evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 27, 2008 8:21 am
the best bang for the buck build IMHO would be a flat top F54 block, N24 Head, L7 cam, Tripple Webbers, and a Header, the carbs being the largest single expense used sets go from $500-$800, I think you can still get them new for around $1300
this is a common setup and tends to get in the 180-200 whp range, if you want more, you have lots of choices, you can do a 3.1 stroker, you can do a race fuel only 14:1 build, you can retain the stock stroke and run 240 rods with custom pistons for a more favorable rod angle, full balance and blueprint etc, the high cr and stroker builds to end to land in the 250 whp range with reports of high end 10k builds getting as much as 300 whp!
also if you can find them Nissan motosport used to make a dometop piston, they were cast and not to spendy, a bud located a used set for only a couple hundred bucks
