my 240sx ford 302 engine changes (lots of pics)
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
maik21
Car: 90 Nissan 240SX Coupe 5.0
this is my 240sx... my project starts maybe 2 years ago... so i put engine in there but there was some wrong things with the install and i decided to do it better than the first time. i will buy a welder machine to do stuffs but i never weld anything so i need to learn how to but i think its not hard.
before the engine changes.. they will be outside changes.. a great bodywork will apreciate.
first off... my actual car..
clearance between radiator and water pulley
engine mount and oil pan .. its to dirty
actual carburator and intake .. edelbrock 600cfm and torker II
my car this morning.. yea.. i open the hood and put a piece of wood in there because the first person who install the engine... took the steel piece and put in the transmission shift pod.
look at clearance between transmission bolts and the transmission hole... the engine its mounted horizontal and maybe if i let it drop the back a little, it will be sit better...
an other one
see the square piece of wood in the engine mount.. i put it there because the engine was sit higher at one side.
radiator fans, yea ... the car is nissan...i want radiator fans in the right place because this city its to hot in the day all the year. some times hits 45 C
yes, stabilizer bar hits the pulley every time when car is lifted. but when the car is down, it works fine.. but its a problem so i will fix it... see the oil pan.. its to down... one time i hit a rock in the street and broke the oil pan.
transmission was mounted to high... and the exhaust system suc** .. its fine when u do the job and thinks goes wrong... its bad when other do the job and all suc** ...
spoiler or wing.. i dont know but i like it.
radiator and electric fans
see carefuly this picture.. i will take the engine pulley and quit the last "V" thing... and short it from the beginning
i cant take off this piece... i dont have a piece that take of a big bolt
i pay 3 bucks to my brother .. he was cutting the exhaust
with this.... cutting tool without the ... see for ur self
wing or spoiler
another one..... .. see far far away...
one more...
i put some pieces of brake pads to lift the engine mounts and see how high can i lift it ...
after i mod the height ... it looks great... i take notes and try to do new engine mounts.
if all things will going good oil pan will be more at the back and with this height
im asking for manual transmission costs because i will do a auto to manual swap too.
please.. give me some advices with all stuff i show you.. and some others with the electric wires.
how back can i mount the engine or how back its recommended distance?i will purchase cams for my engine too =) on tuesday.thanks.
BMAR240SX
Car: 1993 Nissan 240S Coupe
Should have painted the engine bay bro, Nice work
maik21
BMAR240SX wrote:Should have painted the engine bay bro, Nice work
i will clean it.. dont worry.. i want to pull out the engine and clean and paint too !!!! but i go to school and time is over me right now.
time is a matter.
i will post more pics when engine is out.
jeramie411
Car: s13
word keep going
WDRacing
Any updates?
maik21
WDRacing wrote:Any updates?
i receive last week the heads .. they were rebuild and now, it will work fine... they dont port and polish because i will save for a good set of al heads.. but not right now... and i have a new timing chain cover.... i will install all this end of week but i dont have money right now... so the updates will be slow......
some man want to sell me a manual transmission from a mustang... he say the transmission will have all the things i need to install and the clutch its a wire clutch, not hydraulic clutch so i dont know if it will work great. i think its easy to do some custom things if i have that transmission
what its the best ? hydraulic clutch or wire clutch?
with wire clutch, i can easily put some custom pedal on it without those slave and master cylinders.
the cost of that transmission with all the stuff for plug and play will be 100 usd.
WDRacing
I've never even been around an electric clutch. I've always had hyd...
maik21
WDRacing wrote:I've never even been around an electric clutch. I've always had hyd...
its not electric... its something like the wire of the gas pedal, or the wire of the brakes in a bike.
some more... its with five speed.
maik21
im very very happy... my car now is back... its about one day or two for a complete swap.
the manual transmission t5 is mounted and the engine was started some minutes ago... i will need some custom headers but for a few days, i will run with direct exhaust. ...i take a video and i will upload tomorrow because i dont have some wires to conect phone to pc. so... so i will come back with some under the hood pics...all look better than before.
xekushnr
Car: '90 Nissan 240SX Hatch
Aw, you should have sprung for a T5-6. All of my 5.0 friends with a T5 want to do a T5-6 swap. That extra gear will come in handy on the highway and will save gas.
Get some more pics soon! I remember seeing your first "I'm swapping in a 302" thread WAY back and I'm glad to see its moving along.
maik21
im uploading some new pics right now!!!
maik21
WDRacing
Hows it run?
maik21
WDRacing wrote:Hows it run?
it runs very fine..i was having problems with alternator belt but i fixed yesterday.... it spin tires in 1st and second all the time even without the need of kick clutch. .. its more powerful than before. im waiting for the 1/4 mile time. maybe this saturday will be open and i will be there.
i dont know if other v8 fords in a 240 has the electric fans as my 240 has.
now its radiator, fans, engine!!!
maik21
to bad news... i was to the track yesterday to run my car... i have 235-45-18 in the back and 245-40-18 in the front.. so.. i ran and dit 16.7 in the 1/4 mile at 138kph...so maybe i had a bad launch because my tires spin to much and i didnt do a burnout before start so my tires where at normal temp. i start in 1st gear . my car has a lot of torque and maybe if i start from 2nd gear the things were diferent.
my carb its progresive but in the secondary butterfly has a upper vacum butterfly and i stuck that with some pieces of plastic because the real secondary butterfly only opens when i fully press the gas.
monkeydemond
Car: 93 Nissan 240SX coupe
hey thats a bad *** swap man, im looking to do the same thing but w/ an efi 5.0. how did u u make the motor and transmission mounts?
maik21
some pieces of metal.. u need the original metal mounts of the 302 and the plastic mounts from a marquis, they look square ... next u need to put the engine in the desire position and make the custom mounts... its so easy... transmission m ount its similar to the stock moun and if u do automatic, u will have no problem with that.
maik21
bigk
Car: cars, football, girls
How much forward is the shifter from the stock location? Any problems with shifting into gears and hitting anything?
maik21
bigk wrote:How much forward is the shifter from the stock location? Any problems with shifting into gears and hitting anything?
it isnt hitting any because i remove some metal...
its at least 3/4 of hand forward from the stock location. i didnt have problems to shift. all its all right !!! there is only a must have tunne of carburetor.
bigk
Is it possible for you to take a picture of the shifter in first gear. i would like to see how far forward it is. Im trying to convince myself to do a efi 302 240sx.
maik21
check the video link http://www.youtube.com/watch?v=pW65OockPEQ
it show u how far it is. and u will need an L adaptor as mustang have.
http://www.youtube.com/watch?v=DRrG3lplNuQ
Modified by maik21 at 7:10 PM 9/10/2008
bigk
Does this L adapter look like this?
maik21
yep, thats a fashion L adaptor... i did mine with some tubing and my welder !!! les tan 3 bucks !!! one lug and buala !!!
maik21
u can use the one from the mustang but u need to do some little mods . i did mine to save some money.
streetnissan240
Car: 1992 Nissan 240sx
sup i am lovin this 240! i am thinking of putting a efi 5.0 in mine. But i have questions....did you cut anything to get it to fit? Did you use stock driveshaft and axles? Did you use a 5.0 driveshaft and axles? How many mods you had to do??
maik21
streetnissan240 wrote:sup i am lovin this 240! i am thinking of putting a efi 5.0 in mine. But i have questions....did you cut anything to get it to fit? Did you use stock driveshaft and axles? Did you use a 5.0 driveshaft and axles? How many mods you had to do??
y need a driveshaft for the transmission u will use, and the driveshaft for ur stock diff. then y will cut and paste together and u will have a new driveshaft.
u need custom oil pan, and custom engine mounts... uf u use a automatic aod transmission, u didnt need to cut anything and u can use a chevy transmission support for this aod transmission. it will bolt right.
u can see pics of swap and the video because i swap to t5 and cut some metal in the shift pad.
nisord
Car: 240sx and 300zx both with ford motors
hey figer i would put my two sence Worth in to maybe give you some help if i can. alright now first pick your motor 302 from 87 to 90 is about the best of all of them to go with in my opinon if you don't want to change much to the motor. they have a roller cam and they have foraged pistons factory (good for nos or any charger on the motor. if you don't mined putting a hood scoop or the engine sticking though the hood some then the 351 (5.8L) would be a better choice. both would not need any stiffer springs unless your going for really hard corning then i would say stay with the 4banger. not sure what all you know about the 302 and 351 but basicly they are the same motors but the 351 has a 1" taller deck height and larger stroke and rods. because of this the intake and distributor are diffrent. the oil pan is also diffrent. you will need a front sump oil pan (came in most the 60's and 70's cars with the 302 and 351. see the pics of the guy with the red engine bay 240. using the early 90's exsplorer water pump and pulley system will give you about 1" more room up front. the headers i would use early 90's truck 302/351 equale length headers. tyhere a bit more costly but will allow better performance and a much cleaner look. they will require someone to do a little heating and bending and someone good at bending some piping. this is about the hardest part of putting a v8 ford in. I'm running true duals all the way out the back so I'm going a little further and i have cut the back floor out and removed the fuel tank and made the back floor go straigh across and am putting an isuzu trooper fuel tank in place so that i have room for the pipes, one on each side of the tank. as far as the modifications that would need to be done i would cut a little off the front side of the cross member and weld a piece of angle iron back in place to get the strength back. this will keep from you having to cut or dent in the oil pan and also get the motor and trans further back in the car making for better acceleration and cornering. the drive shaft has no easy way out that i have found yet. motor mounts will have to be custom. note: make sure you leave the trans mount with a soft mount. if you have a solid mount you could risk busting the trans housing when the car twist, and with a torque v-8 that will happen. if you want to know what the difference is your stock 2.4L puts out about 145hp and only about 120 ft lbs of torque. a like 88 302 stock makes about 230hp and about 210 ft lbs of torque and its only about 100 to 150 lbs heavier. your money will go further and you will be making more that 2 times the hp per dollar with the 302 than the 2.4 or the 2.0 Nissan motor. plus if anything breaks or goes bad you can get the part cheaper, twice as fast, and easier so it will be down for less time. your radiator the best i have found is from a 4.0 ranger. if you need any more help you can email me at [email protected]. maybe I'll have some pics before long of the 240sx and my other project ('91 300zx with a 4.6 4 valve motor from a licon mark VIII)
nookie2692000
Car: 2 91 coupe`s. one going 302 fully gutted street beast
maik. how well does the auto trans line up with everything? somewhere i know you said you used an explorer water pump? i work at autozone, i was looking at various 302 water pumps. the shortest one i can find is from a 97 explorer. it is about 3 or 4 inches tall. but in order to run it you will need to change the timing cover otherwise your coolant wont flow. so that will help some of you out. the stock pump is 5.75 inches tall. they make 2 versions of it as well. the heavy cast one and a nice aluminum one. the aluminum one is from a late 80`s 302. like a 89 crown victoria.
maik21
nookie2692000 wrote:maik. how well does the auto trans line up with everything? somewhere i know you said you used an explorer water pump? i work at autozone, i was looking at various 302 water pumps. the shortest one i can find is from a 97 explorer. it is about 3 or 4 inches tall. but in order to run it you will need to change the timing cover otherwise your coolant wont flow. so that will help some of you out. the stock pump is 5.75 inches tall. they make 2 versions of it as well. the heavy cast one and a nice aluminum one. the aluminum one is from a late 80`s 302. like a 89 crown victoria.
yea... i dont know exactly what water pump im running right now.. i only know it flows same as the too old water pumps in ford 302, but mines is aluminum...and its a custom one.. before made it custom, this water pump (Al) was a little shorter than the cast iron. the pulley its custom too, u can see in the pictures !!!
Return to “Hybrids”
