mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Tue Mar 25, 2008 9:51 am
Ahhh... it came off of the GM 3.8 V6 which means here in the states it can be found on the Pontiac Grand Prix GTP. The unit is an Eaton M90 while the stock VG33ER unit is an M62... to be honest, Nissan should have went straight to the M90 as the M62 is definitely on the small side for the VG33.
What's nice about those M90's is they're so common place due to Ford and GM using them quite a bit that you can get them cheap on eBay. If you can fab up an adapter of some sort you could definitely get quite a bit more performance over the VG33ER's M62.
