Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Sun Jan 27, 2008 4:50 pm
Sorry, but I have a hard time accepting that you have to leave a spare key in the car in order for the remote start to work.There are thousands of late model cars out there with remote starts, and I have never heard of anyone having to hide a key in their car.My Altima remote start works just fine without the spare key, as does my Sentra.The thing you have to remember is that when you start the car with the remote, even if the car is left unlocked, you cannot just get in and drive it away. It doesn't work like that. When the car starts, there is no key in the ignition, and the tumbler has not been turned to the run position. Most of the accessories are therefore still disabled. For example, the radio will not be on, nor will the wipers work. The only thing that is working on remote start is the heater/air conditioning system, and possibly the rear defrost, if you have that option (which I do). Not only that, but the steering wheel will still be locked, and you won't be able to get the car in gear. If you do get in the car after it has started, and try to drive it, as soon as you touch the brake pedal, it will shut off anyway. You still need to put the proper key in the ignition and turn it to the run position. Thats when all the other stuff starts to work.Even better, in the case of my Altima, if I accidentally leave the door unlocked, and open it without using the keyfob first, my alarm goes off, while it is still running.As for KoukiS14, the starter can be programmed to run the car for as long as I want, but like you said, only in predetermined intervals (15, 30, 45 minutes, etc.) I find 15 minutes is plenty long enough.So, for Law23, go ahead and get a remote starter. You'll like it.
