DRIPS wrote:Has anyone converted teh high beams to HID? I know the low bean is HID but the high is halogen. I am thinking it would be nice to have HID for both hi and low beam
"Silverstars" will change the color of your light but not increase the lumen output absent higher wattage. Your high beams will best be improved by using HIR1 bulbs. They will provide more light, but not more range, as the reflector determines that.
For insight on headlights from a guy who REALLY knows his stuff, go to Daniel Stern Lighting. Here his reply to my recent inquiry after buying and installing HIR1's in my '05 Q45, and you can use the embedded links for more info:
On Thu, 17 Apr 2008, George StarPD wrote:
> sometime around a year ago, I bought a pair of HIR1 bulbs from you for > my 2005 Infiniti Q45. I'm completely satisfied with them. Thank you.
Good!
> You had provided me with a detailed comprehensive E-mail that provided > full specs and descriptions of these bulbs. I saved the E-mail, but > somehow lost it. Do you still have that data already written up that you > can resend me?
Yep. If I didn't, I'd spend (even more of) my life typing! It's at the bottom of this message.
> Also, I just bought my wife a new 2008 Honda Civic EX-L coupe, and would > like to upgrade both high and low beams. Which bulbs should I get
HIR1 high beam, HIR2 low beam. Per the below.
> I'd like to have 100 watt high beams and maybe 75 or 80 watt low beams.
Negative -- output is not measured in watts, high-wattage bulbs would burn up the wiring and damage the headlamps, no such bulbs are made in decent quality, those that are made have sloppy filament placement and very short life and produce less light than the HIR1/HIR2...shall I go on?
Your best upgrade path is to replace the existing 9005/HB3 (high beam) and/or 9006/HB4 (low beam) bulbs with Toshiba 9011 and 9012 bulbs . The new bulbs are not some tinted or overwattage version of 9005 and 9006, but rather employ a relatively new technology called HIR, Halogen Infrared Reflection. The mechanical dimensions of the bulb are all identical to the 9005 and 9006 bulbs, but the bulb glass is spherical instead of tubular, with the sphere centered around the filament. There is a "Durable IR Reflective" coating on the spherical glass. Infrared = heat, so the coating causes heat to be reflected back to the filament at the center of the sphere. This causes the filament to become much hotter (producing more light) than it can by passing electricity through it, *without* the shorter life or greater heat production that comes with overwattage bulbs (to say nothing of overwattage bulbs' incompatibility with stock wiring.)
Here's the comparison of these bulbs to standard and high-performance 9005 and 9006 bulbs. A "+50" would be a Philips Vision Plus or GE Night Hawk. A "+80" would be a Philips Xtreme Power.:
Low beam stock: 9006, 12.8V, 55W, 1000 lumens, 875 hoursLow beam compare: 9006+50, 12.8V, 55W, 1090 lumens, 300 hours Low beam compare: 9006+80, 12.8V, 55W, 1120 lumens, 275 hoursLow beam new: HIR2, 12.8V, 55W, 1875 lumens, 875 hours
High beam stock: 9005, 12.8V, 65W, 1700 lumens, 320 hoursHigh beam compare: 9005+50, 12.8V, 55W, 1830 lumens, 175 hours High beam new: HIR1, 12.8V, 65W, 2530 lumens, 320 hours
So, compared to standard bulbs, you're looking at 88 percent more light from the low beams and a grand total of 137% more light in high beam mode (49% of which from the high beam units, 88% of which from the low beams). The beam pattern will not change, but there will be considerably more light within the beam pattern.
Of course, your headlamps _must_ be aimed carefully and correctly perhttp://www.danielsternlighting....html with any bulbs, but especially with these high-output bulbs.
These bulbs are expensive as bulbs go - $23.95/ea - but they are verycost-effective compared to a tarted-up 9005 or 9006 with blue coloredglass (PIAA and Sylvania Silverstar come to mind) that doesn't producemore light and has a very short lifespan.
The HIR bulbs have a double-wide top ear on the plastic bulb base, tocomply with the law requiring different bulbs to have different bases. Theextra-wide plastic top ear is easily trimmed or filed to make the bulb fityour headlamp's bulb receptacle. Once that's done, they go directly intothe headlamp, and the existing sockets snap on. Please seehttp://dastern.torque.net/Mods/HIRmod.html for details.
Direct order links for these bulbs:
http://store.candlepower.com/hirlighting.html
