fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: Spark Plugs...due for change? (Qxxx4) | 9:22 PM 2/16/2008 |
Yeah u should change them. Do it yourself. Its easy. The first 5 are childsplay, #6 just needs the special Nissan tool (under your rear seat with the tools) and you climb on top of your engine like a monkey, just follow the spark plug wire with your hand (cause you cant see it back there) And youre fine with old plug wires.
1999.5 Infiniti QX4 - Brembo brakes, Hawk pads, Eagle Alloys, Mudstar tires, KYB GR2, JWT intake 2000 Honda Civic 1.8T - smashin on V12's
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: Spark Plugs...due for change? (fueler) | 7:37 AM 2/17/2008 |
lol when i see "fueler" as a reply to one of my posts my face lights up lol you truly are an asset to this forum! thanks fueler for all your info on this forum
ubpsanity
2001 Pathfinder SE, 1999 Mitsubishi Eclipse Spyder
Kitchener Ontario
11-30-2007
| « Re: Spark Plugs...due for change? (Qxxx4) | 8:00 AM 2/17/2008 |
| Quote, originally posted by Qxxx4 » | | would canadian tire be a bad idea? |
Canadian Tire is always a bad idea. Well, I'm sure they do have a few good mechanics, but most of them are called monkeys for a reason. I'd go to a local garage where they pride themselves on the work they do. Or even the dealer, I like the dealer I use, Greg Vann Nissan in Cambridge.
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: Spark Plugs...due for change? (ubpsanity) | 9:08 AM 2/17/2008 |
but dont the dealers charge an insane price for any work done to the car? like if i were to ask them to change my spark plugs ALONE, i have a bad feeling theyd charge me well over $300....true? Id go to brampton nissan, and if its a myth that small service like this would be expensive there, id go instead. I dont really want to do it myself, Im just not comfortable with the idea, In autoshop in highschool, guys would literally snap the spark plug in the motor. scary stuff.
fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: Spark Plugs...due for change? (Qxxx4) | 10:19 AM 2/17/2008 |
The cheapest labor you'll probably find is ~ $75I wouldnt be surprised if the dealer wanted anywhere from $150 - $300 and guess what - you pay those prices, and its probably the first time that mechanic has ever changed the plugs on a VG33. They're in the same position as you - well, actually you have the upper hand since you already read about it on the internet.
Get your leather tool bag out from under your rear seat. Inside it are 2 specialized Nissan spark plug tools. The longer one is for plugs 1-5. The shorter one is for plug #6. This is where a shop would charge you even more - they dont know about the Nissan tools so they struggle to get plug #6 with extensions and pivot joints!!! Its much harder to get that plug without using your Nissan tool.
Good luck with whatever route you choose
KoukiS14
Pathfinder / QX4 Moderator
99.5 QX4 & 05 Saabaru 2.5i
Lafayette IN
3-31-2003
| « Re: Spark Plugs...due for change? (Qxxx4) | 1:36 PM 2/17/2008 |
| Quote, originally posted by Qxxx4 » | | lol when i see "fueler" as a reply to one of my posts my face lights up lol you truly are an asset to this forum! thanks fueler for all your info on this forum |
werd. . I dunno how I wound up as a moderator. . fueler is baller... We have a lot of awesome people here.
fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: Spark Plugs...due for change? (KoukiS14) | 11:01 AM 2/18/2008 |
AlabamaDan
94-Q45 98-QX4 88-Jeep XJ 4x4
Heart of Dixie
8-2-2002
I'd put changing plugs on the top of the list for learning to work on your car. For the most part it's just take the old one out and put the new one in. For this engine, it's not significantly different that other engines that any old time mechanic can work on. Just be careful not to overtighten the plug or your break the plug.You can inspect the wires and determine if they need replacing. Look for cracks or burnt spots. Same for the distributor cap.
Danny
 Done- Jeff Williams FSTB, Touring Rear Sway Bar, Valve Cover Gaskets, Fuel Filter, Spark Plugs, Brakes, Michelin Pilot Exalto 96V tires, Cleaned MAF, Cleaned Throttle Body, Cleaned EGR, Steering Rack Boots, Upper Links, Tokiko Blues, Boots and Bump Stops, Replaced Various Bushings, Mobile 1 Oil and Filter, BG-44K, Synthetic Fluid in Diff. Pending- Alignment, Transmission Cooler 1994 Black/Black Q45 150,500 miles 1998 Beige/Beige QX4 164,000 miles 1995 Black/Black J30 (RIP) 1997 Beige/Beige QX4 (RIP)
fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: (AlabamaDan) | 1:52 PM 2/18/2008 |
Exactly, thanks alabamadan. Qxxx4, if you are capable of changing your oil, then spark plugs is slightly easier (and less messy too)Its not like a Euro or American engine where the plugs are hard (or even impossible) to get at. They are right on top, like a Honda. It's fool proof. But I understand there are people out there who aren't so mechanically inclined. I have friends who dont even know how to take a radiator cap off (it took a group of 4 dudes SEVERAL hours just to get the radiator cap off, they almost hacksawed it, i cant believe it. ) They didnt know you have to PUSH DOWN as you turn. So if that sounds like you... i'd leave the plugs to the pros
bmlawless
1999 Infinity QX4
Boise ID
1-3-2008
| « Re: (fueler) | 2:54 PM 2/18/2008 |
| Quote, originally posted by fueler » | | Its not like a Euro or American engine where the plugs are hard (or even impossible) to get at. They are right on top, like a Honda. It's fool proof. |
I just changed the plugs on my 3.1L V6 1991 Corsica to get it to pass emissions. I can testify to the joy of accessing the plugs between the engine and the firewall. I did plugs 5 and 6 by feel alone. I was very happy to see how easy it was to reach the plugs on my QX4. Reminds me of my 2000 7.4L Chevy truck or my wife's 1983 1600cc VW Rabbit.
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: (bmlawless) | 4:31 PM 2/18/2008 |
ive done it all before, I took auto shop for 3 years in highschool, did everything from oil changes, to brake rotor machining, to oxyacetelyne welding. Its not that Im not mechanically inclined, im just terrified of something going wrong on my own car, i would rather pay someone else to do the work on it and have some kind of a warranty, than do it myself, make a mistake, and cost myself hundreds of dollars. But i did do spark plugs on a 4banger integra before in that class, it wasnt bad, I guess Ill look at the job myself when i get time (id say in a month lol) and see if i can do it myself. thanks for your help guys. And my wires seem ok, and i got a new distributor cap when I bought the car cuz the ignition went on it.
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: Spark Plugs...due for change? (Qxxx4) | 4:33 PM 2/18/2008 |
oh and by the way your tip on the tool for the spark plugs....exactly why im scared to do any work on my qx4, i always have those stupid little things that i DONT know, and waste tons of time figuring it out...but i do think i saw mention of it in the owners manual.
Pathfinder995
99.5 Nissan Pathfinder SE
Apopka FL
1-16-2008
| « Re: Spark Plugs...due for change? (Qxxx4) | 7:38 PM 2/18/2008 |
I agree with all the others - first 5 plugs were easy. #6 is tough and whoever said get on top the car like a monkey is dead on - that's how I got #6! Change them outside when it's daylight so you have illumination on your side. I'd pity the fool who had to try and get at #6 inside an enclosed garage. But seriously man, go by a Haynes manual for $15 and this gets a whole lot easier. You said you're scared about messing up - I agree with the person who pointed out than unless a Nissan dealer is doing the work, some chump mechanic is probably doing this for the first time as well. You can do just as good and you'll do better...why? because it's YOUR car. I would do the distributor cap as well if you're going to do the plugs and wires. $20 part from your dealer. -Jeff
litle88
burbank illinois
3-20-2008
| « Re: Spark Plugs...due for change? (Pathfinder995) | 5:11 PM 3/24/2008 |
I need help, I just changed my all spark plugs but the " #6" plug. I dont have that special tool! any advice as to how to change the last one? Any help will be greatly appreciated! PS dont mean to highjack a thread.
KoukiS14
Lafayette IN
3-31-2003
| « Re: Spark Plugs...due for change? (litle88) | 4:48 AM 3/25/2008 |
| Quote, originally posted by litle88 » | PS dont mean to highjack a thread. |
Hey we're not a bunch of dicks like some OTHER forums I'm not sure... I'm in the learning phase of this thing too. It took me a good 5 years to really figure out the 240sx. I think I have that tool, and can take a pic -- you positive you don't have it?
timmack
'02 Pathfinder SE
Gardner KS
8-26-2007
| « Re: Spark Plugs...due for change? (KoukiS14) | 6:07 AM 3/25/2008 |
i think that tool is only included with the qx4...might be wrong though. i wanna say that i heard that somewhere.
Issac
2002 Pathfinder, 1995 Q45
Portland Oregon
2-18-2008
| « Re: Spark Plugs...due for change? | 7:13 AM 3/25/2008 |
On the newer 3.5 model, there is no dreaded #6 by the way. I know this is not the thread, but it should be stated because I assumed it was going to be real bad on the 3.5 and it is not.
99QX4
Dano's Assistant
99.5 QX4, 07 G35
Long Island, NY
1-26-2003
| « Re: Spark Plugs...due for change? (Issac) | 7:32 AM 3/25/2008 |
Since we're on the topic of spark plugs, i had mine changed last week and 3 of my 02 sensors as well. Holy wow...it made such a difference, it is much more responsive. I had so much fun driving home just now as I flew past a 3-series BMW Although he wasn't accelerating, it just felt good to fly past somebody
slickroger
Nissan Pathfinder 2001
Brampton Ontario
1-6-2008
| « Re: Spark Plugs...due for change? (99QX4) | 9:31 AM 3/25/2008 |
Hey its about that time for me to change all my plugs check wires and maybe change the cap.If you want to hook up and do them when it gets warm Qxxx4 we can do that. i mean your right up the street son holla
Doin it for R50's Everywhere Check out my 2001 Pathfinder:http://www.cardomain.com/ride/3004068 NICO thread with some of my mods:http://forums.nicoclub.com/zerothread/350117
litle88
burbank illinois
3-20-2008
| « Re: Spark Plugs...due for change? (timmack) | 3:46 PM 3/26/2008 |
| Quote, originally posted by timmack » | | i think that tool is only included with the qx4...might be wrong though. i wanna say that i heard that somewhere. |
Yea I would appreciate it! Thanks I just want to know whats so special about it so I have an idea as to what I need to know. Thanks again!
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: Spark Plugs...due for change? (slickroger) | 4:21 PM 3/26/2008 |
hey man for sure! have you done it before? I did a spark plug change on an integra in high school. but it was a p.o.s and it was a 4 banger and it wasnt MY baby. but if i can do it myself with your help id not only save money id be proud. lol I trust my own work than someone elses anyways. When it gets warmer we will do it up for sure man. and for the record, i thought i read that the tool was under the rear seat with the jack? I think i saw a weird tool there before and didnt know what it was for
slickroger
Brampton Ontario
1-6-2008
| « Re: Spark Plugs...due for change? (Qxxx4) | 7:30 AM 3/27/2008 |
i havent checked for the tool yet so hopefully one of us has it. when its warm we got lots of things to do
Prozac
99 QX4, 03 G35 Coupe, 08 MB C300 4matic
Chicago IL
3-28-2008
| « Re: Spark Plugs...due for change? (litle88) | 7:11 PM 3/28/2008 |
| Quote, originally posted by litle88 » | I need help, I just changed my all spark plugs but the " #6" plug. I dont have that special tool! any advice as to how to change the last one? Any help will be greatly appreciated! PS dont mean to highjack a thread. |
I'm in West Chicago, a bit of a drive for you...but you can borrow my special sparkplug tools if you'd like to. I ended up buying them from a junkyard that scrapped out a QX4. If you wanna borrow them we'll just have to find a weekend day when I'm not driving all over the place and you can swing by. It's literally a ten minute job assuming you can get the spark plug wire off the plug. Mine were cooked on.
Adnan
2001 Pathfinder LE 4WD
Toronto On
2-13-2008
| « Re: Spark Plugs...due for change? (Qxxx4) | 8:41 PM 3/28/2008 |
I would definitly go for a plug changethats what i done this week with mine the motor is now fluid smooth,throttle response is much better as well as the mileage i know this chinese mechanic who charged me $150 mine is a 3.5 so pain in the *** to get it done
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: Spark Plugs...due for change? (Prozac) | 6:29 AM 3/29/2008 |
| Quote, originally posted by Prozac » | It's literally a ten minute job assuming you can get the spark plug wire off the plug. Mine were cooked on. |
In case mine are cooked on just wondering whats the best way to get them off? I heard of people snapping the spark plug in half, with the other half stuck inside the motor..what a nightmare!
Prozac
Chicago IL
3-28-2008
| « Re: Spark Plugs...due for change? (Qxxx4) | 6:58 AM 3/29/2008 |
I was lucky, and try this at your own risk, a big pair of pliers on the plug boot was all it took to get them off. The risk here is destroying the wires. If you bought new ones like I did then you should be okay...number six will make you sweat with the possibilities of what could go wrong.Do not try to pull wires off by the wire itself...always grab the boot.
litle88
burbank illinois
3-20-2008
| « Re: Spark Plugs...due for change? (Prozac) | 12:25 PM 3/30/2008 |
Thanks guyz, I have changed the plugs and boots 1thru5 I was just wondering if anyone had changed them with that damn tool! Prozac thanks for the offer! If I cant get it out I will take you up on it sir .
InfinQX4
2000 QX4
Chandler AZ
3-29-2008
| « Re: Spark Plugs...due for change? (fueler) | 11:25 PM 3/31/2008 |
So I know this has been going around - But d**m I can't find the #6 tool...Only thing left under the seat is the jack stuff. As I bought from an Infinti dealer, any one else want to bet they took it just so I would go back and have them replace the plug$?Any other option? And general feeling no need to change the wires?
Prozac
Chicago IL
3-28-2008
| « Re: Spark Plugs...due for change? (InfinQX4) | 5:35 AM 4/1/2008 |
 These are the tools that should be under the seat. The long and short tubes are for the plugs...the short one is the #6 tool. The curvy metal rod is the crank for the tools.
Issac
Portland Oregon
2-18-2008
| « (litle88) | 7:43 AM 4/1/2008 |
Your picture of a girl in a defenseless sitation aint cool. Suprised you can put that up.
InfinQX4
2000 QX4
Chandler AZ
3-29-2008
| « Re: Spark Plugs...due for change? (Prozac) | 8:18 AM 4/1/2008 |
Thanks for the picture! Confirms I don't have them, but now I know what I'm looking for.
fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: (litle88) (Issac) | 1:13 PM 4/1/2008 |
| Quote, originally posted by Issac » | | Your picture of a girl in a defenseless sitation aint cool. Suprised you can put that up. |
wheres that pictuer at
timmack
'02 Pathfinder SE
Gardner KS
8-26-2007
| « Re: (litle88) (fueler) | 1:26 PM 4/1/2008 |
| Quote, originally posted by fueler » | wheres that pictuer at |
in litle88's post, under his name, same place where you have the dude standing outside the building. i got a fiddy that says she likes being tied up like that
fueler
Online
1999 QXFO
Cow Patty BAJA
1-16-2007
| « Re: (litle88) (timmack) | 1:31 PM 4/1/2008 |
now i see! Heres just in case you guys cant see mine, that aint no building thats under a bridge
taken from http://www.youtube.com/watch?v=cyCtAXetPYM "I ride with the best cause i come from the west"
jcpathy69
Newport AR
1-28-2007
| « Re: (litle88) (fueler) | 1:57 AM 4/2/2008 |
I'm at 43k... Would it be worth the hassle to change mine out? I'm desperate for better mpg's, 15 is killing me with a 100 mile commute every day!
 03 Pathfinder LE 4x4 !!!FOR SALE!!! http://forums.nicoclub.com/zer...d=144
Transtek
2001 Nissan Pathfinder
Mexico DF
3-26-2006
| « Re: Spark Plugs...due for change? (slickroger) | 9:00 AM 4/2/2008 |
You w| Quote, originally posted by slickroger » | | i havent checked for the tool yet so hopefully one of us has it. when its warm we got lots of things to do
| on't have the tool 'cause you've got the 3.5L engine, whereas only the older 3.3 needs it. BTW the 3.5 doesn't have plug "leads", it has a coil screwed directly on top of each plug.
slickroger
Brampton Ontario
1-6-2008
| « Re: Spark Plugs...due for change? (Transtek) | 9:39 AM 4/2/2008 |
so this thread is refering to a 3.3L engine the whole time. I have a 3.5L is the spark plug change easier to do on a 3.5L. or is it a different process what the ?
Transtek
Mexico DF
3-26-2006
| « Re: Spark Plugs...due for change? (slickroger) | 10:43 AM 4/2/2008 |
I wouldn't say easier, but it should be okay as long as you are methodical and patient, as several parts have to be removed to change them. BTW only install new OEM plugs, which are platinum-tipped HGK PLFR5A-11, which should be good for around 100,000 miles, although I change mine every 50k.
W O T
Milton on
9-12-2007
| « Re: Spark Plugs...due for change? (Transtek) | 10:52 AM 4/2/2008 |
heys guys, you 2 from brampton, im from milton (20 min west) and was thinking of doing my plugs on my 01 qx4 3.5 aswell. You guys get to it yet ? Ive never even looked to see where my plugs are before since ive never had any troubles but Im at 100k now so I should probly do them.I guess I gotta see if I have that tool or not. And someone mentionned are plug WIRES dont even just pop off, there screwed into the plug???? Weird
| First 1 2 > Last |
