Dano
Administrator (CAO)
'95 240sx base/ '87 BMW 325iC
Kansas City but miss Phoenix
10-29-2002
That's awesome, I love it, and can't wait to see you do more.BUT: If you do a red dome light, your retarded. Do all your switches and gauges and whatnot in red, do the interior light in WHITE. Practicality as well as aesthetically it's better to do it. I'm serious Ryan, don't do red. Keep up the good work though, i'm curious to see your 'switch area' illumination. My auto button has never lit up either...
 National Association of Storm Chasers And Spotters MEMBER -- AIM: s14sx2nr Love you Stace! Enjoy your wings!<3<3<3
float_6969
1990 Nissan 240sx Coupe
Topeka Kansas
8-26-2002
NO RED DOME LIGHT! I promise. I had no intention. I'd like to add the map lights as I don't have them and then also add the foot well illumination too. Those would all be white. I guess if it gets the Dano seal of approval, then I'll continue with the conversion. If you want me to, I can fix your light in your switch. I found the regular incandescent bulbs online, or I could do it with a LED. The only potential problem with the LED is that the color MIGHT not match the rest of the interior. Since It's so isolated, I doubt you'd notice.
Dano
Administrator (CAO)
10-29-2002
Wanna do my climate control too? I've been meaning to for some time but having had the time.
float_6969
Topeka Kansas
8-26-2002
Yea, no problem. I'll probably do mine first, so I know which LED's to use and then I can bring them up there and do it all at once.
KoukiS14
Pathfinder / QX4 Moderator
99.5 QX4 & 05 Saabaru 2.5i
Lafayette IN
3-31-2003
| « Re: (float_6969) | 3:59 AM 2/4/2008 |
Pretty damn cool I'm playing around with something similar, and adding the red ambient lighting that shines down on the center console area. . the Pathfinder / QX4 has a small piece that's ideal for this, and if it doesn't work I won't care.
Mauibuilt Guy
1997 240SX SE
Camp Pendleton CA
12-24-2007
| « Re: (KoukiS14) | 8:19 PM 2/4/2008 |
I am assuming the 9 volt was for instructional purposes only and that it is going to be wired to your electrical system in the car. Looking good though. Possible write up?
float_6969
Topeka Kansas
8-26-2002
Yea the 9V was just for testing. It's in the car and working fine now. I'm going to get some other LED's and do the HVAC controls next. I'll do a writeup then.
nzmoman
240sx 2 of em' and always lookin for more
Atlanta GA
5-22-2006
| « Re: (float_6969) | 5:30 PM 2/20/2008 |
i really would like to see pics of this installed... I am kickin around the idea for a black and red scheme
current build: Copycat- Project Kouki:
KoukiS14
Lafayette IN
3-31-2003
| « Re: (nzmoman) | 3:15 AM 2/21/2008 |
Yeah I want to do this with my interior lights. . on my s14, I changed the gauge lights to red by painting regular 168 bulbs with high-temp red engine paint. . that works well, but I've found some nice red LEDs to use this time around (I'm using one of them as ambient lighting, installed in front of my rearview mirror).However, that part is easy -- I want to also change the hvac, radio, and anything else I can find. I wonder how red will look with the mint green LED lighting that's already on the radio. Maybe go with red cluster and blue elsewhere? I could copy VW
float_6969
Topeka Kansas
8-26-2002
I hope to have it completed in the next month or so. I'm in the middle of a KAT project right now and that is consuming all of my resources. Once I get the car sold, I should have the time and money to move on to the s14.
KoukiS14
Lafayette IN
3-31-2003
| « Re: (float_6969) | 11:37 AM 2/21/2008 |
Awesome. . hey. . what sort of LED are you intending to use to replace the small bulbs in the radio / other places? I'm thinking a 3MM would about fit, but that'd be too easy right?
float_6969
Topeka Kansas
8-26-2002
I'm not quite sure. The problem is how the light is dispursed on a LED. 2 of the 3 lights in the HVAC controls illuminate from the SIDES of the bulbs. This won't work with LEDS. I'll probably come up with some sort of 90° mount that faces the LED twords the face. The light behind the fan switch faces forward, so that's easy. As for size, I'll try and use 5mm wherever possible. This is because you usually have a wider viewing angle available with the 5mm vs. the 3mm. I've heard they're now making 360° viewing angle LED's but I haven't heard much about them.
KoukiS14
Lafayette IN
3-31-2003
| « Re: (float_6969) | 1:24 PM 2/21/2008 |
Good call. . . I haven't taken my S14 HVAC apart in awhile. I wonder how different my QX4 one is. Prolly the same.I'll see if I can't dig up info on 360 deg LEDs.
float_6969
Topeka Kansas
8-26-2002
Every Nissan I've seen is pretty much the same. There are too that face straight down behind the temp control slider, and the vent control buttons. The one behind the fan either faces down, or twords the face.
float_6969
Topeka Kansas
8-26-2002
Here is my favorite place, Plus they're relatively local. http://superbrightleds.com/leds.htm
Dano
Administrator (CAO)
10-29-2002
They sell the 360* LEDs there, did you see that Ryan?
float_6969
Topeka Kansas
8-26-2002
LOL, yea, that's why posted it. I'll prob get a few to see what the light output is like. With the way that LED's work, I doubt they are going to be bright enough for the stock configurations. I hope I'm wrong, as that would make it MUCH more simple!
Dano
Administrator (CAO)
10-29-2002
Well hurry up! I'm anxcious to see more!
float_6969
Topeka Kansas
8-26-2002
I'll start work on the S14 later this week, or this weekend at worst. I'm ALMOST done with the KA-T project. Once it's done, and it get paid for it, then I'll start back in on the S14. Oh, I also looked at the HVAC again, and we WON'T need those 360° bulbs. The S13's come in from the top, the S14's are on the board inside the unit and face forward. The only problem now will be finding a wide enough angle lens as they don't appear to be very far away from the board. If they're too close we'll get hot and cold spots (in respect to the light output). We would then have to go back to using the 360° bulbs again.
Looneybomber
89 bronco 2 (Blu/tan) 99 R1 (red/wht/blk) 02 explorer sprt (grn) 03 S2000 (triple blk)
Topeka KS
3-7-2004
| « Re: (float_6969) | 8:43 AM 3/4/2008 |
Put a tiny blob of whiteout, or other impermiable substance on the tip of the bulb so no light comes strait out. Will that help?
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!" -Adolf Hitler, 1935
Dano
Administrator (CAO)
10-29-2002
No, not on LEDs... however Ryan, if you need more light dispurtion, you can take some really fine sand paper or scotch brite pad and scuff up the end of the LED...
float_6969
Topeka Kansas
8-26-2002
I'm hoping to make it more "plug-n-play" than that, but we'll see how it goes when I get started on it.
Dano
Administrator (CAO)
10-29-2002
Because it's so hard to scuff up a light? lol
KoukiS14
Lafayette IN
3-31-2003
| « Re: (Dano) | 1:56 PM 3/5/2008 |
| Quote, originally posted by Dano » | | Because it's so hard to scuff up a light? lol |
It just IS, okay?!
float_6969
Topeka Kansas
8-26-2002
| « Re: (Dano) | 10:44 PM 3/6/2008 |
This is coming from the white guy with wannabe gang signs in his sig...
Dano
Administrator (CAO)
10-29-2002
I didn't know the horns were gang signs
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
| « Re: (Dano) | 12:11 AM 3/7/2008 |
| Quote, originally posted by Dano » | BUT:If you do a red dome light, your retarded. Do all your switches and gauges and whatnot in red, do the interior light in WHITE. Practicality as well as aesthetically it's better to do it. I'm serious Ryan, don't do red. |
I think Red would work well, especially if you like to develope film while driving (or better yet, parked).
Snoop with a 510?
 | Quote, originally posted by idahotuner » | | WAHT DOES THIS FAP MEAN |
Dano
Administrator (CAO)
10-29-2002
Ricky Racer the Ricer Red.
float_6969
Topeka Kansas
8-26-2002
you guys killed my thread
Dano
Administrator (CAO)
10-29-2002
No, you did, with your lack of productivity.
float_6969
Topeka Kansas
8-26-2002
I'm productive, just not on this car right now.
Dano
Administrator (CAO)
10-29-2002
Yeah.
Enlefo
s14 zenki, black on black.
Portland OR
3-25-2005
Cool man! I did all the windows switches in my 97 maxima back in the day with blue LED's. I to have a black on black s14 but I am going with white lights all around. I never even knew the auto switch lit up lol. Here is a link to a hvac led walkthrough... in case you guys care to see. http://www.s-chassis.com/forum...c+led
float_6969
Topeka Kansas
8-26-2002
nice!
SketchyRollin564
1995 240sx 5spd MT
Boca Raton, South Florida
3-24-2007
| « Re: (float_6969) | 7:34 PM 3/25/2008 |
Wtf the auto switch lights up? Now that has me wondering, does the fan controll speed, and the "hot and cold" thing light up as well?
float_6969
Topeka Kansas
8-26-2002
LOL, yea, it's supposed to.
Dano
Administrator (CAO)
10-29-2002
Yeah, only my fan speed lights up now. The the green 'on' LEDs for the different vent controls.
SketchyRollin564
1995 240sx 5spd MT
3-24-2007
| « Re: (Dano) | 5:24 AM 3/27/2008 |
The only thing that lights up on my AC controll unit or whatever is the buttons that tell you where the air is blowing to, and on the hot/cold slider, just the green line on the slider (not the hot and cold letters)on the AC button, the light for the letters doenst work, but the green line under it when its on dimly lights up the letters from behind ' how the fck do you fix all this without going through an assload of work?
Dano
Administrator (CAO)
10-29-2002
Buy a brand new one from Nissan  Maybe you could send $50 and the unit to Ryan and have him do it for you, lol.
| First 1 2 > Last |
