PBfrEAk
I less than three VG's
'00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
Edinboro for school, and Butler PA
9-16-2004
| « Re: VG30DE into S13 (EvillE423) | 10:00 PM 2/3/2008 |
This place may not get much traffic but the knowledge in here surpasses all.  Alright so as far as a VG30E is concerned...its been done by a few people I believe (namely FoxFire). From what I know, there should be plenty of room in the s13 engine bay for the VG. Width and length is no concern of your's. What is however is height. The DOHC is higher which would cause you to have to fab up your own hood or buy a cowl if they make them for the s13. As far as other major mods...I'd say motor mounts, maybe tranny mounts, and more than likely a custom driveshaft. That should get you going at least.
mtcookson
Supporting Member
Howard KS
11-21-2002
Actually the only thing you have to worry about when trying to swap the DE in, fitment wise, would be the width. It'll be shorter and lower than an inline 4 so you just have to worry about the width being that the VG30DE(TT) is extremely wide.Now... we know its actually been done in the past so width shouldn't be much of an issue. One problem you'll likely run into is the KA24's had a front sump oil pan (if I remember correctly). The VG-DE has a rear sump pan stock which will likely cause problems. There might be a slightly chance you could use the front sump oil pan from a VG30E as I'm pretty sure the bolt pattern is the same but the pickup tube might not be able to swap from an E to a DE. I'm working on a project right now that might answer that question but it may be a little while before I'll know. Like Cody said, the motor mounts will have to be custom as well as tranny mounts as you'll probably be using the Z32 transmission. Transmission wise you may actually contact Mazworx (www.mazworx.com) as they do have a kit to bolt a Z32 5-speed to an SR in a S13 and S14 chassis. They may be able to provide you with the parts needed simply for the 5-speed into the S13 chassis (driveshaft, shifter, shifter bracket, transmission mount/bracket, etc.) The only thing you'll need to worry about is engine placement due to where the tranny is... though it should still be closer to the middle of the car than the I4 would be, just depends how far the tranny sticks out. From there you have to deal with the wiring. There should be a few wires in the VG harness that you'll have to splice into the 240 harness. The tach will need to be modified (I believe you can take it apart and adjust for the new RPM signal to read correctly for the V6). That's all I can think of at the moment. I've still not seen any good documentation on how to do the swap so a lot of it is stuff you'll have to figure out along the way.
Aaarrrrrrrr... Aye approve of this message
edgartheace
1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
Compton CA
9-27-2006
| « Re: VG30DE into S13 (EvillE423) | 7:06 AM 2/12/2008 |
I'm working on the same thing, basically you will need the Oil pan from a J30 since the J's are front sump, You will need to notch the sub frame a bit, and custom engine and tranny mounts, and Drive shaft. Look at what this guy did to get an idea of what it will look like when done. http://forums.nicoclub.com/zerothread?id=187589
PBfrEAk
9-16-2004
| « Re: (mtcookson) | 11:52 AM 2/12/2008 |
| Quote, originally posted by mtcookson » | | Actually the only thing you have to worry about when trying to swap the DE in, fitment wise, would be the width. It'll be shorter and lower than an inline 4 so you just have to worry about the width being that the VG30DE(TT) is extremely wide. |
Ahhh...well thank you for that info. Apparently I need to actually work with a VG-DE before I claim to know lol. It makes sense though, it would be so much higher as it would be wider because the block IS in a "V" shape being a V6 and all.
jay-spec013
Chicago il
11-3-2008
I don't see what so hard about this swap, I mean get a Z32 Xmember which bolt right up to the S13/S14. The think the N/A Z32 uses the the same transmission as the S13 so just do a simple bellhousing swap. We already know the motor fits, apparently better than the Z32. I saw something about notching the frame, but for what the exhaust? I have done a search I found so useful info, but I' am just wondering if the Z32 Xmember is swappable and the N/A trans is identical(internally) what makes this so hard. Please people what I' am I missing here. I know obviously its not that easy or it would be more common. So what I' am I missing guys?
 ------------------------------------------------------------------------------------------------------ http://chicagosprinters.freeforums.org/
edgartheace
Compton CA
9-27-2006
| « Re: (jay-spec013) | 2:33 PM 11/12/2008 |
The tranny mounts are the same if you keep the auto but the manual needs a custom mount, also the Z32 crosmmember is wider than the S13 by about 2 inch's if I remember correctly. It's not difficult to drop in just all the fab work that needs to be done is a real PITA.
FoxFire
90 vg30eT 240SX, s12 vg30e
mesa az
6-28-2006
| « Re: VG30DE into S13 (PBfrEAk) | 4:19 AM 11/18/2008 |
| Quote » | | Alright so as far as a VG30E is concerned...its been done by a few people I believe (namely FoxFire). From what I know, there should be plenty of room in the s13 engine bay for the VG. Width and length is no concern of your's. |
thanks i wish i was done
anyways..
a vg30DE will be one hell of a ***** to fit. the heads are huge and there wont be much room to fit the headers. forget a side mounted turbo and think HUGE hood cowl the vg30E fits with 22inches to spare from the back of the radiator to the front of the crank pully.(with engine 1 inch from firewall) it has about 5 inchs from the side of head to strut tower on both sides. the rear oil pan also fits but comes real close to the power steering rack lines where they go in the rack. it will fit. do it. but you should be prepared to do a ****LOAD of research, and you should have almost every tool known to man in your garage before your start. just get drunk and test fit the engine. it will give you an idea on what needs to be done.
FoxFire
mesa az
6-28-2006
| « Re: VG30DE into S13 (FoxFire) | 4:21 AM 11/18/2008 |
and wtf is up with ****** and cuss words? its bullshiet
PBfrEAk
9-16-2004
| « Re: VG30DE into S13 (FoxFire) | 4:15 PM 11/20/2008 |
So how is that project coming along?Do you have a build thread? If you don't you should start one!!! Are you running just a stock VG or did you mod it at all?? I can't remember.
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: (jay-spec013) | 7:09 PM 11/25/2008 |
| Quote, originally posted by jay-spec013 » | | I don't see what so hard about this swap, I mean get a Z32 Xmember which bolt right up to the S13/S14. The think the N/A Z32 uses the the same transmission as the S13 so just do a simple bellhousing swap. We already know the motor fits, apparently better than the Z32. I saw something about notching the frame, but for what the exhaust? I have done a search I found so useful info, but I' am just wondering if the Z32 Xmember is swappable and the N/A trans is identical(internally) what makes this so hard. Please people what I' am I missing here. I know obviously its not that easy or it would be more common. So what I' am I missing guys? |
Exactly! I'm doing the VG30DETT swap in mine. Just got the motor today. We already figured I'd need the xmember, so I got one.
Never meddle in the affairs of dragons for thou art crunchy & taste good with ketchuphttp://www.myspace.com/importdragon240
boostedc10
89 240sx
Chattanooga Tn
8-15-2007
| « Re: VG30DE into S13 (EvillE423) | 8:30 PM 11/26/2008 |
im seriously considering doing this swap. but with a vg30dett.. ive done my fair share of research but havent found anything about the gauges. my car has the hud setup. so what are the chances ill be able to keep my stock speedo and tach?
mattminer
Narragansett RI
3-11-2009
| « Re: VG30DE into S13 (EvillE423) | 10:09 AM 4/22/2009 |
whoomp her eit is
:P
M@
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: VG30DE into S13 (mattminer) | 11:08 AM 4/22/2009 |
What cross member did you use? We've tried the z32 as well as J30 and know they won't work, so I'm looking for an M30 xmember. I've got the Vg30dett motor that I'm working with.
Modified by importdragon240 at 2:24 PM 4/22/2009
mattminer
Narragansett RI
3-11-2009
| « Re: VG30DE into S13 (importdragon240) | 11:16 AM 4/22/2009 |
modified s13M@
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: VG30DE into S13 (mattminer) | 2:25 PM 4/22/2009 |
Ok cool. What all did you have to do? Was it hard to do?
mattminer
Narragansett RI
3-11-2009
| « Re: VG30DE into S13 (importdragon240) | 6:21 AM 4/23/2009 |
I can take some pictures. The way it is now, the TT manifolds bolt right up and clear too.The Z tranny is mounted in with a modified Z tranny bracket to the stock 240 location. The new mounts or the VG are built off the s13 crossmember. Had to run a oil filter relocation kit due to clearance. Also a new bracket for the alternator had to be built. M@
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: VG30DE into S13 (mattminer) | 7:37 AM 4/23/2009 |
Damn lol. Well I'm gonna try the M30 xmember approach. But would still like to see pics if ya got any to share. Btw, where ya located?
mattminer
Narragansett RI
3-11-2009
| « Re: VG30DE into S13 (importdragon240) | 8:18 AM 4/23/2009 |
yeah ill have alot of pics soon, i have a leaky rear main and im goign to replace the clutch so im going to be under there.in in RI M@
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: VG30DE into S13 (mattminer) | 8:43 AM 4/23/2009 |
I found a J30 that I'm buying this weekend thathas most all the parts I need for most areas of the car with the exception of the xmember. Then parting out the rest. May already have someone who wants the motor but not sure.
SxMachine
Online
Drifting, girls, and drifting on girls
Atlanta, from New Jerz
12-25-2002
| « Re: VG30DE into S13 (importdragon240) | 3:14 PM 4/25/2009 |
| Quote, originally posted by importdragon240 » | | What cross member did you use? We've tried the z32 as well as J30 and know they won't work, so I'm looking for an M30 xmember. I've got the Vg30dett motor that I'm working with. Modified by importdragon240 at 2:24 PM 4/22/2009
200sx cross mem bolts in2 the s13 i belive.
Project 72' Datsun 510 vg30ett almost complete (yes SOHC wit TWO TURBOS!) 90' s13 (sr red) VW mk4 1.8t daily Lookin 4 my dream b13 nxt!! Holy Hi insurance rates batman!!
cypherbane139
85 300zx
sunnyvale ca
5-1-2009
i love projects like these... the car your putting it into had a 4 cylinder right? aluminum block? you'll have to get stiffer springs to support the extra weight i belive
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: (cypherbane139) | 12:24 PM 5/3/2009 |
Yeah it had a ka24. I've already got a full D2 coilover set on. Bought those right after I got the motor. Now I've finally got the J30 here to part out after I use parts off it for part of the swap, and POSSIBLY the 5 lug conversion if it'll work. But I'm still trying to find an M30 cross member.
Modified by importdragon240 at 9:10 PM 5/3/2009
jonas92
90 240sx
lexington nc
8-3-2009
| « Re: (edgartheace) | 10:10 AM 11/14/2009 |
how much sp;icing is needed cuz thats about the only thing im worried about
Wc240
89 240 97 200sx
Sac CA
5-12-2009
| « Re: (importdragon240) | 9:47 PM 11/19/2009 |
i know this thread is old. but i am dead set on this swap. i cant roll the rb25 anymore becouse i got my smog license. this swap can be smog legal. wich is great news for ALOT of peaple. i did have some questions for the guys who have completed this. 1- besides modifying the s13 xmember, did anyone try the m30 one and what didi you find? 2- what did you do as regars to the clearance of the steering column? any info would be great.
You can get much farther with a kind word and a gun than you can with a kind word alone. - Al Capone Nor-cal240sx.com http://www.aa1car.com/obd2help/
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: (Wc240) | 7:05 AM 11/20/2009 |
Dude, I sent ya an email at ur hotmail account. Go check it out. Hit me up when ya can.
MICRoS13
Online
89' fastback
NY
4-16-2009
| « Re: (importdragon240) | 6:37 AM 1/23/2010 |
dude send me an email to ! i did most of the research i wanted to see it picture by picture but yeaa... my email is E.Gourdet@yahoo.com my email on this account i don't use anymore
MICRoS13's VG30DETT S13 Build
importdragon240
1989 Nissan 240sx
Saint Augustine FL
11-21-2008
| « Re: (MICRoS13) | 8:23 AM 1/23/2010 |
Who u wanting to send u an email? Me?
MICRoS13
Online
89' fastback
NY
4-16-2009
| « Re: (importdragon240) | 6:38 AM 1/24/2010 |
Yessir unless you were giving Wc240 non related info to this swap ?
JDMZ32
1991 Nissan 300ZX (NA Slicktop)
Auburn/Montgomery AL
1-14-2008
| « Re: (MICRoS13) | 10:23 AM 1/27/2010 |
My friend's MySpace display name is "M@" and his name is Matt Reimer. I saw "M@", looked at your username, and needed a doubletake when I saw "mattminer" haha.Great project! VG power FTW! NA sucks though, but surely it's better in the lighter chassis...
-Stephen
 FS: http://forums.nicoclub.com/zer...luded Head unit. Interior thread: http://forums.nicoclub.com/zer...erior Car Domain (updated 10-11-2009): http://www.cardomain.com/ride/2875480
