OFFICIAL NORTHEAST PICTURE THREAD
Including VA, WV, MD, DE, DC, NJ, PA, CT, RI, NY, MA, NH, VT, and ME
DJButton
Car: 2010 Nissan 240sx
Post a couple pictures of your car and a brief bio, feel free to change around the format a little but we honestly don't need more then 4-6 pictures of your car in this thread.
My format:
Car:
Mods:
Pictures:
And keep in mind that I will most likely delete the chit-chat and clutter from this thread so feel free to stay on topic.
I will start I suppose.
1991 Nissan 240sxRB20 engine swap, shocks and springs and a bunch of other stuffConcord, NH
x240xdrifter
Car: 1991 Nissan 240sx
Car: -1989 Nissan 240sx se
Mods: - Freshly rebuilt KA24E w/ roughly 10k (a/c removed, Evap removed)- Koyo Radiator- Ebay Cone Air Filter- 4-2-1 header- HKS Hi-power catback- KYB GR-2 Struts/ Tein S-Tech Springs- Ebay Front and Rear Strut Bars- Sportmax 501's 16x8 +15- Fuzion ZRi' 225/50/R16- Nardi Steering wheel, Grex Shift Knob, Broadway Mirror, Custom Ashtray and gauges
Location:Wolfeboro, NH (if anyone is in the area, feel free to contact and chill)
Pictures: Enjoy!
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
Car: 1993 240sx coupe
Mods:Tein SD coilsBC Exhaust17" Hanabi's
Pictures:My old car...may be my new car again soon?
eazye2000
Car: S13 KA-DET
Name: Eric 'aka' EazyE, or just 'E'
Car: 1993 240sx
Mods: Built KA-DE Turbo GT2860RS .86ar
Pictures:
Modified by eazye2000 at 2:45 PM 12/26/2007
nismofly
Car: 89 Nissan 240SX Hatch
i really want more parts....bad
anyway
Car:
-1989 Nissan 240sx hatch
Mods:
BRM 2.5" SS catbackkosei k1, 16x7.5 +22kumho asx or somethingrather, ****ty tires leave it at that, 225/50/16KTS coilovers, 8/6 spring ratesS15 HLSD, r32 gts rear end with 4.36 gearing
giant *** dent from somebody hitting me, needs new 1/4 and a bunch of other things
Syracuse, NY
Pictures:
just after coilover install
and the damage
White Comet
Car: fc, s13 and mazda6, Sierra
CAR- 93 240sx hatchback
MODS- black top sr w/ turbo back 3" exhaust, xs power manifold, intake, koyo rad, walbro 255lph, faze gauges, mom steering wheel, vlsd, cusco sway bar and strut bar, c pillar bar, nismo seats and harnesses, type x taillights and full type x aero (including the turn signals which no one seems to use), hks ssqv, apexi avcr, nismo flywheel, exedy clutch, b&m shifter w/ nimso leather knob, circuit sport oil catch can and coolant res, hks turbo timer, vis vader cf hood, q45 front brakes, ss brake lines, semi gloss rattle can paint job, lots of other stuff that needs to go on or im forgetting
LOCATION- lancaster, Pa
PICS-
PapaSmurf2k3
Site Admin
1991 240sx SE Coupe
Built KA24DET, utilizing subaru flanged turbos. Currently running a custom JGS Log manifold and a Tdo6 20G (oil and water cooled).Tuned ECU and Greddy E-manage blue with Profec E-01 tuner and boost controller.Viscous LSD from a 180sx (pretty sure its the only wicked JDM thing on my car)KYB AGX dampers and Eibach pro-kit springs (all courtesy of the legendary Foster, AKA Fiznat)Ebay FMIC with all custom (by me) piping and brackets.Z32 MAF3" from the turbo, through a magnaflow resonator (curtousey of Greg), cuts down to 2.5" about a foot and a half before dumping through the driver's side rocker panel (Sidepipe FTMFW)SPL V2 Tension RodsAll new control arms, ball joints, and sway-bar end linksLots of new metal on the underside of the car (rust repair)Battery in the trunk, where it belongsCenterforce Dual Friction clutchZ32 front brakesB&M Short Shifter
Wakefield, Rhode Island
Photoshoot coming in the spring.
Slappy
Car: 1993 240 sx coupe
Car : 1993 240sx Coupe
Mods :
Tanabe Sustec S-OC Type II's Cusco Upper Pillow Ball MountsMegan Racing RUCA'sMegan Racing STB'sMegan Racing 2.5" Drift Spec Exhaust w/ test pipeProject Silvia Front Under Brace TYPE-FOSPL V2 Tension rodsSPL Teflon coated brake linesAxxis Ultimate padsTEIN Tie rod/endsSuspension Techniques front & rear sway barRear sub frame collarsACT Street clutch x2 (spare)Nissan Skyline R32 GTS r200 VLSD Advan AVS VS-6 16X7 (tons of oem wheels)Project Silvia Engine MountsUnorthadox crank pulley Injen Intake w/ K&N filterMr. Gasket copper exhaust mani gasketA/C deletedEmissions deleted (AIV/EGR delete plugs.Part # 14052-21R00)Buddy Club type wide racing seat w/ super low down railsGrex Trust (Greddy) Shift Knob Super Light Minor exterior mods
Mods that are on the way :
ATE slotted rotorsValvoline Synpower dot 3/4 brake fluidMegan Racing Brake Cylinder Heat Shield Nismo transmission mountTF Trunk BarNagisa Auto Shakitto Plate (strut tower support)Nagisa Auto Gacchiri Support (fender brace)Energy Suspension Master Bushing Kit Auto Power Roll Bar or U.S. Drift regulation Roll CageS14 seat belts with CG Locks (Later i'll buy harnesses)JWT Stage 1 camsJWT ECUDC Sports headerAero (maybe)
Pictures:
Modified by Slappy at 4:23 AM 1/5/2008
slo_coupe
Car: 90 240sx fastback
Car: 1990 Nissan 240sx
Mods:Megan Racing lowering springs, Tien inner and outer tie rods, PDM racing tension rods, Air filter
mroleg
Car:06 G35X
Mods:Kinetix High Flow CatsKinetix V+ Plenum Nismo CAICoupe MidpipeDrilled/Slotted RotorsTinted TailsColor matched headlight housings19" Privat Netz rims with Kumho Ecsta tires.Dual XDVD8285 Head Unit
Pictures:
Modified by mroleg at 10:40 AM 1/3/2008
480sx
Car: 1996 Pearl White 240sx
Wheres the freaken s14 love!
Had this car for 5 months before i took it off the road to do a ka-t buildup. Such a sweet car in stock form, but i had to have more. My projects 90% now, im just doing the small stuff and were done. It will be on the road for good by the end of january. The ka is such a beast with boost...
Car 1996 Pearl White 240sx
Mods To many to list.. t3/t4 Garrett 50 trim 550cc Sard injectors Enthalpy ECU + SAFC 2 for fine tune Custom everything.. Soon to have respeced Tein HA's + 30 mm z32 Calipers BRM 3 inch
Location Manassas, Va
PICS! Oops, just realized i dont have updated pics, heres a few teasers w/o IC. Ill finish this thread up 2nite ^^.
98koukile
Car: 1998 Nissan 240SX LE
98 Kouki LE (go figure haha)
Not much done because the initial cost, didn't like the feel of the S13CAIAccel plug wirespainted valve cover (ricer hp )5 speed swapRPS street puckfull 6 speaker audio upgradeuninstalled JIC coils waiting for the snow to melt
soon to be...bottom mount turbo T28 or biggerbrm exhaust? Not sure yetR33 forged wheels is my aspirationHLSD
I live outside of Springfield where 240's are far and few between and S14's are nil
Here's some badass stock pictures
99QX4
Car: '07 G35, '05 FX35
'07 G35 coupe
No mods yet...they're on the way.
Long Island, NY
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
car: 1995 240sx se
Mods: The only things that have actually been installed are an led dome light and a kenwood deck. greddy ti-c catcback and b&m short throw waiting in the garage for a spring time install. z32 26mm front calipers are still out for powder coating
ShyLynn
Car: 2006 Nissan 350Z
2006 350Z Located in elmwood park NJ
this is my baby, shes still in the worksThe ford is my friend Stephs its a 06 Fusion
and my non nissan ride2003 dodge ram 2500 slt HEMI
Modified by ShyLynn at 7:37 PM 1/11/2008
MavericStephenc
Car: nissan s14
engine is wayyyyy different and the car is now flat black
greddy FMIC, blitz dual drive bypass valve, apex gtspec down pipe, cat delete,apexi gtspec cat back, miata battery (to make room for the fmic)oh and its half naked
shally2186
Car: S14.5
CAR: 1989 240sx coupe se
MODS: RB20DET swapWelded rear end (dont kno if thats really a mod lol)444cc injectorswalbro 255fpRb25 turbokoyo radiatorracing seatsstablizing bar welded in behind front seatsand ur normal electronics(apexi turbo timer,guages,skyline cluster)
Modified by shally2186 at 7:02 AM 12/13/2008
josiskrazy
Car: 2008 Altima Coupe
Car: '08 Altima Coupe
Mods: Barebone stock, waiting 'til springtime to start doing anything.
Pictures:
new pix.
Modified by josiskrazy at 1:51 PM 3/10/2008
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Car: 1990 Nissan 240sx Hatchback Base
Mods:eBay exhaust (FAIL)
Pictures: This picture was taken in FLAnd finally with my friend's RX7, and step sister's Civic.
Logan76
Car: Junk
Everyone posting their cars, welp I dont have one so I posted my dirty *** KA, it needs cleaned and a new dipstick, has the JGS kit mocked up with the .63 A/R 50 trim, ordering a clutch from AMS and 65lb injectors and it should run pretty good. I have pretty much what I need laying around or soon to be ordered I dont have a vehicle as of yet though.
RB_Seth
Car: 92 240sx RB25
91 240sx LT1
95 240sx 280k mile DD
Car - '92 240sx, currently has an pretty stock RB25DET (Nismo fpr, hybrid fmic, ebay 3"downpipe and hollow cat- fit awesome btw, RS*R catback) Stance GR+ coilovers, Battle Version suspension arms, 26mm Z front brakes, 5 lug and some other stuff
Location - Near Pittsburgh Pa
shally2186
Car: S14.5
should put up pics of your RB26DETT..u kno u want to
RB_Seth
Car: 92 240sx RB25
91 240sx LT1
dont really have any to put up, and its not much to see right now anyways... maybe when its goin back together with the goodies lol
Presscott707
Car: 1999 Maxima 5spd
Car: 99 Maxima 5spd
Mods:Center Force duel friction clutchFidanza flywheelCattman headers, and Y pipeCattman catbackStillen intakeebay high flow catTein basic dumpersFront and rear strut bars.
nterrigno
Car: 2005 Nissan 350Z (Enthusiast)
CAR: 2005 Nissan 350Z Enthusiast
MODS: BONE STOCK RIGHT NOW.....except for Panasonic MP3 Headunit
Pretty stock right now. Modding will begin this spring!
S13.5 ICHI-GO
Car: nissan 240sx 1990 s13.5
Nrw
Car: 1998 Nissan Maxima SE
Car: 1998 Nissan Maxima Se 5 speed (FS0)
Mods: DebadgedB&M STS w/stock knobCAI w/billet maf adapterPainted plug coverLED gaugesFSTB2k Maxima SE 17'sSmoked Bumper lightsRe-wired Fogsbrightened corner lightscustom "maxima" battery tie down
Pictures:
^^^ Old pic
White Comet
i guess i should update mine1990 240sx hatch base model (being converted to power options)purchase price: $300no motor or trans, mint underbody, and interior, formerly automatictoo much going into it to list heres some pics though
DJButton
Guess I should post a new picture too... Whole car will be new in a few months anyway, but here are some changes.
naladude911
Car: 2001 Infiniti QX4
Car: 1993 Infiniti J30 or mom's 2001 QX4 in winter or for recreational purposes
Mods: Only the J30 is modded. HIDs, soon two 12" sealed JL's 600W, intake, chrome appearance, custom front lip, engine paint, full Alpine Type S audio system, Panasonic Headunit. This summer its being repainted black, Borla Straight through exhaust, and maybe some 18" rims, tint, underglow.
Pictures:
Return to “Northeast Region”
