nsrZ32
Super Moderator
90 300ZX TT, 78 280Z, 71 521 Pickup, 98 Sentra 2.0 SE, 02 Altima 3.5 SE, 01 Focus s2
Cleveland Ohio
10-15-2004
Welcome to NICO!Good to have some more old Datto truck guys here. We need to bring more over
-Jerry
 ---George C. Taylor deceased 8/21/04 ...take care Dad--- ----------NICO ROTM ------------Z History Thread ----------
moparvwfreak
1973 Datusn 620, 1995 Nissan Pathfinder SE
Monroe Wa
3-6-2008
well today was productive. i replaced the rad cap so HOPEFULLY it will stop overheating, pulled the grille (which was a ROYAL PITA!) fixed the passenger side headlight low beam for now, pulled the cluster and heater controls and test fitted my 2 knobber Sony tape deck. i also found out where my fiber optic light goes for the wiper knob. so all in all i got alot accomplished. oh i also figured out why my wipers suck. the bushing that goes onto the drive pivot is missing. so they barely work. i also removed the front bumper as it was fubared. here are he 2 pics i was able to take before my camera batteries died
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
Good progress man!
moparvwfreak
Monroe Wa
3-6-2008
not to bad for only having the truck 24 hours. i still have ALOT to deal with. heater issues, radiator issues, and wiper issues mainly. its coming along very well though.
NSR_s30
Drive to live, live to drive
'99 Ford F250 7.3L Diesel, '71 Datsun 240Z
Somewhere in OH
10-8-2004
| « Re: (moparvwfreak) | 7:31 PM 3/8/2008 |
Awesome 620! Welcome to the club.
- Josh - BUY MY MATCO PRO SCAN PLUS OBD1-2 SCANNER http://forums.nicoclub.com/zer...us-oh
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Oh yeah, we have a lot of work to do. The part that really pisses me off about the truck is the front end, but then again it's hard as **** to find a 620 without a slightly smushed front.Mark, nsrZ32 has a BADASS 521 you should check out.
Representing all the pignose pop-up single-slammin' coupes in the rainy Pacific Northwest.
moparvwfreak
Monroe Wa
3-6-2008
yeah i know. but hey i had an idea. L20-T? :D as for the rest of it i found the heater blower works, also the radio is in and works. The benz foglight is in on the passenger side. The dash is back together and the hazzard flashers now work as well. all thats left now is to finish the wiring on the heater fan and figure out where i am getting water inside. drivers side is dry but the passenger side is wet.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (moparvwfreak) | 2:12 PM 3/14/2008 |
well the heater is working now but only on the high setting. could be a bad switch or i have a wire crossed somewhere. nothing big. i also found out where my water leak is INSIDE the truck. passenger side door vapor barrier is shot. the plastic is decent but the glue they used in 73 has let loose. no biggie. i have done these before on VWs so its not hard to do. now for a tuneup, radiator, and new hoses and this beast will be somewhat legal again.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (moparvwfreak) | 10:41 PM 3/17/2008 |
here are some pics that i took today. havent gotten much else done but we, lofapoo and i, got the tail lights working, fixed the wipers, removed the rear bumper and lowered the front end a bit. all in all a good bit of work for one day. i also found out why my reverse lights dont work. one of the switch wires was cut and the other unplugged. time for a new switch. now to figure out my plate light and all will be good to go. so here are the pics!
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
Good progress!
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (nsrZ32) | 2:10 PM 3/19/2008 |
thanks! i have alot of work to do still but at least the oil light started working. now to sort out my fusebox, reverse lights, plate light, parking brake, and the cooling system. i have a line on a buttload of parts so hopefully i can get most ofthose so i can put my truck totally back together,
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Mmm, rusty dirt covered in PB Blaster tastes sooo good.Wish I could make it down south this weekend, but unfortunately I'm stuck heading up north  And the weekend after that is the big one! You got a lot of work to do, boy. I can come over after work some days to lend a hand, drop a line.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 10:21 PM 3/19/2008 |
| Quote, originally posted by lofapoo » | | Mmm, rusty dirt covered in PB Blaster tastes sooo good. Wish I could make it down south this weekend, but unfortunately I'm stuck heading up north  And the weekend after that is the big one! You got a lot of work to do, boy. I can come over after work some days to lend a hand, drop a line. |
yes it does! to bad you cant make it. but i should have some stuff for swapping. i am hopeing to pick up an a**load of parts. hood, bumper(s), doors , tail gate(s), everything i need. will do man.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (moparvwfreak) | 11:36 PM 3/25/2008 |
well i wasn't able to get everything i needed but i did get some parts that i can use. heater box is now fully clipped in place, hood has been replaced with a PERFECT one as has the front bumper, i fixed the core support where it was damaged from the front bumper, replaced the passenger rear side marker and am trying to figure out how to mount my good tail light as the mounting studs are broken. i also got a radiator BUT it doesn't fit. its to wide. so i am working on finding another one if i can. i have also traded my weber carb for a few other peices i am needing. so hopefully i can figure out how to get this thing running right so i can drive ti soon.
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
Speaking of parts. Do you have any access to 521 parts? My truck needs some stuff bad and it seems all of them are in the northwest and not in my area.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (nsrZ32) | 7:04 PM 3/26/2008 |
| Quote, originally posted by nsrZ32 » | | Speaking of parts. Do you have any access to 521 parts? My truck needs some stuff bad and it seems all of them are in the northwest and not in my area. |
i dont but check out http://www.ratsun.net . there are always parts up there for sale. and ou could post a want add for em there too.
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
| « Re: (moparvwfreak) | 2:56 AM 3/27/2008 |
| Quote, originally posted by moparvwfreak » | i dont but check out http://www.ratsun.net . there are always parts up there for sale. and ou could post a want add for em there too. |
I've been a member on there for awhile  Just figured I'd check to see if you had anything sitting around
Bleach
Three Z-cars
Seattle WA
3-26-2008
| « Re: (nsrZ32) | 8:56 AM 3/27/2008 |
what are you doing on this forum!?
350Z - Fairlady Z - 280ZX Turbo
 Northwest Events
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
| « Re: (Bleach) | 11:44 AM 3/27/2008 |
| Quote, originally posted by Bleach » | what are you doing on this forum!? |
This forum is my home  Good to see you on here btw
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (nsrZ32) | 1:04 PM 3/27/2008 |
| Quote, originally posted by nsrZ32 » | I've been a member on there for awhile  Just figured I'd check to see if you had anything sitting around  |
i am just STARTING to build my parts hoard for datsuns. this 620 is my first but most likely not hte last datto i will own.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
You should see what this guy means by parts hoard.You can't walk five feet without stepping on a VW or Mopar part, or take a dump anywhere on his property without a car part staring at you. Now there's more and more Datsun parts stacking up, and he's only had the damn thing a few weeks. God. Damn. Packrat.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 10:22 PM 3/27/2008 |
| Quote, originally posted by lofapoo » | | You should see what this guy means by parts hoard. You can't walk five feet without stepping on a VW or Mopar part, or take a dump anywhere on his property without a car part staring at you. Now there's more and more Datsun parts stacking up, and he's only had the damn thing a few weeks. God. Damn. Packrat. |
its not THAT bad.... ok maybe just a little. "but i'm getting better!" LOL!!!
moparvwfreak
Monroe Wa
3-6-2008
so yesterday i went down to Portland adn got some parts in trade for a carb that i had bought but didn't want to adapt into my truck. i got a valance panel, cowl panel, and a pair of hood hinges. and for a little bit of $$ i also scored a set of new wheels (cheapy Les Schwab wagon wheels painted black), a dash, and a new heater box. i am currently painting the dash since the cracks have been repaired. its going flat black as that way i wont have glare. i have already removed the old dash and i am painting the metal to match the dash pad. hopefully soon i can afford to put a tach in here as well so i know what kind of damage i am doing. the list of parts i still need are..... radiator (still) parking brake cables temp switch for the 2nd set of points or an EI conversion drop blocks (3 inch) heater hoses tune up stuffs fuel line from filter to fuel pump rebuild kit for the hitachi carb new tail lights (amber/red/clear), bumper/tail light housings, and front marker lights (clear\amber) and a bed front. all in all its not a lot of work just time consuming.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (moparvwfreak) | 10:03 PM 4/11/2008 |
well i got a lot done today. i finally got the passenger tail light installed (fender washers, nuts and zipties! yes it works!), got the plate light working, freshly painted wiper arms installed, and my bucket seats repaired and 3\4 installed. i forgot to get enw nuts for the passenger seat mounting studs so.... tomorrow those will be totally installed. i also drilled a small drain hole in the passenger floor board so i can drain the water from teh leaky door seals and vapor barrior. here are some pics of the work i did today.
710fastback
74 datsun 710
queens ny
4-12-2008
nice!!! what are you planning to do for the motor?
Princess Leia to Han Solo: " I love you! " Han Solo:" I know! " I almost cried, it was the most beautiful thing I had ever heard
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (710fastback) | 1:13 PM 4/13/2008 |
i have been thinking about doing an L20 swap until i can find a decent truck 12v KA to drop in. and yes i would be going EFI. but untill i can find a decent L20 and a weber i'll keep the L16 around. hell im ight even try to find a set of SU carbs to mod in. who knows.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Holy crap, dude! I missed out on a lot. That new dash is OMG SECHS.Now where's that lower valence? :P By the way, if you want a coffee table, I have a bare ka24e block I'm about to throw away.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 1:29 PM 4/13/2008 |
| Quote, originally posted by lofapoo » | | Holy crap, dude! I missed out on a lot. That new dash is OMG SECHS. Now where's that lower valence? :P By the way, if you want a coffee table, I have a bare ka24e block I'm about to throw away. |
vlaance is sitting in the bed. havent felt like yankin the bumper, pulling cheesed screws, and painting it as of yet. as for a coffee table you KNOW how much room i have right now. NONE! otherwise i would.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Yeah I went through all my parts and filled a box with a bunch of crap I don't want/needStock exhaust manifold, half of a stripped intake, timing cover, accessory brackets, stuff like that. I still have two boxes full of SOHC parts lol
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 8:27 PM 4/13/2008 |
Hmmm..... I'll have to take a look. I might be able to use some of it.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
You said you wanted an alternator, right? You can have one of mine.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 12:11 AM 4/14/2008 |
might have to do that. but i would need a plug as well so i could upgrade it.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Stanza, hardbody. Maybe Altima if the plug is the same for a DOHC.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 1:22 AM 4/17/2008 |
i will have to look at that. as it sits i am still on the hunt for a good radiator. $$ is a big thing right now so..... yeah. i still have some work to do but all in all its coming along nicely. heres teh list of sh*t i still ahve to do on this truck.to fix..... reverse lights repair 2nd point system (or go EI) find and repair the water leak in the cab repair fuse box and fuse box wireing replace the alternator for a higher power unit (which i have off a single cam KA) rebuild the spare Hitachi carb paint the hood, valance and roof lube the chassis adjust the rear brakes rust repair for the drivers floor and some POR-15 install or replace..... install and wire in my Benzo fog lights (inner lights) with relays install my PIAA fog lights with relayed harness and a pull switch to kinda flow with the rest of the switches radiator door seals vapor barriers tach when i get one new wheels ( i have a set of wagon wheels that i am refinishing) 3 inch drop blocks in the rear as far as i can think of this is all thats really left.
nsrZ32
Super Moderator
Cleveland Ohio
10-15-2004
| « Re: (moparvwfreak) | 7:20 AM 4/17/2008 |
| Quote, originally posted by moparvwfreak » | | i will have to look at that. as it sits i am still on the hunt for a good radiator. $$ is a big thing right now so..... yeah. i still have some work to do but all in all its coming along nicely. heres teh list of sh*t i still ahve to do on this truck. to fix..... reverse lights repair 2nd point system (or go EI) find and repair the water leak in the cab repair fuse box and fuse box wireing replace the alternator for a higher power unit (which i have off a single cam KA) rebuild the spare Hitachi carb paint the hood, valance and roof lube the chassis adjust the rear brakes rust repair for the drivers floor and some POR-15 install or replace..... install and wire in my Benzo fog lights (inner lights) with relays install my PIAA fog lights with relayed harness and a pull switch to kinda flow with the rest of the switches radiator door seals vapor barriers tach when i get one new wheels ( i have a set of wagon wheels that i am refinishing) 3 inch drop blocks in the rear as far as i can think of this is all thats really left.
Sounds kinda like the laundry list of stuff I have for my truck. Also, where are you picking up drop blocks from? I've been trying to find some 2" blocks with no luck
lofapoo
Toyota sedan
Seattle WA
1-4-2004
I believe places such as CSK, Napa, and Autozone can get drop blocks. I remember Mark telling me he found some 3" for ~$30 from one of those places.
moparvwfreak
Monroe Wa
3-6-2008
| « Re: (lofapoo) | 3:05 PM 4/17/2008 |
$35 at autozone for the kit.
2kredz3
1984 Nissan 720
Marietta ga
4-18-2008
| « Re: new guy with a 620 (moparvwfreak) | 9:14 PM 4/19/2008 |
Very nice! Not sure what is common between your 620 and my first year 720 but it will be interesting to see!
moparvwfreak
Monroe Wa
3-6-2008
| « Re: new guy with a 620 (2kredz3) | 11:05 PM 4/19/2008 |
not alot will be the same with an 11 year difference. but i will be more than happy to help where i can.
| First 1 2 3 > Last |
