 Ingalls camber bolts p/n: 81250 - installation instructions are quite vague
Black R
type R
ATL
9-30-2003
Ok, so I have lowered my 1990 240sx xe coupe on eibach sportlines (yes the lowest springs).
I felt some vibration and wobbling in the steering of the vehicle for a long time now and in chasing down the problem, I started replacing things that looked worn in the front suspension.
I removed the front tension rods and replaced them with the adjustable TEIN tension rods.
I removed the torn outer tie rods and replaced them with new inner and outer TEIN tie rods.
I also removed the torns steering rack boots and used new napa ones.
BUT I'm still getting some vibration in the steering when cruising over 50mph. I definitely notice some has disappeared.
I also noticed that my tires are wearing out on the inside, so I decided to get a new alignment, but before that I went ahead and purchased some Ingalls camber adjustment bolts.
These bolts go in upper of the two bolt holes for the lower shock mounting point, and are supposed to give you +/- two degrees of camber adjustment.
http://www.ingallseng.com/parts/81250.htm
I installed with the bolt head oriented towards the front of the car, the arrow on the bolt head pointing inwards toward the motor, and the washer tab pointing away from the car toward the back side of the wheel.
According to the directions, this is supposed to give +2 degrees of camber (I'm hoping this will correct the negative camber from lowering the car).
Now, did I install the bolts correctly? I can't really tell a difference visually - to me it looks like there's still quite a bit of negative camber in the front.....
If it helps, I'll post up some pictures in a bit to show what I'm talking about.
Cone Junky
89 240 SX
San Diego CA
1-20-2008
 « Re: Ingalls camber bolts p/n: 81250 - installation instructio ... (Black R)
You need to let the alignment shop determine if the bolts worked well enough. Some negative camber is fine, in fact preffered for aggressive driving. Eyeballing the wheels is not enough, the car needs to be put on an alignment rack. Buying the bolts ahead of time was a good idea though. That way the alignment tech can make the necessary adjustestments.
Your tire wear and shaking is probably from the toe being way off. just about all the parts you replaced should have required an alignment when done.
San Diego Region Solo # 410
DTM & JDM
Still plays with cars...
matt4pl
cars, anything fast, graphic design, lots of stuff
Chicago suburbs
1-24-2003
 « Re: Ingalls camber bolts p/n: 81250 - installation instructio ... (Cone Junky)
the vibration problem makes it sound like you need your wheels balanced also. tires could be adding to the problem, too. i would get those things checked out while you're at it
ASE certified
whoflungpoo
1997 Silver Moss 240sx SE, 1992 vert LE
Murray Ky
7-18-2003
I experienced some vibration in my car as well, turns my tie rod end was shot. Replaced it and all is well.
I definitely need an alignment, but I'm not going to do it until I get my coilovers/camber plates installed
Happiness is like peeing your pants.
Everyone can see it, but only you can feel the warmth.
Black R
type R
ATL
9-30-2003
Yeah I just finished putting all this stuff on.
I just wanted to make sure I put the bolts on correctly before taking the car to the alignment shop.
Black R
type R
ATL
9-30-2003
 « Re: Ingalls camber bolts p/n: 81250 - installation instructio ... (matt4pl)
Quote, originally posted by matt4pl »
yeah i had the wheels balanced with new tires not too long ago..... I dunno - I'm hoping maybe it's just that I need hub rings for my wheels or something.....
But of course an alignment is getting done this week - I'm just waiting to put the new steering rack bushings on first.
2.4Loflove
1993 Nissan 240SX SE
the HIV GA
11-21-2006
not to thread jack or anything (searched for this), but I have too much negative camber and I'm running tein springs that lower the front about 1.6". These Ingalls camber bolts actually correct the camber if installed properly by a professional? Anyone else try them with success?
onosqv
Q to the V
'92 240sx Vert & '91 300zx TT
bewbews.com
8-7-2002
 « Re: Ingalls camber bolts p/n: 81250 - installation instructio ... (2.4Loflove)
Camber bolts will work just dandy to fix your problem - usually able to correct .5 - 1 degree, more or less (I think more toward the 1 degree range).
1.6" lowered, hahaha, that's cute, .
bew bews
2.4Loflove
the HIV GA
11-21-2006
 « Re: Ingalls camber bolts p/n: 81250 - installation instructio ... (brokeAs240sx)
Quote, originally posted by brokeAs240sx »
yeah, i know. it was just something to get away from the 4by4 look for right now. Once I get done being broke in college I'm going to get some Stance coilovers and drop it where i want it.
gumby74
San Antonio Texas
1-7-2007
The camber bolts work very well. I used them before I installed coilovers and use them still even with camber plates. I was able to adjust the plates out enough so that I have a true 0* and the hash marks actually have a reference value for me. Though I am quite pleased at 1.5* negative up front.
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
