 Where is the subwoofer located?
dawson76
Valrico Fl
3-17-2008
Before I go to a lot of trouble searching for it I figured I'de ask here since I can't seem to find this info ANYWHERE online,lol
I am fairly happy with the Bose systems midrange and highs and the bass is ok at lower volume levels but it almost seems like the sub turns itself off if you get the volume up very high so I figured if I can find the factory subwoofer, (in the back somewhere I'm assuming?) I should be able to hook up a aftermarket sub and amp to the same wiring correct?
Thanks!
eddiehaskill
2008 Nissan Rogue
Buffalo NY
2-25-2008
 « Re: Where is the subwoofer located? (dawson76)
Its located under the spare tire apparently
Derango
2008 Nissan Rogue SL AWD w/ Premium Package
Rome NY
11-15-2007
 « Re: Where is the subwoofer located? (eddiehaskill)
Quote, originally posted by eddiehaskill »
It's actually on top of the spare tire, under the removable floor panels in the rear.
rogueagent08
'08 Nissan Rogue SL
Metairie LA
11-27-2007
 « Re: Where is the subwoofer located? (Derango)
if you check my previous post about this you'll see a pic of where it's located and about the size of the woofer as well.
you should do a little more research about aftermarket car audio. Bose, JBL, etc... any of these factory units are not plug and play systems. you don't just plug up a more powerful amp or a different speaker and it just works. Now if you wanted to add an amp and woofer you could do that and their are a few ways to do that.
alot of the work that you may want done i'll be able to guide you or someone else might be able to but any audio system in the SL equipped Rogues are going to take a nice amount of work and some pretty pennies. Most Audio shops are not Bose freindly, as most of them need to be completely rewired to accomplish any install. I'll be posting some more about my install in the upcoming weeks.
Briguy1027
West Covina CA
10-28-2007
 « Re: Where is the subwoofer located? (rogueagent08)
Your thread showing all of the speakers was great Rogueagent. I agree that to switch subs would probably be difficult with the existing amp that you showed in the picture (it's really small). I suspect the sub is one of those fancy long tubes that Bose uses to extend the bass on their systems.
On another car I have, which is not a Bose setup -- I was able to add something called a Basslink, which has it's own amplifier, which you would take power from the battery and get the signals from all 4 front speakers, or like I did, just from the two rear speakers, and it added a lot of bass. I suppose technically, you could take the signal from the wires coming into existing bass module and disconnect it.
On the Rogue though, I'm plenty satisfied with the bass as it is. I don't really turn the radio up much, content is more important to me, and with the satellite radio and the ability to play MP3s, I have a lot to listen to
dawson76
Valrico Fl
3-17-2008
 « Re: Where is the subwoofer located? (Briguy1027)
thanks rogueagent08, your thread with the pictures was very helpfull.
I have an enclosure with a couple ten's and an amp that wouldn't take up to much room in the back.
Any reason I couldn't use the existing wiring going to the bose sub to hook up my amp and sub? Are the audio leads going to it standard low level sub outs? I also don't know if it uses a standard 12v remote to power on the amp?
I think those are the two main things I need to know in order to get it to work....too bad the head unit doesn't have a seperate sub volume controll
rogueagent08
'08 Nissan Rogue SL
Metairie LA
11-27-2007
if you're using a LOC or line out converter off of just the speaker leads than you'll be okay but be sure it's not a cheap one, just use a decent one and you'll be just fine. I may be wrong on current Bose systems but all previous Bose systems ran their amps at 1ohm to 1ohm voice coils on their speakers which made it rather hard to run off the shelf speakers. running off the shelf speakers yeilded a 4 ohm load and these amp were not meant for that high of an impedence and such caused them to burn up.
summary= a good line out converter should work just fine for adding subs only.
I on the other hand will be doing a full install keeping the factory head unit using the Rockford Fosgate 3SIXTY.2 for my signal processing and all Powerbass equipment.
dawson76
Valrico Fl
3-17-2008
Quote, originally posted by rogueagent08 »
Thanks, so I take it the audio leads going to the bose amp are high level hence the need for a loc if I use my aftermarket amp?
Do you know which one of the wires is the rem, if any?
Modified by dawson76 at 5:45 AM 3/18/2008
rogueagent08
'08 Nissan Rogue SL
Metairie LA
11-27-2007
IDK which 1 is remote but i'll figure it out for you once i get going on the project or if some1 would like to chime in with the answer before than, that'd be great.
dawson76
Valrico Fl
3-17-2008
Well, I'm guessing that the two larger gauge wires are the ground (black) and positive (blue) while the yellow and brown wires are carrying the audio signal and I would be suprised if I'm wrong about those four.
That just leaves the green and black wires with silver dashes. If one of those are the rem then what could the other be for I wonder?
philipa_240sx
'08 Rogue SL FWD - Iridium Graphite
KW Ont
6-21-2007
Wiring for Bose Subwoofer above:
For some reason the FSM wire colors don't match yours...
If you look at the connector from the harness side (clip facing up as shown), the pin numbers are marked as follows:
2 | 4 | 6
1 | 3 | 5
1 = Brn = Audio signal - (line level)
2 = Yel = Audio Signal + (line level)
3 = Braided (black) = Shield for audio signal
4 = Grn = Amp ON Signal (12V switched)
5 = Black = Ground
6 = Black with silver stripe? Same as blue in your photo = Battery +12V (fused at 10A)
The audio signal is not amplified, but appears to be a balanced line level output.
I'm no audio expert so I can't comment on what will work. A LOC may be OK if it's adjustable for the low level Bose outputs. There are also Bose specific LOCs:
http://www.logjamelectronics.com/sounlocbosli.html
Good luck!
Modified by philipa_240sx at 7:01 PM 3/25/2008
dawson76
Valrico Fl
3-17-2008
 « Re: Where is the subwoofer located? (philipa_240sx)
Thanks Phil
Quote, originally posted by philipa_240sx »
2 | 4 | 6
1 | 3 | 5
5 = Black = Ground
Good luck!
thanks Philipa...In case anyone is curious I hooked up my amp and two tens to the factory wiring and it works fine...I didn't use a loc or anything, just split the two audio wires to two RCA plugs and and plugged them into the low level ports on my amp and it worked well, although I had to keep the amp level down very low so I think that may indicate that a loc is needed.
My wife however does not want to lose that much trunk space so I removed it after seeing if it would work
SquiggyFreud
Lafayette LA
3-27-2008
I would like to get at least one 12" in the back, I have already convinced myself I will not put my dual box and fill up the back end as it was in my old CRV. It looks like it will not be too bad tying in an amp, but now I need to work on how I will run the lead to the battery, has anyone pulled any cable in a rogue yet?
SquiggyFreud
Lafayette LA
3-27-2008
Stopped by the local car audio shop today...he said no need for a LOC if you splice in b4 the amp...nonetheless, I have ordered an MTX re-Q bass enhancer, waiting for it to come in. Gonna have a 400 watt amp on my single 12", but am going to install a dual amp kit in case I need to add on down the road.
Still have not found a hole in the firewall to run the battery lead, hoping I will not have to drill
dawson76
Valrico Fl
3-17-2008
 « Re: Where is the subwoofer located? (SquiggyFreud)
Quote, originally posted by SquiggyFreud »
I used the stock sub wiring on mine and it worked fine...it's a little undersized for high current draw but I think it will work fine for moderate listening levels. I guess you would need a larger gauge wire if you like to blast your eardrums off all the time but thats not me.
websfear
2008 Rogue SL Venom Red
Madison WI
9-13-2007
And I doubt that you will. I think Nissan has a habbit of only supporting the wire harnesses. And since the Rogue doesn't have a manual transmission option there isn't a hole for that either.
I am in the same situation, getting 30 amps or so into the cabin. You can get to the firewall by removing a lot of the air intake tubing from the driver side of the engine compartment.
I have an appointment with a local auto stereo installer to have them do it - about $120. That is including 40 feet of wire (20 each of black and red) number 8, fuse blocks and all of the usual looming, wire ties, grommets, etc.
SquiggyFreud
Lafayette LA
3-27-2008
 « Re: Where is the subwoofer located? (websfear)
Yes the air box needs to come out.
Pull the battery, remove the 4 screws on the battery plate this will give you some room to get the air box out.
Loosen the hose clamp on the box, there are 2 more screws, up top on the right and one next to the battery plate. then you can jiggle the box out.
The rubber grommet for the factory harness is now exposed
Poke a hole, pull your cable, feed it down the driver's side of the car under the plastic and your done.
I put a 12" Clarion in a slotted box, 600 Watt Alpine amp, and I used a Re-Q to splice in to the Bose Amp harness. I originally had the amp on a board below the deck in the back, but that amp runs way too hot to be there. Maybe some cross flow fans one day will take care of that.
I did find the Bose amp I will assume is for all of the speakers in the back end while I had it torn apart.
I installed a dual amp kit so if I ever decide to throw some components in there, it should be pretty easy.
Sounds pretty good now, The radio sound quality sucks, I actually use the tuner on MP3 player for radio. CD's sound good too.
Modified by SquiggyFreud at 2:28 PM 4/12/2008
DoubleDo
Schaumburg IL
7-14-2008
How about this SquiggyFreud.
I got a 10 Rockford Fosgate Shallow Sub, the P3 running 280 watts to it. How do you guys like it? It doesn't take up any of my trunk space.
SquiggyFreud
Lafayette LA
3-27-2008
 « Re: (DoubleDo)
Sweet!
rjuarezjr915
ROGUE
SCHERTZ Texas
4-25-2008
 « Re: (DoubleDo)
dude you are my hero this is what i have been trying to do how did u do it??? any help would be great. did you build the box???
DoubleDo
Schaumburg IL
7-14-2008
 « Re: (rjuarezjr915)
Yeah, I built it myself. I got the Rockford Fosgate 10" shallow sub, the D3 shallow one off of ebay for about 95 bucks.
You have to remove the bracking for the Bose sub and then the plastic piece on the right, you have to cut it in half. So I still have the Bose sub in there along with the new one.
The total height for the sub is 4.5" and I used 1/2" HD Partical board. Total Dimension for the box is:
4.5x14x(28top and 31bottom)
It took me about a week to build at work, and the top cover, I just matched the dimensions of the existing cover, with the notches cut out to lay on top flush and a hold cut out for the woofer.
It sounds nice. Hope that helps
rjuarezjr915
ROGUE
SCHERTZ Texas
4-25-2008
 « Re: (DoubleDo)
SORRY TO BE A PAIN, BUT WHERE DID YOU END UP PLACING THE AMPS?
» Return to Rogue Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
