 are parts interchangeable between FF and FR vq35's
Zriuz
180sx
Waterbury CT
9-5-2005
alright i just got my hand on z33 tranny just because i'm a big car part hustler in town so i just buy stuff even if i won't use it if they are at good prices, to resell.
i do own a s13 so i just tho about vq35 swap, i'm currently running an sr but just got the urge of doing a vq swap
can anybody explain the difference between the altima, maxima and z33 vq..?? besides the obvious intake, compression and exhaust... and the difference in years and the valve timing system it uses.
i'm mad cheap so i'm trying to use the FWD version with a megasquirt. i know my way around fabrication so please avoid telling me to seek professional help.
i been searching and cant find anything about the variable valve system.
is it on and off like v-tec, or more like a cam degree adjustment like i-vtec (sorry for the honda comparison) trying to figure out since megasquirt can only control the on and off type. any info will be great.
also want to know if parts like, pistons, cams and rods are interchangeable between the fwd and rwd versions
Zriuz
180sx
Waterbury CT
9-5-2005
 « Re: are parts interchangeable between FF and FR vq35's (Zriuz)
damn no body knows about this??
Q45tech
Q45 Guru
1990 Q45 319,000 miles
Marietta , Georgia
4-30-2002
Why would ethical people consider violating the Federal Clean Air Act by installing a larger displacement engine?
http://www.t3auto.com/
Spoolin4days
03 Spec V
Teaneck NJ
5-28-2007
 « Re: are parts interchangeable between FF and FR vq35's (Q45tech)
Quote, originally posted by Q45tech »
Wouldn't a VQ have lower emissions than a boosted SR? or am I missing something here?
SHIFT_...or get smoked
Q45tech
Q45 Guru
Marietta , Georgia
4-30-2002
 « Re: are parts interchangeable between FF and FR vq35's (Spoolin4days)
Unfortunately the law considers displacement as a higher emission producer. Especially at idle.
A boosted SR is illegal because it was never legally imported or sold in US. Never tested for emission compliance.
rmezz13
350Z Moderator
2004.5 Nissan 350z Performance
Columbus OH
11-27-2007
^^^^^ these are the people that are involved in the EPA that are the reason we cannot update our refineries, build newer more efficient refineries, and dig for oil in our own land..... These people are the reason GAS is so freaking high.... federal clean air act.... blah blah blah..... the same people that say diesel is more polluting than unleaded.... Diesel is more pure and easier for the earth to break down, but since its black smoke it must be bad.... only in america!
350z Forum
350zClub.org
NICO Home
Quote, originally posted by R350Zz33 »
i was just lookin to fill the third hole?.
irax
VQ35DER Powered S14.3
San Diego CA
1-5-2004
how does swapping in a vq into an s13 violate FCAA ? As long as all the emissions equipment is kept from the newer engine and not modified at the very least it is legal. Although you can not swap an engine from a truck into a car nor a gas engine into a car that is diesel, though the opposite is completely legal.
I just scanned through the FCAA and it doesn't specify a displacement compliance.
kzoosho
Turboed 1997 Nissan Maxima SE
Grand Rapids michigan
12-26-2007
 « Re: are parts interchangeable between FF and FR vq35's (irax)
To answer your question the difference in VQ's is very minimal. You can use a vq30 or 35 with that tranny.
1997 Maxima Turbonetics 60-1 550cc injectors q45 maf safcII and running great.
1999 Maxima V1 Vortech 370cc injectors Z32 maf and SafcII auto with modded VB
gadget1382
2x S12 Gazelle, 1. CA18det daily 2. Building VQ30det+t track car
Melbourne Victoria
7-6-2008
Why would you care?
You guys are complaining about petrol prices, yet get them cheaper than nearly everywhere in the world!
American pollys lack of logic, astounds me!
We have stricter road rules than you guys for EPA (Environmental Protection Agency) yet we can still realise that a newer engine, designed for a later Euro standard, is more than likely going to produce less emissions than that for a standard years earlier.
From what limited research i've done there are quite a few parts that are interchangable, but rather unsure of the variable timing etc.
Ban Low Performance drivers... Not High Performance Cars
Nissan S12 - Gazelle coupe / 200SX / Silvia
SPiG
Baton Rouge la
2-25-2007
Between the FWD and RWD VQ35DE (not including Rev Up, HR, or early pathfinder)
these are the same:
pistons (compression is the same for all at 10.3:1 from the FSM)
rods
crank etc.
heads
everything inside the heads including cams and VTC
These are not the same:
Block (mount
oil pan
intake manifold
exhaust manifolds
coolant lines
headgasket (FWDs have 2 layer, RWDs have 3)
All it really does is make you source some more parts like the oil pan and IM, and make custom motor mount brackets. It can be done and for significantly less money than a RWD engine would cost.
The Nissan VTC on the VQ35 is continuous so it is NOT on/off, and cannot be controlled without a complex computer to run it. There are ways around it including disabling it, but you will lose torque or have to use the stock ECU or an expensive standalone.
I am personally disabling it for my swap since I think I will have enough torque with what I have planned.
sancosys
NorCal ca
1-24-2007
 « Re: (SPiG)
There is nothing illegal about swapping in a larger displacement engine as long as you meet the correct laws as well as keep all the applicable smog devices. If not explain how a LS1 swap into a S13 can be legalized in California. And yes it can be...
Aaron
The difference between oversteer and understeer is what you are looking at when you crash.
D-Max, Super Made, Damd, ETC. Ask here.
Black Subaru club check in
Clifton
73' 240Z/7MGTE 71 240Z/L28ET
Scottsdale AZ
1-24-2005
[QUOTE=Q45tech]Why would ethical people consider violating the Federal Clean Air Act by installing a larger displacement engine?[/QUOTE}
+1 for keeping it on topic.
71' 240Z L28ET 417 rwhp
73' 240Z 7MGTE 533rwhp/553rwtq
» Return to VQ30DE / VQ35DE / VQ35HR Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
Home Photography Help
