difference in transmission's?
DS13
Car: 90 240sx hatchback
is there any major differences between a sohc and dohc transmission? because im planning on going to picnpull for a clutch pivot ball studd but i have a dohc and the car ima pull it from is a sohc so would i be wastin my time?
Modified by DS13 at 6:49 PM 2/7/2008
murda-c
Car: 1996 s14
transmission? F-M or M-F
DS13
transmission hahaha
tramp_drift240
Car: 1992 240sx SE Coupe
transmissions are the same, im currently using a sohc transmission with my dohc motor i swapped in over summer.
should be straight
DS13
sweet i hope the car is still there this weekend in that case
tramp_drift240
im crossin' my fingers for you, im a big fan of pick and pull junkyards.
DS13
dam it! the guy i was supposed to go with has to work the whole weekend but ima still try and do it myself WEAK
tramp_drift240
you can still do it yourself, dont worry about it.
MAN UP, SON.
formulaSX_kris
Car: 1992 nissan 240sx twincam hatch
i dont think so ? i have a dohc transmission with my sohc motor with a twin cam clutch everything was fine..
tramp_drift240
...you have a single cam in your car?
and this question was already answered by yours truly.
DS13
okay so i went to picnpull and spent a good 4 hours for NOTHING i got all the bolts out and disconnected the drive shaft and the dam brace thing wouldnt unbolt! i need a breaker bar so to picnpull again tommorw i hope to finally get my part
lofapoo
Car: Toyota sedan
Brace, as in the carrier bearing in the center of the driveshaft, or the transmission crossmember towards the tail end of the transmission?
Either way, PB Blaster is your friend. It has never failed me.
DS13
transmission crossmember and wat is (a) pb blaster?
lofapoo
Car: Toyota sedan
PB Blaster is a penetrating oil on crack.
Unless the bolt is stripped, blast it with PB Blaster and wait a few minutes so it can soak in. Throw in a wrench and a cheater bar and that ****er WILL come off unless it's welded there.
The crossmember should only be held on by four bolts to the frame rails. Not too bad. Just don't cheese the bolt heads, cause then you'd be ****ed.
DS13
where could i get this so called pb blaster
keith0486
any auto parts store should carry it
DS13
word thanks!
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
DS13
sweet i got the part it felt so stupid droppin the transmission just for that little bolt
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
you should of just took the whole thing, who know when you might need it
DS13
i wouldve but my dad needed money for rent so now my card gets rejected when i try to put 2 dollars worth of gas
