scir16v wrote:
I'd like to know this as well. I have it on the stand right now, but I'm going to be cleaning the timing chain covers, valve covers, and intake manifolds real soon. After that, I'm going to assemble and get hoses that are needed. I'd rather not spend unneccesary monies.
Honestly, I completely forgot about this thread. My apologies...
I don't have pictures, but I can tell you what I did.
- Rear ports on valve covers connected to crankcase vent in rear of valley.- Middle ports on valve covers connected to each other, nothing else.- Front ports of valve covers vented to atmosphere with filters.- PCV valve port on manifold capped.- IACV removed from rear of plenum.- IACV port below throttle body capped.- Fuel Damper port vented to atmosphere.- FPR port connected directly to plenum.- EGR Valve removed and blockoff plate installed.- All ports on throttle body capped.- Coolant lines on throttle body and ERG bypassed.- Idle set with throttle body stop screw at 800 RPM.
There may be other things, but this is the gist of it... car runs fine, much better than other vehicles with this amount of bypassing done. Once at operating temp everything runs perfect, only at cold idle are there any slight misses or hesitations.
Hope this helps!!
