turbo2nr wrote:i have both of the fitting on the wastegate im using the one on the bottom for a vac feed for the wastegate not the one on the hat.
I do believe you need to be using the the top most fitting. More towards the end, or 'hat' as you describe it. I'm not familiar with external gates, but I'm almost positive this is your problem.
If you are 'boosting' pressure into the lower chamber of the wastegate, you are, in essence, 'pressing' the gate open from under the diaphragm. Causing yourself to bleed(waste) boost at such a low pressure. You're helping the spring open the gate.
Try switching to the top, or 'hat' side of the diaphragm. That might help.. The only time you use the bottom, is with a boost controller or something.
Anyone else reading this, does this sound right? Or am I up too early and need to go back to sleep??
