 2001 nissan sentra factory rear subwoofer wiring
Dan and Machine
2001 Nissan Sentra
Inwood wv
1-22-2008
  2001 nissan sentra factory rear subwoofer wiring needed.
hi everyone. the wires for my 01 sentra rear subwoofer have been pulled out. the plug is left in the sub with the wires hanging loose. Of course this shut off all power to the radio (wires touched, i guess). i need to know which wires (6 or 7 of them), go into which hole in the connector. something like a factory pinout diagram. or, if that won't work, is there a way to bypass the woofer. daily driver, so i just want my radio back to normal.
thank you for your help.
dan.
Modified by Dan and Machine at 10:38 AM 1/22/2008
nametakennow
Sentra Moderator
'06 MINI Cooper S
Atlanta GA
8-24-2002
The rear sub is junk, so you're not missing anything by having it disconnected.
It shouldn't have shut off the power to anything else.
Check the wiring with the diagram in the FSM. You can get the FSM from the link in my signature.
Welcome to NICO!
'06 MINI Cooper S - Chili Red/White, stock
Sold - '01 Sentra SE (SR20DE) w/pp (VLSD, FSTB), a few mods
Get your Nissan/Infiniti's FSM here.
Need parts? Look here!
NEW QR25 forum
fatboygotslim
2002 sentra SpecV
miramra fl
1-17-2009
 « Re: 2001 nissan sentra factory rear subwoofer wiring needed. (Dan and Machine)
hey, I did the exact same thing, were you able to resolve the issue?
I noticed that subwoofer was blown so i attempted to pull out the harness while the sub was still mounted and ended up ripping out the cables. I used the FSM wiring diagram to pop the cables back into the harness, but the radio still doesn't power up. Any suggestions?
Modified by fatboygotslim at 3:52 PM 1/17/2009
nametakennow
Sentra Moderator
'06 MINI Cooper S
Atlanta GA
8-24-2002
Odd. Make sure you didn't damage the connections when you ripped them out and double check your re-wiring job.
Did you rip the wires out of the sub itself or the crossover next to it?
You may also want to try the audio forum. We have some guys in there who know all about finicky Nissan/Infiniti audio.
alixjg
2006 Nissan Sentra 1.8 Special Edition
Butler PA
3-6-2009
 « Re: (nametakennow)
hey, I just wanted to ask, does anyone know what the wattage is on that sub/amp?
I already have the wiring diagrams and whatnot (thanks to nametakennow) and I'm interested in replacing the sub directly or hooking up a sub with an amp of its own and bypassing the stock amp.
I just don't have the time or money to replace the head unit and whatnot right now.
kasey24e
Nissan 240sx (1990)/Nissan Sentra (2004)
Sioux Falls SD
7-1-2009
 « Re: (alixjg)
So did anyone figure this out? same exact problem. my wires are hangin (black, black/pink, orange, blue, blue/white, grey, grey/pink) I dont know the order and my deck will not turn on.
kasey24e
Sioux Falls SD
7-1-2009
 « Re: 2001 nissan sentra factory rear subwoofer wiring needed. (fatboygotslim)
Hey man, did you ever figure out the power issue after reconnecting the wires? My fuse is good and so is the ground...
» Return to Sentra Forum / Infiniti G20 Forum / NX Forum
