I used a tyre wrench or what ever, it has a Sharp tip that i used to put it inside one of the flywheel`s teeth
Then (i dont know if ur engine has it but...) the engine block has a lil thing, a tube or something inside its block, on the exhaust bottom side, a bellhousing bolt goes in there, sooo i used the tyre wrench (i was untightening so i put it on that side so when someone tried to untight the flywheel it Grabs the teeth and the lil tube and nothing moves
Heres a pic
Then get someone to just untorque the bolts It wont move, i tried it and it worked GREAT screwing and unscrewing! and im a skinny guy!!! Woot Woot , We did the dissasembly in 2 hours and the assembly in 45 mins
Trying to explain... if u get under the car and try this ull understand what im saying... btw if u dont have the lil tube thing, just put a bolt in there, and boila a jamming spot
Thank u and have a nice day
