Best method to clean hard water spots off chrome?
qsiguy
Car: 1994 Infiniti Q45 Turbo
One of the chrome wheels from my donor car was in the line of fire from my sprinklers where it was parked for a few months. Anyone have any tricks to clean it up? I've tried the simple green and it doesn't to anything. Maybe CLR or a diluted mix of it?
Suggestions?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
noxon brand polish and some microfiber. always did the trick for me.
NightRiderQ45
Car: 1998 Infiniti Q45
jltibbs wrote:noxon brand polish and some microfiber. always did the trick for me.
Usually after I wash my car and rims, I drive to the local car wash to toss all of the water out from my rims. From that point I use a spray glass cleaners on the wheels with newspaper. Then I buff it out with the microfiber towel to give it the ultimate shine.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Simichrome
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Ahh yes I know what your talking about... I think CLR would do the trick well... but is it okay if it gets on the paint?
qsiguy
No paint on these wheels so unless I spaz out and dump the CLR all over the car I should be ok
Thanks for the tips!
qship96
Car: 1996 Infiniti Q45
white vinegar on a rag will wipe them right off . Then wash with soap/water so it doesnt smell like a big pickle
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
You can try one of these products all of which are well respected:
AUTOSOL
WENOL http://www.pelicanparts.com/ca...1.htm
FLITZ
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Use Mother's Chrome polish...it's non-abrasive and works GREAT!!!
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
All very good tips. I'll keep that in mind when I upgrade my wheels.
What about the OEM alloys? I've been using this NASCAR foaming spray before I pull the car in to the Touchless Wash. I spray each wheel thoroughly, usually starting with the rear left. By the time I come full circle, the first wheel that was treated is agitated with a wheel brush and the car wash's green soap solution. I run it all over the tires and take care to get in all the little crannies. I do the same for all the wheels. Then I pull in to the bay and let the rocker panel and tire washers have at it.
I've noticed that it doesn't work completely. I always have to wrap a microfiber around my finger and scrub the vertex. I've almost broken fingers messing with those basketweaves.
Is there anything else that can completely get rid of the brake dust?
qship96
Handwashing car at home does a much better job than the touchless automatic, which never really cleans well and leaves a film of dirt remaining on paint and glass { notice how your windsheild is still filthy in the sun except where the wipers sweep the glass} this same amount of crap is also left on all painted surfaces--why you NEVER towel dry after one of these washes,it just grinds the dirt into the paint and leaves thousands of fine micro-scratches in paint which must be machine polished to remove
Haitian_King
qship96 wrote:Handwashing car at home does a much better job than the touchless automatic, which never really cleans well and leaves a film of dirt remaining on paint and glass { notice how your windsheild is still filthy in the sun except where the wipers sweep the glass} this same amount of crap is also left on all painted surfaces--why you NEVER towel dry after one of these washes,it just grinds the dirt into the paint and leaves thousands of fine micro-scratches in paint which must be machine polished to remove
I've done the handwashing bit, but I always never get a result.I bought Automotive soap but it doesn't get sudsy like it does in the movies. Just slippery water. I put it on the car, and by the time that I'm done the back, the front has gotten all dry and nasty looking.
Plus with the current season, outdoor handwashing isn't conducive to one's health. I used to use a "Waterless Wash" that I had for my Jeep (White) on the Q after I got it, but I've run out. It's like this sort of spray on carnuba wax that you let haze and then buff. It works on paint and glass. I thought it was great until reading on the Autotopia board told me otherwise.
When the weather gets warmer, I'm going to just have the car professionally detailed. Engine bay and all. That will set my platform and I'll keep it that way.
