Are you sure that deep rattle you hear isn't knock from the rods main bearings? If your oil pressure is low I'm sure there's something wrong in the bottom end. And like float says, there's no valve adjustments on the CA. Good luck.........slo wrote:Sorry for my noobish-ness....
There's noise coming from the cams (deep rattling sound) at lower rpm. And the noise speeds up as the rpm increases. One guy told me that my oil pressure is low so I'm going to replace the oil pump. The other guy told me that i may need valve shims.
I had one of the nissan master tech's take a good look at the motor. He was sure that it is a bad lifter. It's a rod knock when you hear it at idle and hear it get louder and louder as the rpms increase. Mine, you only hear the rattle at idle and sound/vibrations goes away when revs. It revs clean too. He's sure that it's the low oil pressure.float_6969 wrote:Lifters are a definite tick, not a knock. The motor will continue to run fine until you spin the rod bearing and ruing the crankshaft. It may still run OK, but you'll ruin the motor in very short order if you keep running it.
It needs torn down and rebuilt.
Wow...that sounds horrible.
I've actually seen this video and it's no where near as violent as that car. It'll rattle a little at idle but go away immediately once rev'ed up a bit.
dattodude wrote:Now that I've listened to the noises, the conditions on which the lifters 'rattle' is unusual, but it does sounds like lifters.
If you can:Remove and Measure the 16 lifters you currently have, and compare them to each other at least. For the smaller ones, check that side holes and top hole are not blocked. If any of the holes in the lifter are blocked, the high pressure oil will not make it into the lifter, and the noise will continue for longer than the normal minute or so.
I would prefer using new lifters over using second hand ones. Especially if you find that one or two have collapsed. After 100,000mi it's possible they need replacing anyway.
The FSM tells us that lifters should marked and be stored in engine oil, and not turned upside down, flipping the engine with the valve train installed logically may have caused these noises. But if the oil flow through the lifter is right, the noises should subside after a couple of minutes.
Nope. It only rattles at idle.sideways danny wrote:the best foolproof way to check if its rod bearings is to gently rev it to 3-3.5k then let it drop to idle again. if it taps as it passes down through 2-2.5k its the bearings.
The best way to get self satisfaction is take the advice being offered or rip the engine apart. Back in 1999, I had a CA18DET that tapping at idle and everyone told me it sounds like the lifters, I didn't believe them. So I ultimately pull the head off to discover I had melted a piston, but the car still ran prior to me pulling the head off. The point I'm making here is, you've gotten feedback from some of the most experienced CA owners on this forum, but your responses depict that you're not at all convinced at what we are telling you. So to gain some experience, pull the engine, disassemble it, and gather your own conclusion as to what might be causing your issues. If it is just a lifter, you're still going to have to do some serious disassembling, so may as well go for the gusto and do it all right.slo wrote:
I see your point as well, dude and if you were closer, I'd lend you a hand. I hope that it is just a bad lifter to save yousome cash, but it will still require someone to pull the camshafts, all belts, cam covers, blah-blah, to get to the lifters; let alone figuring out one(s) are bad. But I wish you the best with this issue and please share the outcome with us.slo wrote:I definitely see your point. But try to see it from my point of view. Not everyone knows how to simply take the motor out, dissemble everything, and rebuild it. It takes incredible amounts of knowledge, skill, and know-how to "just do it".
You experienced folks may think that that I'm a fool to buy a rare motor like a ca18det and not know much about taking everything apart. I've researched over and over between sr20 and rb20 but ca18 meant more to me than others. Maybe I'm just justifying by convincing myself that it's NOT a rod knock. But I don't much knowledge and worst off, I don't much money to just drop it off at a shop to fix it. I was so glad that when that master tech told me not to worry and it's just bad hydraulic lifter. All I'm saying is that is there a possibility that it just may be a bad lifter?
I'm sorry to come here and be a cry baby but this is just a situation that i'm in now. I'd love the experience and knowledge to rebuild a motor but with time. I really appreciate those who have helped. I'm getting the oil pump replaced next week and update all of you on how it goes. Thanks and thanks again.
