 1992 Sentra SE-R transmission 5spd pops out of 5th gear
1992sentraser
1992 Nissan Sentra SE-R
Raleigh NC
2-2-2008
My transmission has been giving me trouble for quite a while with 5th gear and now it will not stay in gear.
Is there an easy fix for this transmission? Is it something I can do myself? I called a few transmission places and they never heard of the transmission and will not work on it because it is so rare.
Please help if you can.
thank you,
RED_DET
Super Moderator
2004 6 speed G35 Sedan, 2002 Sentra SE-R Spec V, 1992 Nissan Sentra SE-R SR20DET
Louisville, KY
5-13-2003
 « Re: 1992 Sentra SE-R transmission 5spd pops out of 5th gear (1992sentraser)
It was bound to happen sooner or later with the 91-93 se-r. The fix will cost as much to buy a good used transmission. Preferably one from a 95-97 200sx se-r so that you won't have that problem again.
Factory Service Manuals can be found here
1992sentraser
Raleigh NC
2-2-2008
 « Re: 1992 Sentra SE-R transmission 5spd pops out of 5th gear (RED_DET)
Thank you for the advice.
Will a transmission out of a 95 - 97 200sx se-r really work? Will it bolt up the same or will I have to do some modifying?
thanks again for your help.
RED_DET
Super Moderator
Louisville, KY
5-13-2003
it bolts up directly just as the 92-96 g20t transmission. you can also use the b15 and 99-02 g20t transmission, but those require you to switch over from hydraulic to cable. your best bet to keep the same gear ratios is the 200 sx se-r, the drive train is the same. the only modification is you have to switch the speed o sensor out to your mechanical one, which is simple when both transmission are right in front of you.
1992sentraser
Raleigh NC
2-2-2008
thanks again for your help. I have been looking for a tranny, but have not found anything as of yet. I am trying to stick to the 95 -97 200 because I don't want to go through this again.
thanks again,
Didderson
1990 240sx fastback sr daily.
Harrisburg/Lancaster PA
3-18-2006
Hey guys I wanted to ask this here sorry for the interjection.
I'm converting a GA16de to manual and wanted to know if the speed sensor on my 92 auto would be able to fit in the xx manual trans? Or do auto's have some different sort of sensor?
Thank you! Do the GA transmissions have this 5th gear problem too?
KA24E (SOHC) ECU 4 sale
Version 1 s13 build RIP, "The Mad Hatter" B13
VERSION 2 White Elephant SR20 Build '09!
brezzie
b13
dixon ca
6-8-2009
hey I would like to know if that would work with the ga16 as well?
RED_DET
Super Moderator
Louisville, KY
5-13-2003
I don't know if they manual sensor and auto are the same. Easy way to find out is compare them.
No the GA doesn't have the 5th gear issue.
dmp316
1992 Sentra SE-R
Homestead FL
4-28-2009
Quote, originally posted by 1992sentraser »
thank you,
<IMG NAME="icon" SRC="http://images.nicoclub.com/forums/images/smilies/bash.gif" BORDER="0">
yes like said get you a B14 ser or B15 SE or P11 tranny. B15 and P11 trannys are a hell of alot stronger then B13 and B14 trannys. you can buy the 5th gear pop kit if you do not want ot cannot find another tranny
http://gspec.com/p-7307-5th-gear-pop-out-kit.aspx
ABNRML4U
NISSAN B-13
Tampa FL
4-6-2009
 « Re: 1992 Sentra SE-R transmission 5spd pops out of 5th gear (dmp316)
NismoG20T
NY NY
6-20-2009
92 b13s are known for 5gear pop outs
brezzie
b13
dixon ca
6-8-2009
 « Re: 1992 Sentra SE-R transmission 5spd pops out of 5th gear (NismoG20T)
I have the same issue with my 91 sentra , I will try to put in a 95 or 97 lioke you guys say.....
» Return to Sentra Forum / Infiniti G20 Forum / NX Forum
