Chevy 305 V8 swap to nissan running gear
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
ownedhard
Car: 1989 D21 hardbody
I have a 1989 nissan Hardbody ( D21) with a 2.4 L 4cly with a 5 speed man trans, 4x4,married transfer case,
I am doing a engine swap to a small block chevy (305 V8). The 305 v8 was pulled out of a 1987 El comino with 68k orignal miles and a 4 speed man trans
Does anyone have any idea's on how i can adapt my nissan transmission and transfer case to a small block chevy engine. is there any place where i can purchase an adapter plate to adapt my nissan trans to a chevy motor?
i just pulled the stock Z24 out of my truck last night along with the trans. and this weekend i am going to drop i nthe v8 with a turbo 350 trans. does anyone have any ideas i can use to mount the trans to the nissan D21 hardbody frame?
Modified by ownedhard at 11:05 AM 2/15/2008
Blown240sx
Car: 1996 240sx
You can find an adapter plate or have one pade by a machine shop as long as they have the right measurments. Now I dont know about the input shaft though. You might have to have a custom spline if its not the same spline count.
Davidss
Car: Z06/S2K
What about a 4x4 chevy transmission and transfer case?
ownedhard
i don't want to run a chevy transmission and transfer case. then i would have to change drivelines, mounts, ect.
craigztoyz
But you will blow that 5spd up sooner than later. Unless you don't really use the engine's torque.granted a 305 has a max of about 220 ft Lbs, but that trans and case were never meant for the torque the chevy makes
ownedhard
good thinking, i think im going to go with a turbo 350 transmission. should i get a married transfer case or a non married transfer case?
guilty1
Car: 2000 eclipse, 86.5 hardbody, 93gsxr600/1100, sportster chopper
hows the swap going?? have you run into any clerance probs? getting ready to do the same thing, just finished rebuilding a chevy 305,(30 over pistons, cam, gear drive head redone ect.) going to try to make an adapter plate for chevy to nissan trans. if i do have to go to a chevy 350 turbo i will have to also get a transfer case out of a s-10 or s-10 blazer, that puts your front drive shaft on the correct side.
guilty1
oh yeah, i'm not too worried about blowing up my nissan transmission, just going to be a road truck, avanced adapters have been making chevy to toyota adapter plates for years. you can mess up ANY trans depending on how you drive. i don't plan on off roading.
craigztoyz
I've used Advanced Adapters numerous times, good parts. I like some of their engine mountings.
If you do go with a chevy trans(highly recomend it) why a 3spd 350, not a 700r4? The 700 has a much lower first gear, and a great overdrive, and hooks up just as easily, a bit longer though. s/10 parts are not made strong enough for a v8, can be modified to last longer, but......
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
TH350 vs 700R4 has been debated many of times. The can both take a beating, depends if you want the OD or not, but the TH350 allows for harder launch but the top end ratio sucks.
But I have a TH350 on my LS, it holds just fine
WDRacing
A recent article I read in Car Craft or Hot Rod said the 200-4R is also a very good transmission to work with and can be found in a lot of late 80's RWD GM platforms. Price and number available are said to make this a great choice. I have no actual experience with it, nor have I priced or looked for one. Just thought I'd toss that into the option hat.
Anyone have any data on that transmission?
mikelyon01
Car: 89 nissan hardbody
hey ive got the same exact truck and im dropinng a 350 small block in it too......... i had a couple of questions like ........was their any clearence issues with any thing .... and what engine mounts did you use or did you make you own?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
cheby motor and trans with a 720's divorced transfer case
captainswol
how'd your swap go i got an 89 with the z24 also but mines 2wd i got a 305 i could put in but am worried most about wiring issues and what rearend to use any help on this
apocolypse_now
Car: 1987 D21 4x4
1991 D21 4x4
Im gearing up to do a 350 swap into my 87 D21 4x4. Anyone got any more info? howd you fit your motor mounts? oilpan clearance on the front dif, firewall mods...transmission supports.. iv got loads of questions. stoked for this build.
Thanks
Return to “Hybrids”
