evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri May 23, 2008 8:22 am
actually the L series suck at least their combustion chamber does, and I believe a centered valve would flow better but to get the most out of the L28ET in pretty much stock form, add and intercooler, a RRFPR and a boost controller and you can get arouns 260 hp at the rear wheels, at that point the injectors, fuel pump, turbo, HG and ECU are all pretty well maxed out, upgrade all those and the stock internals will give up the ghost somewhere near 400 whp
the big benefit to twin cams si you cna put the spark plug in the middle and get a more even burn, less chance of detonation and more even pressure on the pistons and rod, they will alow you to put the valves int he liddle of the cylinder and across from the other for improved exhaust scavanging, and having the inltake and ehaust port seperated will allow for a cooler intake runner also a good thing, lots of benefits tot he twin cam but finding one for an L6 is dificult and expensive, I heard of OSG heads selling for more than a complete RB26 swap, just to gain an extra 20-40 hp
