I Agree.. Cheap isn't going to get you far.. pretty much everything you'll need is going to be used if you want to keep it under 2k. Just a SAFC II and wideband are going to be over 500$.. might want to rethink some things.s14tan wrote:For starters, the word reliability and budget don't mix very well.
Interested in this, can u throw up a link, im out the door as of right now. Thx for all the info guys! be back later tonight so see what new info i getWDRacing wrote:.Fuel management first:I'd use the FMU, also known as a rising rate fuel pressure regulator. It will increase the fuel pressure to the stock injectors as boost pressure rises insuring you don't go lean. Works great right up to 10 psi, I've seen as much as 14 psi...but I would use 10 psi as a goal. This is a bolt on affair, needs no tuning and is under $200. Plus it eliminates the need for bigger injectors.
What do you mean by serious problems? Please list the problems or don't post about them. Here on Nico and especially KAT, I like to keep things as factual as possible so others can read through here later and actually get good information. Not just opinions based on something they have little or no experience with. Or something they heard or read on the internet.Ballboygordon wrote:I would suggest getting a good tuned ECU from Enthalpy, JWT, or even q-garage since I've seen his tunes. Otherwise you will run into serious problems. Also if your turbo has coolant lines, don't be lazy and hook them up.
The FMU isn't used with the SAFC. The only way to prevent a boost spike is to install a boost cut switch. Which is actually quite simple. I believe we have a write-up in the FAQ about how to build one yourself.DMan II-40 wrote:Cool, so the FMU actually eliminates that need for me to get larger injectors and the SFAC II since is increases fuel as air pressure increases. Sound simple and like a great idea especially with my budget. Another question would be a boost spike, would the FMU help prevent damage when that happens? what is the best way with my budget to help prevent damage from one of those nasty things?
Edit: Also would larger injectors paired the FMU be more reliable?
Personally, I'd go with a T3 or T3/T4 turbo with a .48a/r or similar turbine housing. This will give you full boost before 3000rpms and still make upwards of 300hp on moderate boost.chrismo240sx wrote:Hey guys, 1st off sorry to hijac this thread but theres a lot of good info so far for beginners.....would any of u reccomend rebuilding a ka first before boosting even if the compression numbers come up strong? and also, what is a decent size turbo to go with for a dd with 125*** miles and want 250-300 hp?
once again, sry for the thread jack man but i want to hopefully join the ka-t club as well soon! ...oh and yea i read the stickies at the top and whatnot but still confusing for me lol damnit, now its a long post. Sorry lol
