" yeah, can i get a number 1 combo ... no drink please ".
~"Ok, i have a number one combo, with no drink .... are you sure you dont need a drink sir. ? "~
*sigh* ... "yes, i dont have cup holders .."
NEVER AGAIN !!!!!!!...
Introducing !!
The padded arm rest drink holder lid 2008 ! By vroom !
Yes you heard right, now you can hold cans, bottles, cups, AND MORE !!
What you need :
- Arm rest lid- Low profile foam *optional, but looks and performs better- 4 very small screws- Office stapler- razor- something to cut plastic, or a hole maker drill bit- vinyl or leather or material of choice- A drink holder liner from a random car(mine was from a 98 malibu) *optional, but looks great.- heat gun or blow dryer
Start :
Pull off your arm rest by removing the two screws at the bottom holding the hinge on. and wiggle the arch out carefully.
3. Remove all the screws, including the one hiding under the latch.
4. Trace the top of the lid with against the foam, give yourself about a half inch extra on all sides, you will be trimming some off later on .
5. Cut it out, then trim it at an angle, with a downward slope, your razor needs to be sharp for this. You dont have to trim it off at an angle but, it looks nice under the vinyl if you do..
6. place it on top of the lid now, and make sure theirs not any hanging over the edge, any protruding bumps or deep grooves will show through the vinyl, so cut it at clean as you can,.
7. Lay the foam and the lid down onto the vinyl, and cut an over sized square around the lid, to make it easy to work with. 8. Now draw a circle on the lid where you will want the drink to sit, it should be the diameter of the bottom of the drink holder liner.
Cut it.
Then place the foam on top the lid, flip it over to trace the hole from the bottom of the lid.
Cut the foam.
Now place the liner of the lid back on the lid, and trace the circle onto that from the top of the lid.
And cut it too.
Now you should have all the pieces ready.(lid liner not shown.)
Start by placing the vinyl backside up, then the foam, then the lid onto it, with the hole lined up. draw a cross in the middle of the hole on the vinyl, and cut it, stretch the flaps onto the lid, and place a screw in each one (careful not to go too deep).
What you do is gently heat one side up, pull it into the lid, and staple it in, then go to the opposite side and do the same, then the other, and the the remaining side.Once you have a staple in all sides, work your way around heating and stretching the material into the lid and stapling it in.It wont look like its gonna work at first, dont be discuraged, It will work and the payoff is sooo nice.
heres a pic in process
When you have it all nicely stretched and stapled in and your satisfied with the look, screw the liner back on, this adds more strength to holding the vinyl together, as you can see.
Now your done, insert your drink holder liner, the rim of it will hold it from falling through.
not too bad eh?....
this may seem shallow, but it works great, after all, it came from the factory .
Even holds 20oz bottles
holds them tight .. here im holding the bottle, thats lifting the center council ..
And if your not confident in that ,... take the liner out. i couldnt find a restaurant cup but im sure it fits, id did when it was in the malibu
ENJOY !!!
Some more pics and stuff
vroom-chirp wrote:heres about 15min of work, buy one from the yard, $5. then slap it in and see how you like it .
just drill out some holes and throw in the liners .
My boss was riding my back the whole time ......
ill post back once this one is padded and covered.
vroom-chirp wrote:Done ..
the one in the rear will be for cans, and the one in the front will be for bottles or fountain drinks.
Also, the one up front is made of soft rubber, so its not bad at all to rest your elbow on. (from a pontiac sunfire )
Im not condoning these drinks in the car .....
even fits a grande Taco bell cup !!
and thats that .
The S14 padded dual holder already sold lacally lol, but i have 2 padded S13 lids and 1 S13 padded single holder lid for sale in my sig .
Modified by vroom-chirp at 10:13 PM 1/23/2008vroom-chirp wrote:Looks pretty stock to me ......
LOL all made and ready to be bought .
the one on the far right is S14
Modified by vroom-chirp at 11:43 PM 1/14/2008
