i was thinking the same thing...dam* our car need some springs bad!!!! can't wait, only 4-6 more weeksCoupeSlate wrote:NICE!!
haha on a side note some of the pic make it look like its a hot-wheels toy
TRUE ALL TRUE<< IM DA 20"INCHER LMAOYEA THE TIRES RUB WHEN HITTING BUMPZ AND WHEN GOING UP INCLINES CURVED ON RAMPS!ITS A HORRIBLE NOISE AND I FEEL BAD BECAUSE I FEEL LIKE IM HURTING MY CAR lONG DRIVES ON THE FREEWAY SUCKI DONT KNOW IF ITS JUST MY WHEELS BUT WHEN I HIT 75+ IT SHAKES ALOT! TO THE POINT WHERE I DONT WANT TO TAKE MY CAR ON LONG TRIPS ANYMORE. BUT THEN AGAIN I HEAR THAT OTHER PEOPLE ARE HAVING THE SAME ISSUES SO I DONT KNOW WHAT IT COULD BEi DONT SUGGEST DROPPING THE CAR IF YOU HAVE 20'S BUT TO EACH HIS OWN !......rjdmmfl1 wrote:Yo, I just realized that those are RWD rims you put on the coupe. Like +24 offfset right? Good luck dropping those bad boys.. we've been debating back and forth on this forum what the ride will be like with a 1" drop.
We've crunched the numbers, but nothing will really tell until someone actually puts the springs on. Eduardo on this forum has +35 offset, 20 x 8.5" wheels with 245/35/20 tires. And he states that he has slight rubbing in the rear when hitting bumps or when going up inclines curved onramps.
You wheels stick out about 1.5 " more than stock, so clearance, after a 1" drop when going over bumps is going to be questionable. It all really comes down to how stiff the eibach springs end up being, but my bet is that your car will not survive a drop without having rubbing issues when going over bumps. (for the rear only, front should be fine!) But hey, we'll all see in a couple of months!
edonissan13 wrote:I DONT KNOW IF ITS JUST MY WHEELS BUT WHEN I HIT 75+ IT SHAKES ALOT! TO THE POINT WHERE I DONT WANT TO TAKE MY CAR ON LONG TRIPS ANYMORE
18x9.5's Holy Crap, I didn't realize you can stick that on the coupe. Although it does stick out a bit, it looks really nice! Let us know how it works out when you drop itAlaron wrote:The wheels are 18x 9.5" and the tires are TOYO FZ4's (245-40-18).....They do stick out a bit Ursus but I like the lines .. makes them look way meaner than the relatively wussy stock wheel offset.
hub centric rings FTW. $20 upgrade that will help amazingly. Also a weight could have fallen off. Wheels like that are going to use stick on wights and if the area they are attached to isnt cleaned precisely they will fly off at the first 80+ you hit.LongBeachCoupe wrote:balance or "hub centric" thingies... i dont have them in my wheels though
Yes my friend, the arch does stand for architecture. I'm a project manager at a small firm in NJ. And yes, us architects enjoy Nissans as well as the next guy, although not as much as I enjoy pulling all nighters. My record is 72 hours without one second of sleep (prepping for a crit of course). Try driving after doing that, you see weird things like grandmas flying in front of your car and massive holes in the pavement.Alaron wrote:I play a lot with depth of field and hdri Rwu, its awesome that you caught that! Does the arch in your screen name insinuate architecture in any way? It would make sense then, being an Architecture major myself
+24 huh?...Well now...Seeing those wheel's dimension on your coupe opens a whole new world of possibilities. Yes, they do stick out a little but not so much that it looks .... And actually I do agree with you that it give a coupe a stance. I like it!Alaron wrote: the wheel offset is +24mm, iffy at best I know, but they seem to work fine and I've had absolutely no rubbing at any angle or speed so far.
Yeah, I mentioned this a few posts up... in any case, I don't even think I factored in the increased rim width and time size, all of that matters when factoring in exactly how much the wheel/tire combo will stick out from mounting hub compared to stock. In any case, yeah its about an extra 2", and as I mentioned, I seriously doubt this car will survive a 1" drop. I think its gonna be hell going over bumps, but we won't know for sure until the springs come out!dangeris wrote:OK,..is it me but I've been doing the math on the wheels that Alaron bought and at 9.5" wide +24 offset, that wheel extends out 46mm MORE than stock. That's almost 2"! I went out to my car and pulled a ruler out and placed it in front of our stock alloys and tried to "eyeball" approx. 2" out. I have to tell ya guys that 2" really sticks out there but looking at his pics that he posted, it doesn't look like they stick out that far. Is it me or am I placing the ruler on the wrong edge. According to the offset calculator, it would extend an extra 46MM from the front edge of the current wheel.
Thoughts anyone?
rjdmmfl1 wrote:but we won't know for sure until the springs come out!
