srpowered240sx
Shocker Style
90 240sx-sr, 92 F-150, 96 integra gsr
humboldt county ca
6-29-2005
even pressure. thats all you can do. keep pulling.
  When did I realize I was God? Well, I was praying and suddenly realized I was talking to myself. NICO photo contest crew..........three, count em, three times Proud Creator of WBDM2TTWFOC: Cuz selling is for pussies!!
aymaeid
93 Miata, 96 Accord, 96 Zenki
Bayonne Jersey
3-25-2007
| « Re: S13 door panel remove HELP!!! (94_240sx) | 1:11 PM 12/17/2007 |
the previous owner of my car broke mine in half, but once broken it slips right out, dunno why
| Quote, originally posted by 240sx_Guy » | ahhh i love nico. it always leads to piihb...
aziankingz
1990 240SX SE
NYC NY
10-9-2007
| « Re: S13 door panel remove HELP!!! (aymaeid) | 1:14 PM 12/17/2007 |
i have manual windows, so i wouldnt be able to relate, but i am pretty sure there are clips under there..just need to pull it hard..and at times you will see the clip flying out too
Project Piggy: Injen Cold air intake, Eibach springs/AGX adjustable shocks, Suspension Technique Anti-sway bars, S13 grey leather seats, Pacesetter Monza catback exhaust system, Strutbar, Drilled rotors, 16x7 gold Enkei 92 wheels +25 offset/ 205-55-16 Kumho ASX tires, EXEDY oem replacement clutch/F1 racing light flywheel, 95 J30 VLSD.
krazydriver
2002 civic ex, 1993 KA-T 240sx
Middle of Nowhere NY
2-8-2007
| « Re: S13 door panel remove HELP!!! (aziankingz) | 1:36 PM 12/17/2007 |
on my s13 just undo the screw and lift it out. Then unclip the power window switch harness. although i did pull/slide it back to front to make sure it was loose, then just grabbed the back side and pulled it out.idk why you had a hard time with it..
| Quote, originally posted by Encryptshun » | So he has an Integra and you have a 240? I know why she left you. She likes it in the front better than the rear. Welcome to NICO. |
Engine stuff for sale -> http://forums.nicoclub.com/zerothread?id=368806 MSD coils, S13 cam, Intake stuff, stainless braid oil lines + more!
Idunno..
Toronto
10-6-2007
| « Re: S13 door panel remove HELP!!! (krazydriver) | 1:55 PM 12/17/2007 |
I have the same problem with mine...i have yet to get it out...but then again i didnt try to hard, i unscrewed the screw, then tryed prying it out with a screw driver but it didnt really get out, i never tryed grabbing it...ill try again soon, was just lazy.
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! (Idunno..) | 2:20 PM 12/17/2007 |
There's something that we don't know what's going on. If you read the article and try to remove it, it's easy enough to understand what's going on, but something's still holding inside.
Spiffy240
1992 White 240sx Fastback SE
Sewaren NJ
2-20-2007
| « Re: S13 door panel remove HELP!!! (94_240sx) | 2:39 PM 12/17/2007 |
ok, i have this same problem but i figured out a wayListen: On that part that houses the controls for the power windows there is a clip on the front of it (the part closer to the hinge on the door). When you pull on it, the clip holds it in and it is a PAIN IN THE ***! Get a small flathead screw driver and slowly pry your way around the piece. Be careful around the edges, its old plastic and it can be brittle. Once u get some room to fit the flathead, locate the clip at the front and try pushing it in and lifting the piece up. Once you see it and it is up, things will go easier. Then start prying it up and watch out on the side closer to the door panel, that can be tricky too. Just maneuver it side to side and it should brake lose. IF THAT DOESNT WORK: Open the door and lay down on the ground underneath it. Pull the door panel on the bottom of it and pull until you hear and feel the clips let off the door. Now look up under the door panel in the gap and you will see the annoying mother fu**ing clip that annoys us all. Also, you can disconnect the unit wiring from it to make it a little easier. I know i write a lot, but good luck. It can be a real pain, but once you figure it out, you'll know what to do from now on.
 _____________ .:1992 240sx SE:. ______________
Spiffy240
Sewaren NJ
2-20-2007
| « Re: S13 door panel remove HELP!!! (Spiffy240) | 2:44 PM 12/17/2007 |
a pic to help
good luck and if need be, ask more questions
bamracing
1989 240SX Coupe dirt track race car / 1989 240SX Fastback parts car
Harlingen TX
6-14-2007
| « Re: S13 door panel remove HELP!!! (94_240sx) | 2:59 PM 12/17/2007 |
if ur talking about the passenger panel, there's one more screw that holds on the vertical pull handle. It held me up for a little while too.
vancouverbc
1991 240sx
langley
10-30-2003
| « Re: S13 door panel remove HELP!!! (bamracing) | 4:06 PM 12/17/2007 |
http://img341.imageshack.us/my...2.jpg jiggle it a bit as you pull up. it is sitting in an aluminum strap. trying pushing on door panel.
Modified by vancouverbc at 4:16 PM 12/17/2007
1989-1998 240sx TUTORIALS FACTORY SERVICE MANUAL Factory service manual2 Factory service manual 1989 Old FAQ INSTALLS Pictures of parts
ivorywhite240sx
Elk Grove California
3-13-2007
| « Re: S13 door panel remove HELP!!! (94_240sx) | 4:20 PM 12/17/2007 |
There is only one way to do it...unscrew all the screw, make sure you pull out the door panel, then gently slide it towards your car, there reach down behind the door panel, pull the plug, now it should come out, because of the plug its hard to get the clip to unclip. Below the plug is a piece of metal usually it holds the panel real tight therefore you have to slide the door panel to loosen it.
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! (Spiffy240) | 7:05 PM 12/17/2007 |
| Quote, originally posted by Spiffy240 » | On that part that houses the controls for the power windows there is a clip on the front of it (the part closer to the hinge on the door). When you pull on it, the clip holds it in and it is a PAIN IN THE ***! Get a small flathead screw driver and slowly pry your way around the piece. |
I guess this is it. That clip is the problem. I took these out from a junk car and I had to break driver side switch housing.
Uberck
93' 240sx
boston
6-10-2007
1. pop door panel clips 2. reach from underneath and push metal tab in on controls and push up 3. push panel up over window seam 4. unplug controls from harnesscustom title please
vancouverbc
1991 240sx
langley
10-30-2003
| « Re: (Uberck) | 7:32 PM 12/17/2007 |
there isnt a clip on the 91
Redevil
Oakland CA
11-26-2006
| « Re: (vancouverbc) | 10:34 PM 12/17/2007 |
slide the piece backwards and lift up. I've taken that out numerous times with no problems.
vancouverbc
1991 240sx
langley
10-30-2003
| « Re: (Redevil) | 11:17 PM 12/17/2007 |
http://forums.nicoclub.com/zerothread/253736another door removal tutorial
Modified by vancouverbc at 4:41 PM 12/18/2007
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: (Uberck) | 5:41 AM 12/18/2007 |
| Quote, originally posted by Uberck » | | 2. reach from underneath and push metal tab in on controls and push up |
Okay, this was it. You can reach it if you stick your hand. I was able to remove it without damaging it. Thanks...
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: (94_240sx) | 5:56 AM 12/18/2007 |
One more thing though. I took my time and was very careful, but still these tabs just broke off like this. But it should be okay and it's going to be even easier next time when I remove the door panel.
Modified by 94_240sx at 6:23 AM 12/18/2007
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! (vancouverbc) | 5:57 AM 12/18/2007 |
Are there letters on the window switches???? Never seen them before. Mine was all gone when I bought the car.
White Comet
1990 RX-7 and 1993 240sx
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (94_240sx) | 6:18 AM 12/18/2007 |
yep, spiffy hit the nail on the head, thats exactly what i was going to say. i didnt know that the 91s dont have that clip , interesting. i currently have my door panels out and cut into pieces
91 Camaro RS build White Comet Sale Daytona Blue paint aftermarket gauges welded diffs, diff housing and ring gear
wtb- s14 speed sensor
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! | 6:27 AM 12/18/2007 |
Alright, One more question about the door panel. What's the best way to clean the fabric? Mine is dirty and I was thinking about pressure washing(w/mild pressure) it after I apply a little bit of soap. I did that to floor mats and it really cleans up. Do you guys think it's going to work? Has anyone done it before? I don't want to mess it up.
White Comet
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (94_240sx) | 6:52 AM 12/18/2007 |
i dont think pressure washing is necessary, how dirty are they? i cleaned mine up by hand w/ a bucket of soap and water. that should do the trick
krazydriver
2-8-2007
| « Re: S13 door panel remove HELP!!! (White Comet) | 7:11 AM 12/18/2007 |
Oxyclean fabric stain remover. This stuff is AMAZING. The back seat of my s13 was so nasty when i got it, soaked it in water mixed with oxyclean and got about 3 gallons of BLACK water out of it. Then scrubbed it with the oxyclean and vacuumed some more, then rinsed it all out with the hose. Now it looks almost newwhen i cleaned my door fabric i just used a damp rag with some of the oxyclean stain remover on it. Then once they were nice and clean... i decided to reupholster them like 3 weeks later.
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! (krazydriver) | 7:23 AM 12/18/2007 |
| Quote, originally posted by krazydriver » | | Oxyclean fabric stain remover. |
Alright, that's what I wanted to know. I think Bed, Bath & Beyond has them. I'll update this thread with some before and after pics. Cool, thanks.
White Comet
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (94_240sx) | 7:34 AM 12/18/2007 |
are u talking about the whole door or specifically the small carpeted area on it?
94_240sx
'Vert Encyclopedia
94_240SX
TX
2-28-2005
| « Re: S13 door panel remove HELP!!! (94_240sx) | 8:03 AM 12/18/2007 |
| Quote, originally posted by 94_240sx » | Alright, that's what I wanted to know. I think Bed, Bath & Beyond has them. I'll update this thread with some before and after pics. Cool, thanks. |
Small carpeted area. Sorry. I should have specified that.
White Comet
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (94_240sx) | 8:20 AM 12/18/2007 |
oh got ya, after rereading the posts thats what i thought, but i was initially confused cuz the pics had no carpet. im in teh process of redoing the carpeted area on mine
Spiffy240
Sewaren NJ
2-20-2007
| « Re: S13 door panel remove HELP!!! (White Comet) | 7:05 PM 12/18/2007 |
thanks comet for the gratificationbut y not just take that stupid carpet stuff off it looks better off just take off, clean with rubbing alcohol to get residue off, then armor all cleaning and protectant wipes/spray http://www.nicoclub.com/articles.php?id=175775 ^^ link for convenience ^^ ive actually re-vinyled my door panels and i take them ****s off all the time b/c i put 6 1/2 infinity speakers in there and its all connected to a 4 channel amp
krazydriver
2-8-2007
| « Re: S13 door panel remove HELP!!! (Spiffy240) | 7:32 PM 12/18/2007 |
lol i just got around to doing the same thing. 6.5" infinity kappa's VERY NICE!! plus the revinyling looks so much better then the fabric, and it matches my glovebox and seats better.
positron_
240SX Padawan Learner
1993 Nissan 240SX Coupe
Starkville MS
3-21-2005
| « Re: S13 door panel remove HELP!!! (94_240sx) | 11:02 PM 12/18/2007 |
What's up 94 ...those pesky clips. Mine usually pops out when I slide it back then up.
"Where's my mother%$@##! movie check?"S13 300ZX Rear Brake Install http://forums.nicoclub.com/zerothread?id=277821 S13 Fender Brace Install http://forums.nicoclub.com/zerothread?id=255621 S13 Power Folding Mirror Install http://forums.nicoclub.com/zerothread?id=253619 S13 Subframe Collar Install http://forums.nicoclub.com/zerothread?id=215477 S13 KA24DE Engine Removal http://forums.nicoclub.com/zerothread?id=299950 S13 Wheel Stud Replacement http://forums.nicoclub.com/zerothread?id=247358
White Comet
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (positronone) | 6:20 AM 12/19/2007 |
im redoing my panels but not like the way in the link, i cut my door panels in 2
Uberck
93' 240sx
boston
6-10-2007
| « Re: S13 door panel remove HELP!!! (White Comet) | 6:53 AM 12/19/2007 |
wtf? details?
White Comet
lancaster Pa
6-15-2006
| « Re: S13 door panel remove HELP!!! (Uberck) | 7:51 AM 12/19/2007 |
write up coming soon
