 Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!!First  1 2 >  Last
pirate87
1997 Nissan 240sx SE
Durham NC
8-2-2006
*All info reflects the best of my knowledge, but please if I do err, correct me!
Ok guys, school has kept me off the forum actively for about a year now, but I've recently started trolling again only to find a lot of questions about the Holset HX35 and its application to the RB series of motors.
The Holset, as has been said many times over, is a great turbo. It flows great, and is nearly bullet proof, plus they can be had for about $250 on ebay. I am going to talk specifically about the HX35, but much of what I say also applies to the HY35 (smaller compressor) and the H1C (slightly older).
Here is a link to the Cummings page about the HX35, for basic info on the turbo:
http://www.holset.co.uk/files/...5.php
So.... It all began when my previous turbo a TO4E just wouldn't spool fast enough. I set to thinking about cheap alternatives and quickly came across the HX35. Days later I purchased one off of ebay for $250 shipped and it arrived soon after. The turbo came internally wastegated, but I run an aftermarket manifold with an external wastegate (the XO2 top mount),so I removed the actuator and welded the flap shut. The specific turbo I purchsed also came with a V-Band adapter for the down pipe which made fabbing things very easy.
Here is my setup installed, which has remained the same (and reliable) for the past 6 months.
As you can see I run a "Greddy" plenum, Q45 throttle body, Z32 maf, all tuned on a Power FC.
The HX35, simply, is a large turbo. The compressor housing is almost 11 inches across at its widest point, so to fit it mounted to the top mount manifold, I had to shave about 2 mm off the compressor housing and the valve cover. Also the compressor had to be clocked pointing straight down, where its thinnest point aligned with the valve cover.
Now that the turbo was fitted to the manifold I had to hook up the oil lines. The oil return is the same as most T3 turbos as well as the stock RB dump tube, which I reused for the return. The oil feed is slightly larger than a standard T3 so I had to get an adapter to get my lines to fit. I cannot remember the exact size, but if anyone else knows, please comment. Also, the turbo is not water cooled so anyone converting from a stocker would have to plug those lines.
The compressor intake is 4 inches in diameter so a 4" to 3" silicone coupler was used to hook everything up. The compressor outlet, being clocked to the ground required me to rig my charge pipes in the crazy snake route shown. Soon I will weld a 90º bend to the outlet to solve that annoyance.
OK, we've come along way and the turbo is finally ready to sp-sp-sp-SPOOOL!
I will soon post video to accompany this section, but for now you'll just have to take my word for it. In second gear from a 2000 rpm roll about 20 mph for me, I mash the gas. Of course there is lag, but at about 2800-3000 rpm boost starts to build until at about 3500-3800 rpm a "spike" is felt when the boost jumps from 5 psi to 10 psi, where I have my gate set, and holds to the redline- 6900 rpm.
On my last tune the car put down 300 hp somewhere near the redline at just under 12 psi.
Off to work for now, but more pics and video will follow. Hope I've helped to answer alot of questions!
RB30DETT Build in progress!
rb25drag
1990 240sx
Springcity tn
9-24-2007
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (pirate87)
If you kept it Internaly wastegated couldn't you put a boost controller on it and limit the boost?
Propane=6's on the way!!
gawdzilla
none
9-18-2004
you might want to rotate the turbine housing so the oil feed and drain are more vertical.. looks like your oil feed is coming in from about 10 or 11 o clock
pirate87
Durham NC
8-2-2006
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (rb25drag)
Quote, originally posted by rb25drag »
Its externally wastegated with a boost controller inline. But yes, to your question.
Quote, originally posted by gawdzilla »
I've heard this before, but exactly why is perfectly vertical better? Does oil pressure build b/c it can't drain as fast?
kjlindgr
6.6 DMax
Green Bay WI
6-16-2006
Turbos drain with gravity so vertical is ideal.
RB's don't belong in FD's
http://www.sound-performance.com
rb25drag
1990 240sx
Springcity tn
9-24-2007
[QUOTE=pirate87] The turbo came internally wastegated,
QUOTE]
You said the turbo came internally? Is there anything wrong with keeping it internally and adding a boost controller? Or is there a reason you make it external> reason is for if you wanted to keep the stock manifold.
pirate87
Durham NC
8-2-2006
QUOTE]
I already had an external setup...there's no reason the internal setup wouldn't work except I'm nt sure what the stock holset actuator spring is set for. It could be quite high since it is a deisel turbo.
rb25drag
1990 240sx
Springcity tn
9-24-2007
That was my question, If I decided to stay with internal wastegate on one of these turbo's and still be able to control the boost with a boost controller? or if the actuator is too high and you have to change it to external to control it?
BoostFab
Nissan Land
12-3-2003
anyways, as for your question; you can keep the wastegate that comes with the turbo, but the problem is you don't know at what boost level it will activate---because diesel trucks boosts these suckers near 30psi. I wouldn't recommend anyone running it unless you know it's actual boost rating. beside, an external wastegate will be more stable and you still can plug in a boost controller at your will.
rb25drag
1990 240sx
Springcity tn
9-24-2007
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (BoostsFed)
Does anyone have a picture of the stock manifold modified with an external wastegate?
Thanks for the info guys! I wanna learn all the turbo options for this motor! I have alot of experimenting im doing in the near future.
Cjmartz2k
'92 Skyline w/RB25 & Holset HX40
K Vegas NC
5-19-2007
Here are my spooling vids:
And some beating on it vids:
All the other vids are with a TO4e, so don't use them as a gauge.
Pirate--not trying to steal you thread or anything, just trying to add to the Holset info.
My R32 GTSt = 11.8 @ 124mph
pirate87
Durham NC
8-2-2006
I guess I misunderstood the first time . I believe I read somewhere that the HX35 actuator is set to open at 21 psi.
nizmo zilvia
RB20 1990 Black 240sx SE
Hartford County Connecticut
7-7-2005
WOW!!! CRAZY FAST!!!!!!!!
Can't wait to invest in it!!!!
http://www.chukirb.com
Quote, originally posted by blues14 »
Cobalt ss is not a "nice" car.....its a cheap POS Chevy trying to be an import. It belongs in the Hertz rental car lot right next to the Neon SRT-4. IMO
pirate87
Durham NC
8-2-2006
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (Cjmartz2k)
Quote, originally posted by Cjmartz2k »
Hey man, the vids are great! Thanks for adding to the thread. Yours seems to spool far faster than mine? Can you provide more details on your setup? It looks like you were boosting to about 15psi?
Bwana
Super Moderator
'77 MGB CA18DET, Miata, 510
Vista CA
9-16-2004
Actuators are fairly simple to source and replace. I definitely wouldn't recommend running on the stock Cummins actuator...
rb 90 240
90 240
ohio
9-9-2007
so Im curious, 300wheel on the turbo upgrade with tune? I was reading on aem and there was a guy on there making almost 300 on a rb25 with bolt ons and the ems tuned. Is there more room in this turbo upgrade with the upgraded manifold and all to make over 300? I can get a hx35 from a friend who just did twins for a pulling truck and it would be next to free. I just need to reach my goal of around 375 wheel and trying to find a good turbo to go with. Im scared to try my turbo I have now as I think the turbine wheel is going to be too small.
neonbomb
Pittsburgh/Detroit
4-22-2007
Quote, originally posted by pirate87 »
Oil does not 'drain' from the turbocharger nor any part of the motor so no, placement of in and outlet feeds will not matter on a pressurized volute shaped object (aka a turbocharger).
Great turbo and try and keep holset a secret
95' s14
Stock + rb25 neo
Cjmartz2k
K Vegas NC
5-19-2007
Glad you like them! It's a bone stock RB25, HKS log style manifold and wastegate (38mm with no boost creep ) and it's 1.5 bar which is abotu 22psi. Gears are stock Skyline 4.37's. I'm not sure why it would spool quicker than yours. It's a hybrid, so it's got an even bigger compressor wheel on it.
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
Looks good CJ... cant wait Untill i get mine... .... i have started to look around on this forum more because im about to break into the RB world after all these years....
im a Holset guy myself.. good stuff man..
Luckly my OLDER H1C lol didn't come with an internal wastegate..... but yea you don't wanna run the stock wastegate that comes with the turbo..they are built to see a much bigger signal... that chances of spikage is high
this site was helpful to me when i really got into holset's some years back
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
quick chart i made so you don't have to link up to the site if you don't want to
Boost levels for respective dodge ram truck years.....
Modified by Biggamehit at 1:35 AM 1/18/2008
Modified by Biggamehit at 7:40 AM 1/18/2008
Http://BigGameHit.TeamMNR.Com
Http://DonaldJackson.TeamMNR.com
Kansei240sx
91 240sxHatch RB25DET, 86 AE86 Hatch 5SPD, 2008 Honda Ruckus 49cc gas saver!
Tulsa Ok
11-1-2004
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (Biggamehit)
That looks good there.
A few questions though.
What size exhaust housing is that? 14 cm, 12cm?
I am hoping you are running a conservative tune on that 10 psi. I know those turbos come to life at higher pressures and the flow increases dramatically over another 5 psi, but how are you only making 300 rwhp?
I am making 307~ on a good day with factory everything more or less.
Greddy manifold
SAFC
AVCR
FMIC
Divored dp
3" exhuast
all the basic bolt ons. running a 11.9-12.1 afr on 20 degree timing.
Im in the process of upgrading injectors, ECU, and turbo, and i have a mind set on that actual manifold, and turbo, although ill probably actually do a smaller exhaust housing, per say the 12 or 14.
And what injectors are you running? If you're on stock, ill hold my comments because 300 to low 300's is a feat on stock injectors for the 25.
I say, "cranketh thine boost! and maketh powa!"
Previously powered by RB25DET, now moving up to an RB26DETT 91 S13 GT2/1 Track car under development.
(R.H.C. Garage, Tulsa Oklahoma)
SR/RB/VG nissan anything?!
Swaps, wiring, electrical, fabrication etc. PM me if you need parts or wiring help!
ASE MASTER CERTIFIED TECHNICIAN.
pirate87
Durham NC
8-2-2006
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (Kansei240sx)
Quote, originally posted by Kansei240sx »
Greddy manifold
SAFC
AVCR
FMIC
Divored dp
3" exhuast
I am not positive but based on bigmehit's chart the turbine housing is 12cm, and your suspicions were correct I am still running stock injectors, so I am am boost limited as of now! Soon to be changed.
The only thing about my manifold and turbo combo that wasn't ideal was the grinding I had to do to shave off a few mm from the compressor and valve cover. This has lasted me, but I'm sure it isn't the best option. Ideally, I probably should have rewelded the flange on the manifold, but oh well.
Shocker
Youngstown Ohio
8-1-2004
you bastard, those videos make me want my car to be running so damn bad!! ahh I miss that noise.
this seems like very good cheap turbo that provides excellent results.
Always a Fight.
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
 « Re: Pirate87's Holset HX35 boosted RB25 thread- Diesel Turbo FTW!! (Shocker)
yea the turbos are cheap because they are for a truck application.... but they can get pricey..
but these turbos are bad *** awesome quality... one night while going home after welding up my exhaust..... i noticed my oil pressure was acting up.... so i pull over and wow ..... big hole in my oil pan from a puncture. i was driving a very high rate of speed... lets just say my turbo spooled for little over a mile with no oil at all... I took it apart and everything was fine.
hope im not thread jacking. here is a little more info on the great holset.
http://forums.nicoclub.com/zer...83671
few pics of where i got mine from... much much more bro's he also has brand spanking new ones for about 300-500 bucks
Modified by Biggamehit at 7:30 AM 1/18/2008
Modified by Biggamehit at 7:33 AM 1/18/2008
Modified by Biggamehit at 7:50 AM 1/18/2008
Shocker
Youngstown Ohio
8-1-2004
lol thats what I meant cheap to buy, not in quality.
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
Oh no doubt bro. i understood you.. i was just piggy backing on it lol
Shocker
Youngstown Ohio
8-1-2004
Pirate, or Cj how long till you guys get on the dyno or get a trap speed with this turbo?
grenade180sx
180sx
socal ca
8-20-2007
so wait.. i have a 20. and i cant find a 9cm housing.
spool is kinda laggy for drifting and a 20 is gonna be another 300-500rpms
any advice on which one to rock?
and please link the shop where you took that pic!
BoostFab
Nissan Land
12-3-2003
 « Re: Pirate87's Holset HX35 boosted RB25 thr ... (grenade180sx)
Quote, originally posted by grenade180sx »
you can step down to the HX25 or HX30
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
 « Re: Pirate87's Holset HX35 boosted RB25 thr ... (BoostsFed)
good answer bro... the hx30 goes unnoticed and the hx25 is another good one...
here is a pic of the hx25... will bolt right up.... T2 flanged
Cameron
a 240
Atlanta GA
6-3-2007
 « Re: Pirate87's Holset HX35 boosted RB25 thr ... (Biggamehit)
HEY YOU GUUUUYYSSSSSS!
CHECK OUT WHAT I BEEN DOING WHILE I WAS AWAY!
Brand NEW H1E!!!
Mock up of the exhaust manifold on there.
oh and granade. ditch the stock housing bro. get a Hx35 and get the bullseye housing, .58ar or something, which is like 7cm..
they are only like 250..
dont drop down from the 35...
Oh and guys i realize it is a T4 lol. Im getting the Bullseye Housing for the Hx40(H1E) and changing it to T3.
its like a .79AR
Cameron
a 240
Atlanta GA
6-3-2007
oh and OP is that a Freddy?
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
 « Re: (ZenkiCam)
hahha LMAO dude.... i dont know you... but your nuts lol
Modified by Biggamehit at 6:16 PM 1/18/2008
Cameron
a 240
Atlanta GA
6-3-2007
 « Re: (Biggamehit)
lol ive been around for a while. RB forums is where half my posts are at lol.
Ricky i hope mine dont have the same fate as yours
pirate87
Durham NC
8-2-2006
 « Re: (ZenkiCam)
Zenkicam..
I love the turbo position with the apex manifold. How did you come across one, and if you dont mind me asking how much did it run you? I'm really considering switching now because I am not a fan of the XO2 stainless, though it has been reliable, it doesn't position the turbo very well.
nizmo zilvia
7-7-2005
I should of got a apexi manifold for $700 when I had the chance!!
Cameron
a 240
Atlanta GA
6-3-2007
 « Re: (nizmo zilvia)
and pirate, it will be very very hard to come across another one.. they are extremely rare, and were only available to have if you bought an apexi kit, which was like ¥500,000 JPY or around $4,600 USD. They are kits discontinued now, and the chances of finding another one are extremely low. They are more rare than The HKS manifold.. I lucked up when i found this one. I Found it on Nico in the RB Classified, and Bought it from a Guy in Australia. His Name is Justin, Username 25ltr here on nico.. on other forums like nissansilvia, and Skylinesaustralia his username Is Silman. I talk to him a good bit, whether its through Youtube, or Email, but Ill tell him to keep a lookout over there in Aus. to look for you one, although chances are uber slim...
the Kit that it came off of is the Apexi RHX-6, So that phrase would be your best bet to search for in google, if you wanted one. there are very few people that have them, and oh dont forget, that these RX-6 kits were made for all difffernt types of motors, not just 25s.. They are easy to find for like evos, and RX7's and Twin Turbo RB26 Kits, but, since this manifold is a dual stud pattern for a RB25, or a single turbo RB26, its sorta hard to find them, cause not many of this model were made.. but it fits all RB's which is a good thing..
TheMadScientist used to have one on here, but he sold it. So you could check with him to see where he got his at too.. But if you find one, remember they are IHI flange, so it would need to be conv. to T3. mine already has been.
Cameron
( Here are some Vids of it, he had a GT3040r on it, when it belonged to him.
http://www.youtube.com/watch?v=Hk0EOYc-9x0
http://www.youtube.com/watch?v=2q5bXzK8EdI )
Modified by ZenkiCam at 5:02 PM 1/19/2008
Modified by ZenkiCam at 5:31 PM 1/19/2008
Modified by Cameron at 10:47 PM 12/15/2008
pirate87
Durham NC
8-2-2006
 « Re: (ZenkiCam)
thanks for the info, I can imagine how rare they are. The position of the turbo just seems so perfect, I'm jealous!
Biggamehit
89 KA24DE-T
Misawa, Japan
1-30-2005
 « Re: (ZenkiCam)
bro you may be able to score it from yahoo japan auctions
awesome third man site named Rinkya.com
you go there and shop on yahoo japan through them... sooooooo Freaking awesome
Cameron
a 240
Atlanta GA
6-3-2007
 « Re: (Biggamehit)
Yea big game, that would be the only place i could think to hope to see one come up.
LOL look here, RB20 For 84 dollars hahaha
http://www.rinkya.com/twview.p...71654
pirate87
Durham NC
8-2-2006
 « Re: (ZenkiCam)
yeah, bought my power fc through rinkya, good stuff!
 First  1 2 >  Last
