gtir)
Hi there..How come you didn't just buy a 54c IR motor for a replacement or rebuild the blown motor? a stock 54c is much stronger than a 53j engine unless it has after market internals...Seems like your doing more work than needs to be done.
Also this answer you got " "This is the same motor I have sold before for GTi-R's and have not heard of any issues. The "red top" is for rear wheel drive cars, like the US spec 240 SX... so that motor would not work for you." He doesn't seem to know about the bluebird motor aka Red Top 4wd engines which is a very common swap here in the states in the Sentra b13-15.
Super Smurf
POWER'D By SR20DET
Swede_gtir
Stockholm Sweden
3-25-2008
 « Re: (Nismo77)
Quote, originally posted by Nismo77 »
Unfortunately the blown motor (54C) isn't that common here in sweden.. Otherwise I would have bought a block right away. The reason I dont rebuild my original motor is because it has "cracks" in block and head... This 53J motor is totally rebuilt with after market internals and ported head etc..
I know.. He doesn't seem to know sh*t about the SR's.
Nismo77
SE-R
La Mirada CA
5-31-2006
 « Re: (Swede_gtir)
wow thats a bummer...we have gtir motors over here all the time..its a shame this guy you bought your engine from didn't send you the 54c long block like he was suppose to in the beginning...you would have been done already...Anyhow Good luck with it and if you don't already know check out sr20form.com for more info if you need it...
Swede_gtir
Stockholm Sweden
3-25-2008
 « Re: (Nismo77)
Thanks.
He said something like "there are no GTI-R motors in the country" and exactly this: "This is the same motor I have sold before for GTi-R's and have not heard of any issues"
The company is not going to help me to solve this problem, but they say I have usd 500 in credit, that I can use to buy what I want...
If someone have pictures of a SR20DE FWD (long block) with all of the parts (oil filter adapter, power steering pump etc..) still attached to it, I would be really happy, and it would help me alot!
710fastback
74 datsun 710
queens ny
4-12-2008
http://www.jdmtigerjapanese.co...bpjf3
i would sell that built de and source this 54c . i would go with forged internals this trip. the 54c is a STRONG motor you're good for 500+ without porting and stroking. good luck mate
Princess Leia to Han Solo: " I love you! "
Han Solo:" I know! "
I almost cried, it was the most beautiful thing I had ever heard
» Return to SR20DE / SR20VE / SR20DET Forum (front drive)
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
